Question: Thule Xsporter with Bed Rails - Page 2 - TundraTalk.net - Toyota Tundra Discussion Forum
post #16 of 22 (permalink) Old 04-15-2015, 10:39 PM
TRDPRO1's Avatar
Quoted: 36 Post(s)
Originally Posted by Dirte' View Post
I just bought a like new condition 422XT on craigslist. The reason I bought the older model was to get the XK2 adapter to fit with my Tundra. Tired of waiting for Thule to have one for the 500XT. I do have a question.... How tight were your XK2 adapters sliding into the 422XT? I just received a set that were so tight that you would have to hammer them in. I called Thule and they thought they may be machined wrong. I'm waiting for another set to arrive this week.
One was so tight that I had to use a rubber mallet and the other 3 moved freely.
TRDPRO1 is offline
The Following User Says Thank You to TRDPRO1 For This Useful Post:
Dirte' (04-16-2015)
post #17 of 22 (permalink) Old 04-15-2015, 10:43 PM
TRDPRO1's Avatar
Quoted: 36 Post(s)
Originally Posted by Macross510 View Post
So i may have found a way to make this work. After looking further I noticed the Tacoma adapters fit but can get high enough to latch on to the base. I noticed the thing stopping it is the middle piece that goes in the the bed rail. So i went ahead and cut the piece off and were able to place them in. Its still tight but its probably better than loose. I didnt have enough time to finish the install and hopefully i don't run into anything. I am attaching image of what i did. Please let me if this is some how a bad idea. Thank you.
Image 1: shows it can't fit.
Image 2: what i shaved off the clamps.
Image 3: fitting tight after i shave it.
Image 4: comparing shaved clamp to unshaved.
looks good to me.
TRDPRO1 is offline
post #18 of 22 (permalink) Old 04-15-2015, 10:48 PM
TRDPRO1's Avatar
Quoted: 36 Post(s)
Finally got the whole system on. Part of the bed liner gets in the way of the clamps. But I was able to find an area that will find my Thule cargo. Also the little metal pads that you put on as you tight the screws are just exact, not much room. Was able to use the lock system. Including some pics.
interested in the locking system, wonder if they make them for XK2s.
TRDPRO1 is offline
post #19 of 22 (permalink) Old 04-15-2015, 11:19 PM
Dirte''s Avatar
Quoted: 128 Post(s)
I must have it's brother..... One tight and three are fine.
That's right... It's an 14' with a foot print gas pedal and a Hurst speed shifter with a pool-ball grip.
Build Log Here:
14' Tundra 1794 Save The Chrome Club #46
02' Tundra Limited (Gone)
Dirte' is offline
post #20 of 22 (permalink) Old 04-16-2015, 02:59 PM
Quoted: 5 Post(s)
I don't think the XK2 has a locking system. Not by Thule anyways. It requires its own bolt. So 2 total.
2015 White Limited CM 4x4 TRD
Macross510 is offline
post #21 of 22 (permalink) Old 09-03-2015, 11:37 AM
Very nice. Looks factory.
Related question: Has anyone cut the vertical supports to make them shorter? I need to cut the two rear vertical supports so they will fit properly around my side mounted toolbox.
mtnracer is offline
post #22 of 22 (permalink) Old 05-27-2016, 02:53 PM
Quoted: 3 Post(s)
2016 didn't work
I've got the newer Thule xsporter pro, bought about 5 years ago and a new 2016 TRD pro tundra. After reading this thought it would work on my application. Picked up the XK3 Thule "Tacoma" adapter. Followed the instructions and ground down the edge. Didn't even come close to working on my rig, both with and without the rubber pad under the rack (between the bed rail and rack). Just threw away $50.
Sucks...
Hoss79 is offline
