3/1 lift, Vibration issue - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 14 (permalink) Old 08-12-2018, 02:32 PM Thread Starter
Quoted: 52 Post(s)
Angry SOLVED: 3/1 lift, Vibration issue
2016 CM 1794, I am still getting the annoying steering wheel vibration at 60-80 mph. I have tried both carrier bearing and diff drop. My tires are new and I have done wheel alignment recently. I suspect that I need to upgrade the OEM UCA. Would that be a good thing to try?
Flex Fuel 2016 | Edition 1794 CM | TRD CAI | Valve body Mod | LT ARH | | 20" Method Roost wheels
2012 rcsb | TRD SC | 18" 41 series Procomp wheels| Valve body Mod | JBA Long tube headers | Airaid CAI | 2/4" SOSperformance LK | Caltracs TB
Last edited by riskydude; 09-16-2018 at 08:13 AM. Reason: please add "SOLVED" on the title
riskydude is offline
post #2 of 14 (permalink) Old 08-12-2018, 08:07 PM
Brian20's Avatar
Quoted: 156 Post(s)
Did you try a road force balance? Also, are your wheels torqued correctly?
Brian20 is offline
post #3 of 14 (permalink) Old 08-12-2018, 08:56 PM
jdiesel_us's Avatar
Quoted: 43 Post(s)
With a 3" lift on the front you are pushing the factory uca. Do you know what your alignment specs were?
Sent from my SAMSUNG-SM-G930A using Tapatalk
2016 SR5 TRD CM bone stock still under warranty
jdiesel_us is offline
post #4 of 14 (permalink) Old 08-12-2018, 11:19 PM
Quoted: 29 Post(s)
What tires? Some of the new knock off brands are bad for balancing. My first guess would be a re-balance.
GEOTundra is offline
post #5 of 14 (permalink) Old 08-13-2018, 08:44 AM Thread Starter
Quoted: 52 Post(s)
yes I did, and yes I think so.
I am not very sure about the figures but they were all green. I will get get either Total Chaos if I could save some $ or most probably SPC UCA. I just want to confirm whether this will solve my problem first or not.
Michelin 275/65R20 on 308 Methods. I will try that before purchasing an upgraded UCAs and share the numbers for review.
post #6 of 14 (permalink) Old 08-14-2018, 12:22 PM
Tundra234's Avatar
Quoted: 272 Post(s)
Tundras are very sensitive to vibrations. I had that issue and chased it for over a year. It ended up being bad tires...Michelin LTS MX2's with 15,000 miles on them. Shouldn't have anything to do with the leveling kit as long as everything is tight and alignment is correct.
2013 DC 4.6, Flowmaster exhaust, Undercover, V-leds exterior, LED interior, LED strips in door pockets/footwells, Pioneer AVH-P5100 head unit, Alpine Typr R 8" subs, Oracle halos/power indicator, BHLM, Fuel maverick 18x9 +1 offset w/ Nitto Ridge Grappler 285/70/18, Aries bull bar/N-Fab Podium step bars, V-Leds Micro headlights, Rigid fog lights, GrillCraft grill with Rigid LEDs, ReadyLift 3/2 SST, ScanGuage II, Switched backup cam, Vleds 6K LED strips in bed, G-Tek SABM, Clazzio seat covers, G-Tek Fab sill protectors, Line-X bumpers, TRD front/rear sway bars, Pedal Commander, Hornblasters
Tundra234 is offline
post #7 of 14 (permalink) Old 08-14-2018, 12:34 PM
Brian20's Avatar
Quoted: 156 Post(s)
Those LTX MS Defenders were going to be my next tire after the LTX AT2 wear out. Was it just a balance issue?
Brian20 is offline
post #8 of 14 (permalink) Old 08-18-2018, 10:17 AM
Quoted: 66 Post(s)
That vibration is almost certainly in your tires. Alignment settings will not cause a vibration like you are describing. The new UCAs aren't a bad idea, but they won't fix this issue. If you still have your stock wheels/tires, bolt them on. I'd bet the vibration is gone. I'm in the same boat. I've had my wheels/tires balanced by America's tire 12 times in 25k miles. Still shakes from 80 and up.
mgh20180 is offline
post #9 of 14 (permalink) Old 08-19-2018, 11:49 PM
rhineholio's Avatar
Quoted: 28 Post(s)
I had the same problem turned out to be my lower ball joints. I bought new Dorman LCAs and they failed in about 100 miles. I also have the tallest springs OME makes which have a bunch of pre load and push down on the lower control arm.
'10 Rock Warrior
TRD Supercharger
TRD dual exhaust
OME 613
Coachbuilder 3" Shackles
BudBuilt 3/16" skid plates and beefy rock sliders
Road Armor bumper w/ pre-runner hoop, PIAAs and Warn XD9000 winch
rhineholio is offline
post #10 of 14 (permalink) Old 08-27-2018, 05:10 PM Thread Starter
Quoted: 52 Post(s)
I have installed Zone UCA, have to admit that it makes a day and night’s difference even without the alingment. The vibration is minimal now, I think with Socal’s specs for alignment, I will get the issue resolved completely . So those with lifted trucks, UCA upgrade is deffo an investment to consider.
post #11 of 14 (permalink) Old 08-29-2018, 10:39 AM
PMG
PMG's Avatar
Quoted: 142 Post(s)
Swap the front and rears and see if the vibration stays...
PMG is offline
post #12 of 14 (permalink) Old 08-30-2018, 12:14 AM Thread Starter
Quoted: 52 Post(s)
I think I was wrong . . Upgrading UCA is surely a good thing for lifted trucks but it did not solve my vibration.
I have tried diff drop, CB drop, wheels alignment and most recently upgrading the OEM UCA with Zone offroad.
post #13 of 14 (permalink) Old 08-30-2018, 12:16 AM Thread Starter
Quoted: 52 Post(s)
I will try that today, I anticipate that one of my 20" methods has a slight bent.
post #14 of 14 (permalink) Old 09-04-2018, 06:06 AM Thread Starter
Quoted: 52 Post(s)
Ok guys, so I spent almost $ 700 or more in trying things out. Today, I stopped by a wheels shop and asked them to check the tires balance. It was obvious that they were out of balance. I will get the road force balancing, this should surely cure the issue.
