Got rubbing with 295/70/18, thinking of 305/65/18, Quick Qs - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 11 (permalink) Old 02-12-2018, 11:43 PM Thread Starter
phatjoe's Avatar
Quoted: 35 Post(s)
Hey,
I have a 3/1 set up, but unfortunately, I got rubbing with 295/70/18 tires. My wheels have a +20 offset. I guess I can live with the rubbing but the tire shop will exchange for a different size.
I was going to go with 305/65/18 tires. The tires will need to be ordered so they can't test fit. From what I've read, these tires are one inch shorter.
Anyone have good luck with a 3/1 lift and no rubbing with 305s? If not, I may play it safe and go with 275/70/18. A lot of affordable tires in 275.
Thanks
2019 Tundra TRD Pro Voodoo Blue
phatjoe is offline
post #2 of 11 (permalink) Old 02-13-2018, 01:40 AM
rruff's Avatar
Quoted: 471 Post(s)
Rubbing where? You are always going to need some plastic modding with that set up. Just fix it.
rruff is offline
post #3 of 11 (permalink) Old 02-13-2018, 01:52 AM Thread Starter
phatjoe's Avatar
Quoted: 35 Post(s)
Rubbing on the mud flap of the front wheel. Only rubs when wheel is fully turned. Even with mud flap removed, it still rubs. It annoys me enough to try a smaller tire size.
Interested to hear from folks who are running 305/65/18 tires. Thx
phatjoe is offline
post #4 of 11 (permalink) Old 02-13-2018, 02:06 AM
rruff's Avatar
Quoted: 471 Post(s)
Everyone's experience will be different because alignment effects the fore-aft position of the wheel. High caster will move it forward though (like yours), which is good.
In a few minutes you could move the front liner forward and get rid of the rub. If you want.
rruff is offline
post #5 of 11 (permalink) Old 02-13-2018, 02:17 AM Thread Starter
phatjoe's Avatar
Quoted: 35 Post(s)
Behind the front mud flap (Pic attached) is part of the metal frame. It's making contact with that when I cut the wheel. Just makes it feel junky so happily opting for a smaller tire.
File Type: jpg D42A7262-D4B6-4985-99F9-B6CA8CF9359F.jpg (149.8 KB, 64 views)
phatjoe is offline
post #6 of 11 (permalink) Old 02-13-2018, 11:05 AM
rruff's Avatar
Quoted: 471 Post(s)
Unless they really changed something for '18 (which I doubt) that is an easy fix. You can remove the bolts that hold the front of the liner in place (on the bottom), trim it a bit and move it forward, then drill new holes and reattach bolts.
rruff is offline
post #7 of 11 (permalink) Old 02-13-2018, 11:40 AM
renlo's Avatar
Quoted: 7 Post(s)
I test fitted 295/70/18 and also had rubbing with a 3" lift. It rubbed on the front wheel liner and the rear mud flap. Also tried on 305/65/18 and they rubbed too. Ended up going with a 285/70/18. I did end up pushing the wheel liner forward another inch and would like to try on the 295/70's again.
2016 Tundra Platinum CM
renlo is offline
post #8 of 11 (permalink) Old 02-13-2018, 02:07 PM Thread Starter
phatjoe's Avatar
Quoted: 35 Post(s)
I ended up purchasing the Wildpeak AT3W tires in 275/70/18. I got them for $158 a piece, which is a great price. I've had them before and they are a great performing tire.
phatjoe is offline
post #9 of 11 (permalink) Old 02-13-2018, 09:36 PM
Fttam's Avatar
Quoted: 123 Post(s)
It's a ten minute fix, tops.
Fttam is offline
post #10 of 11 (permalink) Old 04-12-2019, 10:11 AM
Quoted: 3 Post(s)
I am also looking to put 305/65r18 bfg ko2 on stock rims. It is hard to find direct answers and I've searched for weeks. I have 1.25" spidertrax spacers and a LRO 3/1 level. What kind of rubbing will I get where? I don't mind taking off the front(front) small mud flap and pushing the liner up and redrilling the holes for that. What about the skid plate and front(rear) mud flap? I have OEM style bushwhacker fender flares that slip over the front(rear) mud flap and I'm not sure if it would look right if I removed the mud flap with these flares. Also, the 3/1 leveling kit came with steering bump stops to limit the turning radius, so full lock(where most people seem to have rub) is slightly limited. I have a 2017 DC with TRD package. I would love to hear from someone with this exact setup.
Jason Pitner is offline
post #11 of 11 (permalink) Old 07-11-2019, 01:29 PM
iawhonda's Avatar
Wink 305/65r18
I have front 2" lift with 305/65R18.
Mods: Max caster, remove front and rear mud flap. Rubbed front plastic w/turned in reverse only.
Installed Coachbuilder front bumper shim kit, never rubs under any conditions.
iawhonda is offline
