Best/easiest leveling option (for a brand new Tundra owner) - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 32 (permalink) Old 01-03-2018, 03:59 PM Thread Starter
dano277's Avatar
Quoted: 9 Post(s)
I'm brand new to the Tundra community and especially Tundratalk so bear with me!
I just bought a 2018 Tundra limited double cab and I'm looking into different leveling options. I'm definitely wanting to go with either the Toytec/Eibach Complete Front Coilovers or the Bilstein 5100s. I've been reading plenty of forums on here but which do you guys think would be an easier install and the best quality? Do I also need to buy new UCAs with the 3 inch level?
I'm pretty jacked to be a part of the Tundra community, you guys seem pretty legit based off what I've been reading so far!
~Dan
dano277 is offline
post #2 of 32 (permalink) Old 01-03-2018, 04:02 PM
Ccla's Avatar
Quoted: 145 Post(s)
Easier to install would be the complete coilovers if they come assembled. You shouldnt need UCAs if you only use them without any shims / spacers etc
2016 CM SR5 Black on Black on Black, Black Diamondback Bed Cover
Maxtrac Spindles, Bilstein 5100s Top setting Front, Zone +3" Shocks rear
2 CoachBuilder Shims per side, CoachBuilder carrier bearing drop kit
TRD Pro Grill with 30" Light Bar behind it
37x12.5x20 RidgeGrapplers Spidertrax 1.25" wheel spacers
Spyder Black headlights, Rigid Midnight Fogs
Fab Fours Vengeance Rear Bumper with LED Bars
Morimoto Switchbacks, Reverse LEDs
Ccla is offline
The Following User Says Thank You to Ccla For This Useful Post:
dano277 (01-03-2018)
post #3 of 32 (permalink) Old 01-03-2018, 05:17 PM
Quoted: 66 Post(s)
keep in mind just leveling the front tends to be 2-2.5" on the fronts only, while a 3" front lift is usually paired with a 1" rear lift
the 5100s on top setting will be about 2.5" up front, not sure about the toytec coils
Current:
2018 1794 4x4 TRD Magnetic Gray/Brown - Exterior LEDs, ProZ Profold Tonneau, Pioneer 4200NEX, Toytec/Radflo 2.5 front coilovers, BOSS 2.0 resi rear shocks, Toytec rear shackles, Ambit RS02 18x9+0, Nitto Ridge Grappler 285/70/18, Cab Mount Chop, RCI engine skid
2011 BMW M3 Sedan Alpine White/Black Cloth
Former: 2008 SR5 5.7 DC 4x2 Super White/Black "Dog Hair Magnet" Cloth
quiksi is offline
The Following User Says Thank You to quiksi For This Useful Post:
dano277 (01-05-2018)
post #4 of 32 (permalink) Old 01-03-2018, 09:12 PM
Fttam's Avatar
Quoted: 123 Post(s)
Theres not much difference in ease of install between coilovers and the 5100's honestly.
What you want to spend (5100's are excellent for the price, coilovers cost more) and how you plan to use it (mall crawler or serious off reading) should dictate which way you go.
I went with 5100's and rear CB shackles, 295/70's on stock TRD wheels and my truck looks great, rides and drives fantastic on the street and works well for me off road (I'm not rock crawling or jumping the truck, but it does tons of beach driving, muddy farm roads and muddy/rocky/rutted hunting trails no problem).
Good luck!
Fttam is offline
The Following 4 Users Say Thank You to Fttam For This Useful Post:
BamaTundra* (02-19-2018), dano277 (01-05-2018), jhl1963 (02-24-2018), Powertechn2 (01-14-2018)
post #5 of 32 (permalink) Old 01-03-2018, 11:28 PM
Quoted: 49 Post(s)
Ease of install would be coilovers IMO. That's just because I'm not gonna use an autozone spring compressor for 5100s. But I went with 5100s and CB shims on each side to get 3" in the front. Did toytec shackles in the rear for 1.5" there
MattFL850 is offline
The Following 2 Users Say Thank You to MattFL850 For This Useful Post:
dano277 (01-05-2018), Powertechn2 (01-14-2018)
post #6 of 32 (permalink) Old 01-04-2018, 11:15 AM Thread Starter
dano277's Avatar
Quoted: 9 Post(s)
Did you need UCAs with the shims? I'm leaning more towards doing a 1" in the back based off of what everyone is saying!
