0w-20 vs 0w30
25853 Views 70 Replies 23 Participants Last post by  ColoradoTJ
This is not a motor oil question or review, just an experience. I took my truck to the dealer last saturday for them to change my oil (first mistake). I bought 2 gallons of amsoil ss 0w-30, knowing our truck takes 7.9quarts. 1 gallon equals 4 quarts, so 8 quarts of oil and an amsoil filter. The dealer calls me back and states that I have the wrong kind of oil, the truck takes 0w-20. I tell them that I know, and that I want to use 0w-30 because I tow. The dealer then tells me that the 0w-30 may cause a check engine light!!! I told her she was full of it and go ahead and change it.
Two hours later, they call me back and the truck is ready, but it is a quart low on oil! I hit the roof! After much deliberation about their intelligence, I speak with the tech, and he claims that the amsoil fiter is larger than the toyota filter.? When I check the oil, of course it is not a quart low, just a hair below the full line.
Anyway, I wanted to let anyone know who is on the fence about using 0w-20 or 0w-30 There is no check engine light that warns you have the wrong oil, and that the truck is VASTLY quieter and smoother with 0-30. I never liked all the clank clank and diesel sounds my truck made with the 20 weight oil. It is like a whole different beast (ie, no clanking) now that I switched to 30 weight. I will never put that 20 in the truck again! I don't care what the book says about 20 weight, I want my truck to last, and 30 is the way to go for me!! No noticeable drop in MPG either.:machinegunner:
61 - 71 of 71 Posts
http://s1307.photobucket.com/user/2...3Motul0w30-TOYTUN-12-ENG_zpsb15c74bb.jpg.html
A 2012 Toyota Tundra 5.7 with 6,000 miles on a run of Motul X-lite 0W-30 with a TRD oil Filter and stock Toyota Air Filter and 22 percent BP, 22 Percent Shell and 56 Percent Chevron/Texaco, only one tank of injector cleaner used during the drain. The Tundra was used for about 3,000 miles of interstate without a trailer and 3,000 miles to tow a 3,000lb trailer up and down steep hills on short trips, in a mild Southeast USA climate.
The result was that the 0W-30 was ok in the short term, but the increased viscosity and fuel dilution created a small amount heat/wear in the engine.
The end result is that, subject to your own personal oil testing/applications, my consensus thus far is to definitely use a 0W-20 or 5W-20, Probably M1 AFE or Toyota Branded oil, which is made by XOM, but was made specifically to Toyota’s Specifications. Honda appears to have back specified 5W-20 in the Sixth Generation accords; I am testing 0W-20 in that application too.
For the drivetrain/differentials, the Toyota 75W-85 is probably for CAFE ratings, something like an Amsoil 75W-110 or a straight 110 weight oil like LE 1605, but I do not have the test data to show anything yet.
As always any oil you pick varies based on your application, and this is mostly over my head, but it seems that there are applications which involve a lot of short trips where the cold-start protection of 0W-20 is better. It appears that even if 0W-20 was created for CAFE ratings, the end result appears to be a win/win for everyone. The easiest to procure, best 0W-20 is probably going to be M1 AFE or Toyota or Honda branded 0W-20. I am currently testing a run of Motul Eco-Lite 0w20.
Red Line/Amsoil might be the best 0W-20 for towing:
Which 0W-20:
Which 0W-20 - Bob Is The Oil Guy
Favorite SN 0W-20:
Favorite SN 0w20? (NOT THE BEST) - Bob Is The Oil Guy
Do you really need any thicker than 0W-20?
Do you really need any thicker than 0W-20? - Bob Is The Oil Guy
I like your Colt Cingular, but can't find your UOA.
I agree with your lube opinions so far too. Good call on the SAE 110 rear diff!
that is total B.S. Never heard of having to take the vehicle in for all scheduled maintenance at a dealer to get any type of ext. warranty valid. I cry liar and cheater on that one.
Do the oil change yourself next time to make sure it is done right. Dealer cannot void your ext. warranty for doing your own oil changes period.
Cookiedough1-all I can tell you is that is the answer I got from Sparks. I didn't pay for the extended warranty, it was a dealer warranty that came with the truck. I paid to have the water pump replaced as my truck is an '08 and has 65K miles. I've saved the warranty paper since we may have a toilet paper shortage some day.
They told you that, but did you see it in fine print in the actual writing of the paperwork? All they told you that for was to get you into their stealership for a price gouging of maintenance. You can do your own oil changes or go anywhere and NOT void any ext. warranty of anykind plain and simple.
Cookiedough1-No, I haven't pulled out the paper and checked it. Since their first reaction was negative I was concerned about them doing any work on my truck. And I have since relocated and the dealer is about 200 miles away. Thanks for the concern.
2
:auto:I got my UOA back from blackstone. The first one is on toyota 0w20 and the second one is Amsoil 0w30
For me and my application, seems that amsoil 0w30 is best. I think the silicon is from the the K&N. May look into changing that back to stock and see what the next report says.
I appreciate your input, cingular, but bobs the oil guy is just a lot of people with opinions. The results from the uoa is what I want to go by for my application.
Good Luck!
:beerchug:
I think what we know about oil is an on going learning experience. Years ago most of us old timers were convinced we had to change oil every 2,000 miles or so. We also used heavier oils such as 10-40. Also ran 90 weight gear oil in the manual transmissions. Now most manuals run engine oil.
As the years go by the oils (now mostly syn or syn blends) get thinner and thinner yet our engines last longer than they used to. Now we have manufactures recommending 0-20 weight for some cars as well as 100,000 mile powertrain warranty (Hyundai). We rarely hear about any engine needing new rings or a rebuild and often hear others talk about 200,000 miles on their current ride and the engine is still in great shape. Just as many of these high mileage motors are running dyno oil as syn.
The stubborn side in me tells me I don't want to use 0-20 weight but I have to believe the builder of the car or truck has my best interest at heart. Oil continues to improve as does the quality of how the vehicles are being built.
I do have a UOA, I just used a photo hosting link in my other post because I had trouble uploading a picture.
The result was that the 0W-30 was ok in the short term, but the increased viscosity and fuel dilution created a small amount heat/wear in the engine. 0W-20 is a much better choice for this engine according to the professional interpretation of this oil report.
I'm going to stick with what the highly educated and paid engineers recommend for my 2012 5.7. The owners manual does state that a higher viscosity oil can be used under extreme conditions like high speed or extreme load conditions.
I don't tow a space shuttle around, so 0W-20 works for me.
61 - 71 of 71 Posts
