All wheel and tire pics here! - Page 124 - TundraTalk.net - Toyota Tundra Discussion Forum
jr3volution
post #1846 of 2005 (permalink) Old 01-07-2018, 08:51 PM
Chucksmith07's Avatar
Quoted: 84 Post(s)
Originally Posted by bswright View Post
Looks good! Leveling kit?
Yes 3-1 with ready lift. With 5100 in the rear. I am running 275/60/r20. Wish I would have went with your size tire.
Sent from my SM-G920V using Tapatalk
Chucksmith07 is offline
The Following User Says Thank You to Chucksmith07 For This Useful Post:
bswright (01-07-2018)
post #1847 of 2005 (permalink) Old 01-11-2018, 10:28 PM
mattpowe's Avatar
Quoted: 8 Post(s)
Originally Posted by BuggyMasters View Post
Just got mne done. This is wih ReadyLift 69-5475 4" SST lift. Dealer installed. Wheels are DropStar 645MB 20x9 with a +18 offset. Tires are Nitto Terra Grappler 295-60R20
I know this is an old post from you but do you have any rubbing issues? And do you still have the same set of tires?
mattpowe is offline
post #1848 of 2005 (permalink) Old 01-12-2018, 11:13 AM
Quoted: 13 Post(s)
Method Grid 18x9 +18
285/70 Nitto Ridge Grappler
Stock Suspension. Stay tuned....upgrades to come
1prerun is offline
post #1849 of 2005 (permalink) Old 01-12-2018, 12:39 PM
Ccla's Avatar
Quoted: 145 Post(s)
Dirty Sevens. (37x12.5x20's)
2016 CM SR5 Black on Black on Black, Black Diamondback Bed Cover
Maxtrac Spindles, Bilstein 5100s Top setting Front, Zone +3" Shocks rear
2 CoachBuilder Shims per side, CoachBuilder carrier bearing drop kit
TRD Pro Grill with 30" Light Bar behind it
37x12.5x20 RidgeGrapplers Spidertrax 1.25" wheel spacers
Spyder Black headlights, Rigid Midnight Fogs
Fab Fours Vengeance Rear Bumper with LED Bars
Morimoto Switchbacks, Reverse LEDs
Ccla is offline
post #1850 of 2005 (permalink) Old 01-14-2018, 01:39 PM
Lound's Avatar
BFG 275/60R20 KO2 Fuel Vapors +35
Lound is offline
The Following User Says Thank You to Lound For This Useful Post:
maybe (01-16-2018)
post #1851 of 2005 (permalink) Old 01-16-2018, 06:50 AM
maybe's Avatar
Quoted: 33 Post(s)
Looks really good. Thanks for posting a pic. Those are the exact same wheels that I am getting.
2014 1794 CM, Bilstein 6112's top setting, 1 CB shim per side, 5160's rear with +3 CB shackles, Zone upper control arms, 1.25 Bora wheel spacers, Stock wheels, Nitto Ridge Grapplers 295/60/20, AMP Research steps.
maybe is offline
post #1852 of 2005 (permalink) Old 01-17-2018, 02:45 PM
La-Motor's Avatar
Quoted: 5 Post(s)
Just completed...285/65-18 Hercules Terra Trac AT II's on 18x9 Method NV's+25 Offset with Bilstein 5100s on top setting. Only removed the front flaps. Loving it so far.
La-Motor is offline
post #1853 of 2005 (permalink) Old 01-17-2018, 09:42 PM
Quoted: 4 Post(s)
Hope you are still on here. Iím looking to do a Boss 3 inch lift with rear 1.5 shackles with Fuel Contra 20x9 +20. I was looking at the exact same tires. How much trimming did you have to do? do They still rub?
pgarrido1233 is offline
post #1854 of 2005 (permalink) Old 01-17-2018, 10:04 PM
Quoted: 4 Post(s)
Originally Posted by Jsquared_25 View Post
Just had OME 614's, Coachbuilder +3 shackles, LR UCA's and 20x9 +20 fuel Mavericks with 295/60/20 trail grapplers all installed Friday.
Any rubbing or major trimming needed? Looking at a similar wheel, same size and offset with the same tires on a Boss 3 inch lift
post #1855 of 2005 (permalink) Old 01-18-2018, 12:16 PM
Cachedh's Avatar
Quoted: 4 Post(s)
Just installed some Method 17's with a custom color and some General Grabber x3 (35's).
Cachedh is offline
post #1856 of 2005 (permalink) Old 01-18-2018, 02:41 PM
Quoted: 4 Post(s)
Originally Posted by FenixMike View Post
Thanks! I will have to look at the receipt later for offset, I have a tire guy ive been using for 10 years and he just takes care of everything for me. I want to say 20mm offset, but don't quote me on it. Tires are 295/60/20
Any Mods to the wheel well needed to avoid rubbing. Iím looking at the same size tires with 20x9 fuel Contras +20 with a 3 in Boss lift. Trying to see if they will fit without major rubbing or mods.
post #1857 of 2005 (permalink) Old 01-18-2018, 10:30 PM
Quoted: 4 Post(s)
Originally Posted by T Miller View Post
Tires are 285/65/20 BFG AT. I had these tires on the factory wheels and didn't rub. With the +20 offset I had some minor rubbing on plastic but after a little trimming the rub is gone. Here are a few more pics after installing. I can take more later today if you would like to see a different view.
Do you have a lift on it?
post #1858 of 2005 (permalink) Old 01-19-2018, 08:25 AM
Quoted: 37 Post(s)
I had at least 1/4 inch everywhere, but your results may vary. The dealer did the install and did pull the front wheel liners forward a bit, so I couldn't say what a completely factory setup would do.
FenixMike is offline
post #1859 of 2005 (permalink) Old 01-22-2018, 05:57 PM
Originally Posted by Tha Waterboy View Post
35's on stock TSS wheels. I have a rough country 3/1 level kit with 1.5" supreme suspension wheel spacers and 35's Atturo Trail Blade M/T's tires. Removed the both mud flapps, i have very minor rubbing only when steering wheel is at full turn while backing up into my driveway. Also have the go rhino 2.0 sports bar.
Looks awesome bro, yours has the look I like. Big lifts doesnít seem to affect the right tire, truck body ratio.
"When lion skin is too small, it can be covered with fox"
Iceman0305 is offline
post #1860 of 2005 (permalink) Old 01-25-2018, 03:47 PM
Punisher22's Avatar
Quoted: 3 Post(s)
35x12.50R17 Toyo R/T's on Method Standard
35" Toyo R/t's on 17" Method Standards.
FOX 2.5 w/ remote resi, Coachbuilder +3 shackles, Body Mount Chop, and Bushwacker Extend-A-Fender flares.
2015 Platinum 4x4 - super white
Platinum Member #68
TRD supercharger, FOX 2.5 w/ resi, Coachbuilder +3 shackles, 35" Toyo R/T's on 17" Method Standards, Bushwacker Extand-A-Fender flares, Expedition One bumpers w/ Baja Designs lights & Superwinch Talon 12.5SR, Custom Skid Plates, 46 gallon Transfer Flow tank, AMP steps & ESP storage box.
Punisher22 is offline
The Following 2 Users Say Thank You to Punisher22 For This Useful Post:
Ben_iv (03-10-2018), Crimsoncountry (01-25-2018)