dano277 is offline
post #7 of 32 (permalink) Old 01-04-2018, 11:22 AM Thread Starter
dano277's Avatar
Quoted: 9 Post(s)
Fttam, do you have any pics of your setup??? Here's my stock truck. went with the double cab because I saved $4,000. Loving it so far!
dano277 is offline
post #8 of 32 (permalink) Old 01-04-2018, 11:24 AM
Ccla's Avatar
Quoted: 145 Post(s)
3" shouldnt need UCA's over 3" yes. I got a within spec alignment with 5100's and 2 CB shims on the top setting. But its barely in spec. I'm adding UCAs to try and improve it
Ccla is offline
post #9 of 32 (permalink) Old 01-04-2018, 03:36 PM
phm14's Avatar
Quoted: 11 Post(s)
I Installed Bilstein 6112s on my '18. Highest setting gave a perfect 2.5" level, and the spring/2.5" damper are perfectly matched for a great on/off road compromise ride. I've bought may last set of Toytechs after experiencing poor product and service. I received the wrong spring rate for my '04 Tacoma, so the springs were bowing in, nearly rubbing the shock body, as well as riding really harsh to to the excessive preload needed to set a 2.5" lift. The owner was not only clueless (or pretended to be), but unpleasant to deal with. Finally had to sort it out myself. If that weren't enough, Toytech has since stopped using Bilstein dampers, and now uses a no doubt cheaper and less reliable in house "Boss" branded damper. Given the decades of excellent trouble free performance I've had with Bilstein suspension on both on and off-road trucks and motorcycles, there's absolutely no reason to go Toytect since Bilstein is now offering their own coilovers. You can even find some vendors that will assemble the COs for you if you prefer not to use a spring compressor. I installed these COs myself, as always. Trying to shortcut by not un-bolting the lower ball joint and sway bar frame brackets/end links was a waste of time for me.
Toyota 4x4 owner (x4), since 1993, continuously
2018 Tundra SR5 4x4 5.7 DC, Blazing Blue Pearl, Bilstein 6112 coilovers, TRD exhaust, Method Roost with Nitto Ridge Grapplers
'16 Lexus RCF
'15 4Runner Trail
First Toyota: 1974 Celica, bought 1980.
[SIGPIC]
phm14 is offline
The Following User Says Thank You to phm14 For This Useful Post:
post #10 of 32 (permalink) Old 01-04-2018, 03:41 PM
Quoted: 49 Post(s)
Stock uca still. And I did 1.5" because a lot of people say the tundra likes a certain amount of rake to keep the computer happy. Idk if it does or doesn't, but I like the way it turned out either way
post #11 of 32 (permalink) Old 01-04-2018, 04:04 PM Thread Starter
dano277's Avatar
Quoted: 9 Post(s)
Thanks phm, I think I'm going to go with the 6112s in the front and 5100s in the back. Based off what everyone's said they are the better of the two plus the 6112s already come with coils. Tundratalk is the titties, its great having all you guys with Tundra experience for questions and advice!
dano277 is offline
post #12 of 32 (permalink) Old 01-04-2018, 04:09 PM Thread Starter
dano277's Avatar
Quoted: 9 Post(s)
Have any of you guys ordered parts from Wheeler's Off Road?
dano277 is offline
post #13 of 32 (permalink) Old 01-04-2018, 04:11 PM
Consider the Firestone Ride-Rite Kit. levels, increases carrying capacity, and best of all makes the truck ride like a luxury car when empty.
KE7ZAG is offline
post #14 of 32 (permalink) Old 01-04-2018, 04:12 PM
Shelbie67's Avatar
Quoted: 53 Post(s)
If you tow, be careful not to completely level the truck. If you do the tongue weight can alter your steering control.
2018 Toyota Tundra Platinum Crewman in Magnetic Gray Metallic.
Mods: coming soon to a forum near you....
Shelbie67 is offline
post #15 of 32 (permalink) Old 01-04-2018, 04:52 PM
2Tall's Avatar
Quoted: 4 Post(s)
I purchased my 6112s pre-assembled from Wheeler’s and had zero issues. They even throw in a little goodie bag of candy!
As far as suspension setup, I went 6112 on the top setting and Toytec shackles at 1”. Overall very happy with the setup for a daily driver. I probably could’ve had slightly better system but at a much higher cost, ie full blow coil overs like king or fox.
2016 SR5 DC 5.7 4x4 MGM
Bilstein 6112/5160 Camburg BJ uppers Method Double Standards/BFG KO2 305/65-18
2Tall is offline
The Following 2 Users Say Thank You to 2Tall For This Useful Post:
