1 - 20 of 68 Posts
Here is some information on doing LED gauge swaps in Tundras, It really depends on the year you have and what all can be done, Ill list what is different about each year below, this is not a sale add, I offer swapping services since a lot of you don't want to tear into the gauge cluster, (they run about $600-1400 for replacement) I swap the LEDS and ship it back same day service if your interested.
2000 to 2004 tundras use (74/t5) led bulbs, for the cluster and 74/t5 for the climate control along with 194/t10 leds, this can be done fairly easy.
2005-2006 the climate control is the same, but the cluster uses leds that need to be soldered on the cluster, on top of that it needs to be finely sanded to get the green film off the overlay.
2007 to current are all leds and range from size to type. I stock everything needed for this swap.
http://i15.photobucket.com/albums/a383/Biohazard2070/LED%20Gauge%20Swaps/IMG_1142_zpsc6212806.jpg
Where you located, how much you charge?
The Green!! How much do you charge for that amazing work of art?!
Guys,
There are different models of Tundras that have different options, what I will do is list those options and you can PM me with what options you have and what you want done and I will get you a price for that.
Tundra model
SR5
Limited (this edition is the hardest of them all)
Rock Warrior
These are all the leds needed for each light
2007-13 TOYOTA TUNDRA
GAUGE CLUSTER COLOR
• CLUSTER NUMBERS & LETTERS COLOR #11
• NEEDLE COLOR #10
• GEAR NIGHTTIME POSITION COLOR #1
• ODOMETER COLOR #3
• DRIVE POSITION P,R, N, D, 1, S #6
• MANUAL GEAR POSITION COLOR #1
• TURN SIGNAL COLOR #2
• TRACTION CONTROL #1
• E-BRAKE #1
• VSC #1
• CHECK ENGINE #1
• TOW HAUL #1
• 4X4 HI #1
• 4X4 LOW #1
• CRUISE CONTROL #1
• DOOR AJAR #1
• HIGH BEAM #1
• LOW FUEL #1
• SEAT BELT #1
• LOW WIPER FLUID #1
• ABS #1
• LOW TIRE PRESSURE #1
• AIR BAG #1
• AUTO LSD #1
• BATTERY #1
• RSCA (REAR SIDE CURTAIN AIRBAG) #2
CLIMATE CONTROL
• NEEDLES ON KNOBS #4
• MAX A/C #1
• SYNC #1
• A/C LOW/HIGH #3
• A/C POSITION #4
• HOT/COLD # 4
• PASS SIDE HOT/COLD #4
• A/C ON/OFF #2
• DEFROST #2
• RECIRCULATION #2
• AIRBAG LIGHT #6
• SEATBELT #2
BUTTONS/SWITCHES
• 4x4 SWITCH #3 COLOR #3 NEEDLE
• TOW HAUL #1
• RSCA #1
• ROLL DOWN WINDOW #1
• HEADLIGHT ADJUSTMENT #1
• CARGO LIGHT SWITCH #2
• INTERIOR LIGHT SWITCH #2
• INFO/MODE/RESET/SONAR BUTTON #4
• WINDOW AUTO SWITCH #1
• STEERING WHEEL CONTROLS.#7
• SEAT WARMER #2
I offer lifetime warranty on all LEDS, should any fail I will replace them at no charge, However it does not cover shipping.
Guys,
Tundra model
SR5
Rock Warrior
GAUGE CLUSTER COLOR
• NEEDLE COLOR #10
• ODOMETER COLOR #3
• E-BRAKE #1
• VSC #1
• CHECK ENGINE #1
• TOW HAUL #1
• 4X4 HI #1
• 4X4 LOW #1
• CRUISE CONTROL #1
• DOOR AJAR #1
• HIGH BEAM #1
• LOW FUEL #1
• SEAT BELT #1
• ABS #1
• AIR BAG #1
• AUTO LSD #1
• BATTERY #1
CLIMATE CONTROL
• MAX A/C #1
• SYNC #1
• A/C LOW/HIGH #3
• A/C POSITION #4
• HOT/COLD # 4
• A/C ON/OFF #2
• DEFROST #2
• RECIRCULATION #2
• AIRBAG LIGHT #6
• SEATBELT #2
BUTTONS/SWITCHES
• TOW HAUL #1
• RSCA #1
• SEAT WARMER #2
I need all buttons green that would go on a 2wd 2012
What's up Daniel. LEDs looking good. I like the white with blue. Might have to change mines from blue to white.
^^^^^ hahahahaha. already rockin the purple in the turn signals.
White with blue is bad ass. My truck is my daily driver or I would do this for sure. PM on they way with ?'s.
Guys,
Tundra model
SR5
Rock Warrior
GAUGE CLUSTER COLOR
• NEEDLE COLOR #10
• ODOMETER COLOR #3
• E-BRAKE #1
• VSC #1
• CHECK ENGINE #1
• TOW HAUL #1
• 4X4 HI #1
• 4X4 LOW #1
• CRUISE CONTROL #1
• DOOR AJAR #1
• HIGH BEAM #1
• LOW FUEL #1
• SEAT BELT #1
• ABS #1
• AIR BAG #1
• AUTO LSD #1
• BATTERY #1
CLIMATE CONTROL
• MAX A/C #1
• SYNC #1
• A/C LOW/HIGH #3
• A/C POSITION #4
• HOT/COLD # 4
• A/C ON/OFF #2
• DEFROST #2
• RECIRCULATION #2
• AIRBAG LIGHT #6
• SEATBELT #2
BUTTONS/SWITCHES
• TOW HAUL #1
• RSCA #1
• SEAT WARMER #2
So how much for this mod?
How much for you to come to my house and do this mod for me ;):D
Discussion Starter #15
Depends on the options your truck has, limited tundras are by far the hardest swap due to the changes Toyota made on them, and if you want every light swapped, if you have a stock radio, and if you are shipping.
If you ship I give discounts to try and make up for having to take it all apart and ship it.
Sure buy a plain ticket and pay for a hotel. or just ship it and rent a car it would be cheaper.
Well to give us all a general idea, could you give us some kind of numbers? Lets just say the limited and all of the LEDs swapped. Or give us a base model all LEDs swapped or hell, even just the cluster. A List of the price per each assembly would be nice. Something. Just sayin.
Discussion Starter #17
for regular Tundras 07-13 with the SR5 package it is $250 for the full swap, gauges, climate control, stock radio, all buttons/switches.
for limited tundras 07-13 price is $340 for the full swap, gauges, climate control, stock radio, all buttons/switches. (gauges/climate control are near impossible and require a ton of desoldering/resoldering of connections)
for RockWarrior Tundras 07-13 with the SR5 package it is $260 for the full swap, gauges, climate control, stock radio, all buttons/switches.
Swap takes 4-6 hours of time
07-13 regular/sr5 trucks
Clusters are $75.
Radios are $65.
Climate control is $55.
Buttons/Switches are $7 each.
Swap takes about 6-9 hours of time.
07-13 Limited trucks
Clusters are $115.
Radios are $65.
Climate control is $95.
ALL LEDS ARE LIFETIME WARRANTY (doesn't cover shipping costs)
Hope this helps you guys out.
Wish you were local i would get the swap in a heartbeat!! What kind of turn around are we looking at?
1 - 20 of 68 Posts
