Recommended Tire and Wheel Size? - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 12 (permalink) Old 07-31-2017, 04:24 PM Thread Starter
Quoted: 27 Post(s)
Hey everyone, I just purchased some 5100s and coachbuilder shims and +3 shackles. I will be setting the 5100s on the middle setting. I have searched some threads here and had some questions. I want to have the wheels and tires ready to go so I can get them put on the same time.
1. What is the largest Tire size I could go with for 18 and 20 inch wheels?
2. Is there a recommended offset or certain amount of backspacking needed if I want my tires to stick past my fenders .5 - 1 inch?
3. Any pics with anyone with a similar set up?
Thanks again!
phil217 is offline
post #2 of 12 (permalink) Old 07-31-2017, 11:40 PM
Turiha's Avatar
Quoted: 3 Post(s)
Thanks again!
I'm in the same boat as you, getting the fox 2.5 next week to level the truck, will be using the stock 18" wheels and would prefer bfg all terrains, sizes available are 285/65 18 or 305/65 18.
Any suggestions?
Turiha is offline
post #3 of 12 (permalink) Old 08-02-2017, 12:00 AM
rruff's Avatar
Quoted: 473 Post(s)
Are you cool with removing and trimming plastic, and doing the BMC? Then you can fit 37x12.5s. https://www.tundratalk.net/forums/tun...4x4-trd-5.html
And I'd like to pause for a moment of **** YOU PHOTO BUCKET!!!! Because all @KevinK 's pics are down.
Offset of +25 to +35mm is advised to minimize clearance issues. 12.5" tires will stick out a little.
rruff is offline
The Following User Says Thank You to rruff For This Useful Post:
phil217 (08-03-2017)
post #4 of 12 (permalink) Old 08-03-2017, 12:13 PM Thread Starter
Quoted: 27 Post(s)
Thanks Ruff! I dont mind removing plastic or trimming. I would prefer not too. Not sure if I want to go as big as what you are saying...
phil217 is offline
post #5 of 12 (permalink) Old 08-03-2017, 12:35 PM
rruff's Avatar
Quoted: 473 Post(s)
It's easy: https://www.tundratalk.net/forums/tun...clearence.html
Get 9" wide rims with +25, +35mm offset, and tires up to 35x12.5, and you shouldn't need to cut the body mount (it's steel).
If you are offroading much at all I'd get 18s, otherwise 20s are fine on road. This is a great site for checking what tires are available:https://tiresize.com/tiresizes/35-inch-tires/
rruff is offline
post #6 of 12 (permalink) Old 08-03-2017, 12:41 PM Thread Starter
Quoted: 27 Post(s)
Sweet. Thanks rruff! I plan on getting Fuel Hostage 18s or 20s. I am leaning towards the BFG KAO2.
phil217 is offline
The Following User Says Thank You to phil217 For This Useful Post:
pgarrido1233 (03-26-2018)
post #7 of 12 (permalink) Old 08-03-2017, 12:45 PM Thread Starter
Quoted: 27 Post(s)
How about backspacing?
phil217 is offline
post #8 of 12 (permalink) Old 08-03-2017, 12:48 PM
CritTRDpro's Avatar
Quoted: 44 Post(s)
My shims and shackles are going on today. Just added some 295/70/18 Toyo AT2's with +20 fuel vectors. I think it looks perfect. 34in tire and its not too wide. +20 gives the truck a nice stance, not too aggressive but definitely noticeable. Tomorrow I'll have pics with shims and +3's installed
16 TRD PRO CM
CritTRDpro is offline
The Following User Says Thank You to CritTRDpro For This Useful Post:
post #9 of 12 (permalink) Old 08-03-2017, 12:50 PM Thread Starter
Quoted: 27 Post(s)
Thanks!
phil217 is offline
post #10 of 12 (permalink) Old 08-03-2017, 12:57 PM
rruff's Avatar
Quoted: 473 Post(s)
Backspacing is defined by width and offset, it isn't independent.
rruff is offline
post #11 of 12 (permalink) Old 08-03-2017, 07:06 PM
smac619's Avatar
Quoted: 41 Post(s)
I would love to see pics. I have the 6112/5160 set up and looking to add 2 shims each side and the Toytec shackles in back. I have Camburg UCA's sitting on the shelf. I am looking at putting 305/55R20 Nitto Ridge Grappler's on. Not sure of the rims yet but leaning towards the Rockstar 2 with some custom painting. I figure the stance will be similar.
2015 DC SR5 TRD Super white
San Diego Tundra Club
Lifted Tundra Club (LTC) Member #78
Bilstein 6112s & 5160s w/ 2 CB Shims | Fuel Stroke 612 Wheels | Nitto Ridge Grappler 295/70/R18 | Stealth Step Boards | Toytec Lift Shackles | TRD Sway Bar | BAK Industries Revolver X2 | JBL Audio Amp | Kenwood Front & Back Speakers | LEDs Interior & Exterior | Husky X-Act Contours front & rear | TRD Shift knob
smac619 is offline
post #12 of 12 (permalink) Old 08-08-2017, 10:41 AM Thread Starter
Quoted: 27 Post(s)
Any pics???
phil217 is offline
