1 - 4 of 4 Posts
I am looking at getting a set of rims and was wandering can I clear 14.50 wide tires with a 20x10 -12 offset rim?! I'm not talking about cab mount clearance but room between in side of tire and the knuckle/spindle?! Thank you all!!
20x10" with -12mm offset gives you about 5" of wheel backspacing plus another 1.75" of tire gives you 6.75" from the hub inward, so measure back from the hub mounting surface and up and down 11" or so to get an idea. I really don't know if it will rub or not. Just adding my 2 cents.
Reactions: Ogtoyfan
Not sure how valid it would be since your truck will be in full droop while you are measuring but it could give you a rough idea. Someone running the same setup would be beneficial. Good luck.
1 - 4 of 4 Posts
