TRD Off-Road suspension upgrade help... - Page 2 - TundraTalk.net - Toyota Tundra Discussion Forum
post #16 of 35 (permalink) Old 10-30-2017, 04:02 PM Thread Starter
Quoted: 9 Post(s)
@Mickleford do you happen to have a pic of your rig you can share?
SC_HANK is offline
post #17 of 35 (permalink) Old 10-30-2017, 05:31 PM
Mickleford's Avatar
Quoted: 63 Post(s)
Bilstein 5100ís all around.
Ride height is set on the middle setting which provides around 1.5Ē lift in the front.
The rearís are not adjustable so itís at factory height.
The middle setting is not really enough to be called ďleveledĒ and still provides a touch of rake.
Stock tires still. Hopefully thatíll change soon!
2016 CM SR5 | Silver Sky Tundra Club Member #248
Mickleford is offline
The Following User Says Thank You to Mickleford For This Useful Post:
SC_HANK (10-31-2017)
post #18 of 35 (permalink) Old 10-30-2017, 06:55 PM
silverhack's Avatar
Quoted: 89 Post(s)
I’m considering the 5100s for the front for now. Down the road, if I want to put the 6112s up front I could move the 5100s to the rear.
EDIT: For anyone else reading this later, see the next post.
2018 Limited CrewMax 4x4 🔥 INFERNO 🔥 :: TRD Faux ::
silverhack is offline
post #19 of 35 (permalink) Old 10-30-2017, 07:27 PM
Mickleford's Avatar
Quoted: 63 Post(s)
Originally Posted by silverhack View Post
Iím considering the 5100s for the front for now. Down the road, if I want to put the 6112s up front I could move the 5100s to the rear.
Nope.
The fronts are totally different from the rears.
silverhack (10-30-2017)
post #20 of 35 (permalink) Old 10-30-2017, 07:30 PM
rruff's Avatar
Quoted: 469 Post(s)
SO now I am up in the air between 5100's on the front OR spacer lift (due to cost, or lack thereof)... Any other suggestions or recommendations?
Definitely 5100s. I'd say use the middle setting and leave the rear alone.
If you want 35s on stock rims, 295/70s (which are ~34.3") or 285/75s (which are ~34.8") are your best bet. Shop for good deals.
rruff is offline
The Following User Says Thank You to rruff For This Useful Post:
post #21 of 35 (permalink) Old 10-31-2017, 09:23 AM Thread Starter
Quoted: 9 Post(s)
Looks great @Mickleford
SC_HANK is offline
The Following User Says Thank You to SC_HANK For This Useful Post:
Mickleford (10-31-2017)
post #22 of 35 (permalink) Old 10-31-2017, 09:27 AM Thread Starter
Quoted: 9 Post(s)
@rruff thanks for the info, tires you would recommend for a "road princess" or whatever folks want to call it on here?
SC_HANK is offline
post #23 of 35 (permalink) Old 10-31-2017, 02:28 PM Thread Starter
Quoted: 9 Post(s)
@Mickleford what tires will you be going for?
SC_HANK is offline
post #24 of 35 (permalink) Old 10-31-2017, 02:43 PM
Mickleford's Avatar
Quoted: 63 Post(s)
Either 285/70/18 or 295/70/18. Still havenít decided...
post #25 of 35 (permalink) Old 10-31-2017, 02:48 PM
rruff's Avatar
Quoted: 469 Post(s)
in 295/70r18, Michelin LTX M/S... Excellent performance, longevity, and MPG. In the big sizes they are pretty cheap compared to competitors.
Looks like you just missed the Discount Tire Direct ebay sale though. They might still be your best bet.
https://tiresize.com/tires/Michelin/...-295-70R18.htm
rruff is offline
post #26 of 35 (permalink) Old 10-31-2017, 03:07 PM Thread Starter
Quoted: 9 Post(s)
[quote=rruff;8970314]in 295/70r18, Michelin LTX M/S... Excellent performance, longevity, and MPG. In the big sizes they are pretty cheap compared to competitors.
Yeah I have had those for many years- was hoping to get something a bit more aggressive...
SC_HANK is offline
post #27 of 35 (permalink) Old 10-31-2017, 04:43 PM
rruff's Avatar
Quoted: 469 Post(s)
The Michelins will be better in every way on the road, but if you don't mind more noise and more gas $$$, here are other options.
https://tiresize.com/tiresizes/295-70R18.htm
Generally the more "aggressive" they look the more on road compromises you'll make.
rruff is offline
post #28 of 35 (permalink) Old 10-31-2017, 07:39 PM
Mickleford's Avatar
Quoted: 63 Post(s)
Oh ya forgot to specify tire brand/type
I'd either looking at BFG KO2 (not available in 285/70/18) or Nitto Ridge Grappler.
post #29 of 35 (permalink) Old 11-01-2017, 11:22 AM Thread Starter
Quoted: 9 Post(s)
@Mickleford @rruff it's too bad they don't make the BFG KO2 in 285/70/18 as I am trying to avoid trimming... I assume 295/70/18 would need substantial trimming?
SC_HANK is offline
post #30 of 35 (permalink) Old 11-01-2017, 01:29 PM
rruff's Avatar
Quoted: 469 Post(s)
No, not with stock wheels and offset. You may need to remove mudflaps, and I'm pretty sure you'll need to bend the skid plate in the front. That's like 10 sec with some channel locks.
I don't think you'll be sorry about going big, but you may be sorry if you get gnarly off road tires for driving on the street. At least I'd be sorry.
rruff is offline
