Towing Travel Trailer gets harder 2 hours into the trip - Page 2 - TundraTalk.net - Toyota Tundra Discussion Forum
post #16 of 18 (permalink) Old 02-24-2019, 12:00 AM Thread Starter
Quoted: 28 Post(s)
Thanks for the help everyone!
I'm going to check the wheels & brakes on the trailer to see if there's some issues there before we go out again next month.
Sam Talbot is offline
post #17 of 18 (permalink) Old 02-25-2019, 11:27 AM
Aaron713's Avatar
Quoted: 21 Post(s)
I just pulled a travel trailer (31 feet, from ball to back bumper, 12ft tall, 5000lbs) from SLC to LV (450ish mi) and I noticed the same thing around 3 to 3 1/2 hours. Truck just doesnt want to get into 5th at 65, when it had been acting normal for 200 miles. Mine is a '18 Platinum, on stock wheels and tires. Even with 400lbs of people, 230 of fuel and another possible 500lbs of assorted nonsense, we're well within specs. And it acts like it for a long time. Until it doesn't anymore.
I sort of shrugged it off as heat soak related; maybe something with a transmission temp parameter that limits the upshift from 4th, since the torque converter only locks up in 5th and 6th gear. But then I found a piece of info in the AB60E and F transmission documentation that says "lock up operation is performed when the 4th gear is held during the AI-SHIFT control or the cruise control". Maybe that's the same for the A750s.... I was using the radar cruise for nearly all of the trip, basically unless heading down a long hill towards a curve. So next time, I'll turn off cruise when the truck seems to be working harder as an investigation of more symptoms. I gotta say though, except for the noise, the truck was rolling along just fine at 4000rpm in 4th, up and down hills, into or with wind. I am also very thankful for my traveling companions: Bose QuietComfort 35 II headphones. A miracle of technology.
Aaron713 is offline
The Following User Says Thank You to Aaron713 For This Useful Post:
Sam Talbot (02-25-2019)
post #18 of 18 (permalink) Old 02-25-2019, 01:12 PM Thread Starter
Quoted: 28 Post(s)
Thanks for this info - you have the same setup as I do, and likely traveling the same roads (I was heading south on 15 till I took highway 6 towards capitol reef.)
I'll have to try turning off the cruise if it happens again and see what happens.
Thanks!
