1 - 2 of 2 Posts
I was told a levelling kit would fix the tires rubbing the frame on hard turns, which is only rubbing problem so far. I could use some advice as there are many options. I want to lift only enough to stop the rubbing. I like a stiff ride and want more suspension strength in rear to reduce sag when loaded. The truck is on the road more than off road. Two kits I have looked at so far are Bilstein and Toytec. Both 3" using spacer for front and add-a-leaf or block for rear. (both say if spring retaining clamps are less than 31" apart then add-a-leaf will not work).
Any help is greatly appreciated.
Discussion Starter #2
Just realized Toytec is probably not the manfg. in which case I not sure what I was looking at.
1 - 2 of 2 Posts
