So this truck must have spacers then?... otherwise you are contrdicting yourself. I want to put 35's on mine. Does anyne know how much offset would be needed?They are 35's. This truck has been discussed many many times on the other forum.
35's will rub with out off-set rims. 305/65 is about the biggest you can run with no rub, but it will require a small trim to the skid plate.
yes the guy who owns this truck made his own spacers to fit the tires. I think they were 3 or 5 mm spacers.So this truck must have spacers then?... otherwise you are contrdicting yourself. I want to put 35's on mine. Does anyne know how much offset would be needed?
My beig question is how much does the 305 effect your gas milage
It's not the wheel well where it's rubbing. Spacers are irrelevant.So this truck must have spacers then?... otherwise you are contrdicting yourself. I want to put 35's on mine. Does anyne know how much offset would be needed?
F'n Sweet!!!Here is a picture of mine on 20" rims with 35" tires....
