Leveled with 35's - post em here! - Page 80 - TundraTalk.net - Toyota Tundra Discussion Forum
post #1186 of 1348 (permalink) Old 05-21-2017, 01:00 AM
Quoted: 5 Post(s)
Originally Posted by Brad07z06 View Post
Pic in Sig I will post more later!
very nice
TundraonFire is offline
post #1187 of 1348 (permalink) Old 05-21-2017, 01:02 AM
Quoted: 5 Post(s)
What's the offset on your rims?? Thanks
post #1188 of 1348 (permalink) Old 05-21-2017, 01:29 AM
Quoted: 5 Post(s)
Originally Posted by dylan View Post
well I guess I'm late, but figured I'd throw up a few pics of my truck.
LRO 3/1, tires are 35x12.50, rims are 20x8.5 +10mm.. modded front fender liners & body mount, haven't put skidplate back on yet since it really doesn't bother me.
Super helpful. Thank you for the details and pictures!!!
post #1189 of 1348 (permalink) Old 05-21-2017, 02:05 AM
Quoted: 5 Post(s)
Originally Posted by Madmaz163 View Post
Got rid of my lift and got what i really wanted
Total Chaos UCA, 2.5' Icon Coils (3" Lift), 325/65R/20 Pirelli ATR, 20x9 Fuel Boost Rims (+26 offset, 6" BS), and i modded the body mount
Attachment 9820
Attachment 9821
Attachment 9822
How much did those 2.5 coils cost?
post #1190 of 1348 (permalink) Old 05-21-2017, 09:49 PM
Quoted: 5 Post(s)
When you say you modified the body mount. What does that entail and what are the possible consequences??? Thanks!
post #1191 of 1348 (permalink) Old 05-21-2017, 09:53 PM
Quoted: 5 Post(s)
Originally Posted by NJMonster View Post
35 offset will be fine. I'm running +12 offset....
I will be running a 9 offset. Will body mounts need to be modified? What does that mean if so? what are the ramifications of that??
post #1192 of 1348 (permalink) Old 05-22-2017, 01:55 PM
Gdubz's Avatar
Quoted: 4 Post(s)
This might be a dumb question.
when someone says the rims are 20x8.5 +10mm
what's the +10mm mean?
thanks sorry for the dumb question.
Gdubz is offline
post #1193 of 1348 (permalink) Old 05-23-2017, 02:23 AM
Quoted: 15 Post(s)
@Gdubz the + or - followed by a number measured in millimeters is the wheel offset, or the distance (in millimeters) the center mounting ring of the wheel is offset from the centerline of the wheel. A negative offset means the center hub is closer to the inside of the wheel, pushing the entire wheel out of the fender more (more aggressive), while a positive offset means the hub is closer to the outside face of the wheel, leaving you with a more tucked in look. Factory wheels come stock at +60mm and are flush with the fender. Anything closer to 0 or in the negative numbers from that original +60 is going to give your tire/wheel package a more aggressive look (sticking further out from wheel wells/fenders).
Malone/LYCAN NorCal
2016 Tundra TRD Pro
Toyo Open Country R/T 35/12.50R17 // Method Race Wheels Double Standard 17x8.5+0mm // UnderCover Ridgelander // Ekstrom Design Shims/+3" Shackles
LYCANoffroad is offline
The Following 4 Users Say Thank You to LYCANoffroad For This Useful Post:
Gdubz (05-23-2017), Jcadet000 (07-07-2017), rippster (05-24-2017), Sharkz (01-27-2018)
post #1194 of 1348 (permalink) Old 05-24-2017, 07:42 PM
Sonic Motor's Avatar
Quoted: 143 Post(s)
The body mount protrudes out a little in our fender wells, the chop is when someone cuts off the excess and rewelds a piece of metal closer to the actual mount and in turn creates more clearance for larger wheels and tires.
Possible consequences - Can't really think of many.
Full write up for better understanding here -
Fixing Tire Rub from Large Off-Road Tires: Off-Road.com
Zach @ Sonic Motor
Cell: 626-214-6695 (TEXT for price quotes
Shop: 626-363-9036
2008 Tundra (SLOW long travel build)
1973 Cadillac Coupe Deville
1973 Oldsmobile Cutlass 442
Sonic Motor is offline
The Following 2 Users Say Thank You to Sonic Motor For This Useful Post:
GMD1337 (07-27-2017), TundraonFire (05-24-2017)
post #1195 of 1348 (permalink) Old 05-24-2017, 10:30 PM
TrooperTKSR5's Avatar
Quoted: 82 Post(s)
I did the BMC. Only concern I have is rust. We painted it, but it's difficult to get paint coverage on the interior. I might go back in eventually and see how it's doing, clean, sand a little to rough the surface, prime, and recoat with more Rustoleum semi-gloss protective enamel. Otherwise, I don't see it causing any structural issues.
Let me know if there's a better rattle-can option.
2016 Super (Storm Trooper) White TRD Off-Road
ToyTec 3" kit up front, Coachbuilder 2" Shackles, TRD Rear Sway Bar, White Knuckle Off-Road Sliders, Driver Side Grab Handle, 35x12.50R18 Nitto Ridge Grapplers, Method Roost Wheels, S&B Intake, etc.
- Thread for installing drivers side grab handle in Gen 3. Directions on page 2. SparksParts.com now sells the kit (see page 25). Best upgrade out there.
TrooperTKSR5 is offline
post #1196 of 1348 (permalink) Old 05-25-2017, 01:48 PM
Quoted: 143 Post(s)
You can spray the inside with Weld through primer also for added protection. Eastwood Self Etching Weld thru Primer @TrooperTKSR5
Zach @ Sonic Motor
Shop: 626-363-9036
The Following User Says Thank You to Sonic Motor For This Useful Post:
TrooperTKSR5 (05-26-2017)
post #1197 of 1348 (permalink) Old 05-25-2017, 02:24 PM
Jesco's Avatar
Quoted: 7570 Post(s)
Almost 35's
Jesco is offline
The Following User Says Thank You to Jesco For This Useful Post:
AKTundra72 (10-31-2018)
post #1198 of 1348 (permalink) Old 05-25-2017, 04:25 PM
Quoted: 5 Post(s)
Originally Posted by Jesco View Post
Almost 35's
Very clean!!
CUSTOMWHEELS4U is offline
The Following User Says Thank You to CUSTOMWHEELS4U For This Useful Post:
Jesco (05-25-2017)
post #1199 of 1348 (permalink) Old 05-26-2017, 03:21 PM
Quoted: 82 Post(s)
Almost 35's
I think we talked about this almost a year ago, but what sort of numbers are you running on lift? Spindles, right? Also, are those the 18" Methods 308 Roosts? Is the backspacing on those sufficient, or are you running spacers as well? I've been planning to get those shoes on my rig this summer, wrapped in Ridge Grappler 35s. Great looking truck!
Questions, questions, questions, lol
post #1200 of 1348 (permalink) Old 05-26-2017, 03:30 PM
Jesco's Avatar
Yes 3.5" spindles. Wheels are 18 offset. No spacers needed.
Jesco is offline
