1 - 6 of 6 Posts
Do they even fit and if so does anyone have any pics.
Getting ready to have camburg 2.5 coilover susp kit with deaver leaf springs put on my 2012 crewmax. I will most likely go with method rims and have only seen 18s on crewmax.
16s no. Very few 17s will fit. Some members have 17" methods
Reactions: Powertechn2
Ya i just saw the post by the guy who put 16 inch wheels with slicks and the grinding he did to his calpers. Thanks...For some reason I didn't think the methods 17s fit the crewmax only the 18.....Thanks again
All 07-13 Tundras, be they Regular cab, Double cab or CrewMax, can fit the same wheels (17"+). There's no difference in available fitments that's depending on the cab (or the bed length, or the drive type).
Volk (Rays) TE37s are probably the lightest 18" wheel you can find, but also one of the most expensive. TRD Rock Warrior wheels are 17" and forged and thus also very light weight as well as being strong. They get heavier from there.
^^ What he said.
harder to fit front's, rear rotors smaller, thus grinding to fit (not recommended) can manage 16's... fronts. grind away and I still don't thing you would ever manage.
methods and rw wheels and last I knew that was it for a 17.
1 - 6 of 6 Posts
