6112 and the difference between the highest and 2nd highest ride height - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 16 (permalink) Old 04-19-2018, 07:07 PM Thread Starter
Quoted: 11 Post(s)
I currently have them at the highest setting and I think it is too firm and bumpy on the highway. Is it worth it to lower it? Will that help with the concrete bed bounce on the highway?
2009 5.7 4x4 double cab Rock Warrior
Bilstein 6112 set at 2.5 lift/level
Bilstein 5160 rears
305 BFG All terrain
Moreal Speakers Audison AMP 2 10 inch JBL Subs
Corsa exhaust with k and n drop in
Viper alarm with electric start
johnnyquad17 is offline
post #2 of 16 (permalink) Old 04-21-2018, 09:21 AM
GR8White's Avatar
Quoted: 342 Post(s)
Changing the front probably won’t affect the rear that much but if you haven’t already, you should look into doing the @Coachbuilder1 shackles and poly bushings as I hear that helps a lot
2012 RW DC. ADS Coilovers and Piggybacks, MCM Fab UCA's, CB +3’s, 305/70/17 Nitto Terra Grappler G2's, full audio system
GR8White is offline
post #3 of 16 (permalink) Old 04-23-2018, 12:41 PM Thread Starter
Quoted: 11 Post(s)
Thank you I will. Would that affect the 5160's in the back? Would I need to do anything with them? Would my ride height be level with the +1 shackles. I have a 09 Rock Warrior DC 4x4 . Thanks
John
Bilstein 5160 rears
305 BFG All terrain
post #4 of 16 (permalink) Old 04-23-2018, 01:27 PM
Toytime's Avatar
I agree! I had toytec shackles on the lowest setting and poly bushing in my 16 with 5100 and helped alot with the bed bounce on the hwy. Especially noticed it towing trailer.
Toytime is offline
post #5 of 16 (permalink) Old 04-23-2018, 09:37 PM
GR8White's Avatar
Quoted: 342 Post(s)
John
It won’t affect the 5160’s in the rear but what I would suggest would be to do the front first and get it all aligned properly. Take a measurement from floor to top of wheel well in the back, then place a jack under your trailer hitch and go up in increments of how the CB shackles are made. 5/8”, 1.25”, 1.75” and see what you like the look of. Everyone’s truck is different so I can’t exactly tell you what will level it out but with 6112’s at a so called 2.5” and +1’s in the back, I would say you should end up with about an inch of rake
GR8White is offline
post #6 of 16 (permalink) Old 05-09-2018, 08:30 PM Thread Starter
Quoted: 11 Post(s)
I did add the coachbuilder1 shackles and poly bushings and that helped a ton. Thank you for the advice!
Bilstein 5160 rears
305 BFG All terrain
post #7 of 16 (permalink) Old 05-09-2018, 08:34 PM
GR8White's Avatar
Quoted: 342 Post(s)
Good to hear. What size shackles did you go with?
GR8White is offline
post #8 of 16 (permalink) Old 05-10-2018, 01:11 PM Thread Starter
Quoted: 11 Post(s)
I went with the +3 and did add 2 shims to the drivers side and 1 to the passengers side. Looks better and rides better. I also did drop the air down from 46 to 35 psi. I have open country tires that helped as well. I still get some bed bounce but it is much better.
Bilstein 5160 rears
305 BFG All terrain
post #9 of 16 (permalink) Old 05-10-2018, 01:15 PM
GR8White's Avatar
Quoted: 342 Post(s)
Oh wow. That thing isn’t probably sitting pretty high now. I too reduced my tire pressure awhile ago down to the 35-38 range and that helped a lot. And I think the tires wear better as well. Not sure why Toyota has the door sticker at 46psi. Oddly enough my bosses RW sticker says 40psi. Did you do aftermarket upper arms too?
GR8White is offline
post #10 of 16 (permalink) Old 05-10-2018, 04:15 PM Thread Starter
Quoted: 11 Post(s)
No after market upper arms she aligned perfectly.
Bilstein 5160 rears
305 BFG All terrain
post #11 of 16 (permalink) Old 05-10-2018, 04:19 PM
GR8White's Avatar
Quoted: 342 Post(s)
Interesting
GR8White is offline
post #12 of 16 (permalink) Old 05-10-2018, 04:31 PM Thread Starter
Quoted: 11 Post(s)
Interesting
Why do you say that? You don't really need arms until you go higher than 4 inches. I didn't go over that.
Bilstein 5160 rears
305 BFG All terrain
post #13 of 16 (permalink) Old 05-10-2018, 04:32 PM
GR8White's Avatar
Quoted: 342 Post(s)
Interesting
General rule of thumb is that they’re suggested over 2.5” and needed at 3”. What do your alignment numbers look like? Caster must be real low
GR8White is offline
post #14 of 16 (permalink) Old 05-10-2018, 06:30 PM Thread Starter
Quoted: 11 Post(s)
I talked to David from Ekstrom Design and he said it was fine to run this way and the alignment was spot on for everything including the caster. I'm very pleased with the set up. Thanks again!
Bilstein 5160 rears
305 BFG All terrain
post #15 of 16 (permalink) Old 06-16-2018, 09:58 AM
The 2 shims and 1 on the passenger side with front suspension at highest setting? I'm researching before I do my suspension project.
deequin is offline
