Anyone Running 305/65/18 on Stock TRD Pro Wheels? - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 96 (permalink) Old 07-07-2016, 12:00 PM Thread Starter
Rynomac11's Avatar
I've searched through the forums looking for 305/65s on the stock TRD Pro set up but haven't found anyone as of yet. Any help is appreciated. Thanks!
Rynomac11 is offline
post #2 of 96 (permalink) Old 07-07-2016, 02:26 PM
Quoted: 17 Post(s)
I am running that size the BFG KO2's on those rims
Royr is offline
post #3 of 96 (permalink) Old 07-07-2016, 02:28 PM
Quoted: 234 Post(s)
Can you post a picture?
08 Double Cab, 4.7L, 4x4
275/70/18 Nitto Ridge Grapplers
18x9 Vision Warriors
2" MotoFab Leveling kit
Flowmaster Super 50 Series Dual In/Dual Out
parker44 is offline
post #4 of 96 (permalink) Old 07-07-2016, 02:38 PM
Quoted: 17 Post(s)
Pic of 2016 with 305 65 18 bfg ko2 tires on Ted rims
Royr is offline
The Following 2 Users Say Thank You to Royr For This Useful Post:
kingkabong (07-21-2016), lilgsx (11-16-2016)
post #5 of 96 (permalink) Old 07-07-2016, 09:42 PM
Quoted: 21 Post(s)
I'm running that size also. Perfect fitment IMO. No rubs, no mods
& the tires are flush/ poke w/ the fenders.
'16 Pro CM MGM TRD SC #1 ....It can be done...
TRD Pro Tundra Club #65
Supra Dr is offline
The Following User Says Thank You to Supra Dr For This Useful Post:
tlpru (08-18-2016)
post #6 of 96 (permalink) Old 07-07-2016, 10:21 PM Thread Starter
Rynomac11's Avatar
Thanks! Do you guys have any photos from the front and rear? Thanks again for the help
post #7 of 96 (permalink) Old 07-08-2016, 12:32 AM
Quoted: 17 Post(s)
And another issue - the speedometer is spot on accurate with this setup 2016 Crew Cab 1794 edition Tundra - no correction needed.
Royr is offline
The Following User Says Thank You to Royr For This Useful Post:
Snaggle (07-10-2017)
post #8 of 96 (permalink) Old 08-18-2016, 10:03 AM
tlpru's Avatar
Quoted: 14 Post(s)
I'm trying to decide between
295-70-18 which has limited tire selection
275-70-18 slightly bigger than stock
305-65-18 little bigger than 275 (but wider)
my understanding all 3 have NO RUBBING ISSUES
any thoughts
tlpru is offline
The Following User Says Thank You to tlpru For This Useful Post:
mallard75 (02-14-2017)
post #9 of 96 (permalink) Old 08-18-2016, 11:24 AM
FrankieJoe14's Avatar
Quoted: 36 Post(s)
You will need to remove the front mud flap for 295's
Also may need to do a little persuasion with a hair dryer - some people do and some people don't.
2016 TRD PRO CM Quicksand
TRD Rear Sway Bar
Bak Revolver X2
BFG KO2 275/70 R18
FrankieJoe14 is offline
post #10 of 96 (permalink) Old 08-18-2016, 12:37 PM
Over the LINE's Avatar
Quoted: 18 Post(s)
I'm looking at 295/65/18 Duratracs. According to specs I find they are 1" taller and 1/2" wider than stock 275/65/18. The revs per mile are off by about 3% so the spedo will be very close.
Over the LINE is offline
post #11 of 96 (permalink) Old 08-18-2016, 12:55 PM
xtyfighterx's Avatar
Quoted: 314 Post(s)
295 70 18 here check my build out link is below I had them with stock wheels and now with aftermarket. Buddy is running 305 65s no problems either just small trimming
|Blacked out| |Color matched| |Fox 2.5 resi coilovers| |Fox 2.0 resi shocks| |Coachbuilder shims| |Method grid wheels| |295 70 18 trail grapplers| |Pro grill| |32in light bar| |Weathertechs| |TRD rear sway bar| |D2s retrofit| |Relentless bed bars/cargo spare tire setup| |smittybillt rtt| |ARB 1250 awning||Led bulb swap|
Black TC #391
MY BUILD
xtyfighterx is offline
The Following User Says Thank You to xtyfighterx For This Useful Post:
Über Drunk (10-12-2016)
post #12 of 96 (permalink) Old 08-18-2016, 03:23 PM
Muleycrazy13's Avatar
Quoted: 272 Post(s)
Seems like most who run the 295/70r18 are having to do the hypertech speedometer calibration which costs some bucks to purchase
2015 Toyota Tundra SR5 TRD 4x4 Crewmax
Toyota spray in bed liner/ Undercover Flex/ 30" LED Lightbar/ Osram Nightbreaker Headlight Bulbs/ LED interior from GTR lighting/ Bilstein 6112 top setting/5160s/ Toytec shackles on middle setting with poly bushings/ Carrier bearing drop/ Front diff drop/ 275/70R18 BFG KO2's/ 18x9 Fuel Mavericks +20 offset/ 1A Auto Tow Mirrors/ Husky Xact fronts/ Weathertech rear/ NFAB steps/ Tekonsha Prodigy Trailer brake Controller
2010 Toyota Camry SE
AZ Tundra Club #102
Muleycrazy13 is offline
post #13 of 96 (permalink) Old 08-18-2016, 03:41 PM
Quoted: 314 Post(s)
Think my speedo is off 2mph I wanna say with 295s
Black TC #391
MY BUILD
post #14 of 96 (permalink) Old 08-18-2016, 04:02 PM
Gene3x's Avatar
Quoted: 173 Post(s)
With a 3 inch left the 295's would not rub would they? I don't want to remove the mudflaps.
Black 2015 1794 w/ SuperCharger, BA Muffler, Nitro 4.88 & Auburn gears, Pop N Lock, TRD sway bar, Alcan Springs, TRD Pro shocks, Backup Camera & Satellite mod switches, Locker Down Console Safe, Cattleman Grill Guard, TRD Skid Plate, Adjustable Rhino Rack, Undercover Flex cover, MS8 processor, JL 700/5 Amp, Tech 12 volt Sub Box w/ JL10's, A118 Dash Cam,
Previous truck.... 08 Crewmax SR5 Texas Edition
Gene3x is offline
post #15 of 96 (permalink) Old 08-18-2016, 04:20 PM
Quoted: 314 Post(s)
It would rub a little. No need to remove them heat up the area where they rub with a hair dryer and reform it
Black TC #391
MY BUILD
  TundraTalk.net - Toyota Tundra Discussion Forum > Tundra Discussion > Tundra TRD Pro
