2017 CrewCab Limited TRD Tires - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 6 (permalink) Old 08-24-2019, 10:29 AM Thread Starter
Guinnessny's Avatar
Quoted: 16 Post(s)
Hi guys,
Its time to get new tires on my 2017 Crewcab Limited TRD. I currently have the original stock p275/65/R18 Michelin LTX A/T 2 with 43,000 miles on them.
I'm looking to get a bigger tire that will fill the wheel well out a bit more, but not crazy big. I believe i would like to keep the width the same..... so is P275/75/R18 the size i should get????
Whats a good tire size that will not cause any sensor problems or huge speedo changes?
Thanks for the help.
Rob
Guinnessny is offline
post #2 of 6 (permalink) Old 08-26-2019, 01:46 PM
Quoted: 17 Post(s)
I do not believe any major tire manufacturers make a 275/75 18 tire. You can go 275/70 18 (33x10.8) or 285/65 18 (32.5x11.2) or 285/70 18 (34x11.2). Stock tires should run around 32x10.8.
I have 35k on my stock LTX AT2's and they are ready to be replaced as well. I do tow approx. 6k lbs somewhat regularly so I'm not surprised to only get 35k out of the P rated tires. I plan to for with 275/70 18 LT E rated tire once I add the bilstein 6112's and 5160's.
2017 CM LTD 4x4 TRD
AZBoatHauler is offline
post #3 of 6 (permalink) Old 08-28-2019, 10:43 AM Thread Starter
Guinnessny's Avatar
Quoted: 16 Post(s)
AZBoatHauler,
Thanks for the info. What do you think is the largest size I can go with on my stock 2017 Crewcab Limited TRD?
Thanks Again,
Rob
post #4 of 6 (permalink) Old 08-28-2019, 11:57 AM
Quoted: 197 Post(s)
ANY change in tire size will affect Spedo and MPG and MPG readout display accuracy.
My winter set up , the tires are a lil bigger and its 2mph slow on the speedo.
2018 TRD OffRoad 5.7 gasser
24hrsparkey is offline
post #5 of 6 (permalink) Old 08-28-2019, 12:06 PM
1lowlife's Avatar
Quoted: 1287 Post(s)
You can use this calculator to see the physical dimension differences between tire sizes.
It also gives you MPH differences as well.
https://tiresize.com/calculator/
Learn it, know it, live it.
Texas Tundra Group #183
1lowlife is offline
post #6 of 6 (permalink) Old 08-28-2019, 07:44 PM
Quoted: 17 Post(s)
Originally Posted by Guinnessny View Post
AZBoatHauler,
Thanks Again,
Rob
275/70 18 will be the tallest you can run without modification. (you might have to remove the tiny air dam in front of wheel but it is unlikely) 285/65 18's will also work. I have not heard of anyone able to fit 295s without doing some modification.
2017 CM LTD 4x4 TRD
  TundraTalk.net - Toyota Tundra Discussion Forum > Tundra Discussion > Tundra Wheels & Tires > Will it fit?
