Upper control arm recommendation - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 30 (permalink) Old 05-09-2017, 10:51 AM Thread Starter
mckayam1's Avatar
Quoted: 14 Post(s)
Looking for recommendation for a quality upper control arm for icon stage 2 kit, with a top setting of 3 inch lift. Possibly one shim as well.
Sent from my SM-G920R4 using Tapatalk
mckayam1 is offline
post #2 of 30 (permalink) Old 05-09-2017, 05:03 PM
Trailmoose's Avatar
Quoted: 647 Post(s)
Know a lot of people here like the total chaos upper control arms. Might want to check them out.
2017 Tundra TRD Pro CM Cement, BD Squadron Pro Fogs, Rago Fab Hidden LED Bar, All-Pro Sliders and Bakflip MX4.
Trailmoose is offline
The Following User Says Thank You to Trailmoose For This Useful Post:
mckayam1 (05-09-2017)
post #3 of 30 (permalink) Old 05-13-2017, 10:21 AM
GR8White's Avatar
Quoted: 342 Post(s)
Why not run an icon arm with their new delta joint?
2012 RW DC. ADS Coilovers and Piggybacks, MCM Fab UCA's, CB +3’s, 305/70/17 Nitto Terra Grappler G2's, full audio system
GR8White is offline
The Following User Says Thank You to GR8White For This Useful Post:
mckayam1 (06-12-2017)
post #4 of 30 (permalink) Old 05-13-2017, 05:21 PM Thread Starter
mckayam1's Avatar
Quoted: 14 Post(s)
Didn't know about the delta joint
mckayam1 is offline
The Following User Says Thank You to mckayam1 For This Useful Post:
Trailmoose (05-13-2017)
post #5 of 30 (permalink) Old 05-13-2017, 05:24 PM
GR8White's Avatar
Quoted: 342 Post(s)
I'd check that out or total chaos like someone suggested or the MCM fab arms that I have. The @M C M arms are basically modeled after the total chaos and use the same quality FK uniball
GR8White is offline
The Following 2 Users Say Thank You to GR8White For This Useful Post:
mckayam1 (06-12-2017), Trailmoose (05-13-2017)
post #6 of 30 (permalink) Old 05-13-2017, 07:05 PM
Tommy Tran's Avatar
Quoted: 44 Post(s)
Icon lift, Icon UCA. Done
2016 SSM DC SR5UGP TRD 5.7 4x4
Icon/ Baja Designs/ Second Skin Audio/ NVX
AZ Tundra Club #111
Tommy Tran is offline
The Following User Says Thank You to Tommy Tran For This Useful Post:
post #7 of 30 (permalink) Old 05-13-2017, 07:37 PM
toymdt's Avatar
Quoted: 94 Post(s)
Never, ever under any circumstance get ones off of Ebay. Don't ask why I know it's too embarrassing.
Toyota Master Diagnostic Technician 20+ years
"I know a thing or two cuz I've seen a thing or two."
toymdt is offline
The Following 2 Users Say Thank You to toymdt For This Useful Post:
mckayam1 (06-12-2017), Über Drunk (05-14-2017)
post #8 of 30 (permalink) Old 05-13-2017, 10:44 PM
dissipator16's Avatar
Quoted: 183 Post(s)
Total Chaos
Keep your lettuce crisp, and your hair low and loose.
dissipator16 is offline
The Following User Says Thank You to dissipator16 For This Useful Post:
post #9 of 30 (permalink) Old 05-14-2017, 03:25 PM
Victor_361's Avatar
Quoted: 17 Post(s)
Just get a SPC Light Racing UCA. Less expensive than an Icon UCA if money is a concern.
2016 Silver Sky DC 4x2
CST 3.5 Spindles/5100's middle setting
35x12.50 Toyo AT2 20x9 Fuel Mavericks +20
Color Matched handles and mirror caps
NFab's textured black steps
CB +2's, CB bushings, CB carrier bearing drop
Pro Grill, BHLM, 2 inch CST blocks
Victor_361 is offline
The Following User Says Thank You to Victor_361 For This Useful Post:
post #10 of 30 (permalink) Old 05-14-2017, 09:35 PM
Southern's Avatar
Quoted: 197 Post(s)
umm..sorry, but I gots to know..
I feel normal again!
Southern is offline
The Following 3 Users Say Thank You to Southern For This Useful Post:
Jarvis243 (05-14-2017), mckayam1 (06-12-2017), Über Drunk (05-14-2017)
post #11 of 30 (permalink) Old 05-14-2017, 09:47 PM
Quoted: 36 Post(s)
Yeah, story time.
Sent from my VS986 using Tapatalk
Jarvis243 is offline
The Following User Says Thank You to Jarvis243 For This Useful Post:
post #12 of 30 (permalink) Old 05-14-2017, 09:56 PM
Über Drunk's Avatar
Quoted: 3434 Post(s)
Well aint that a load of horse sheet.
Official Tri-State Member #4
Barcelona Red Tundra Club #10
2007 Silver Tundra SOLD
2011 Black Rock Warrior (Things and stuff installed) SOLD
2014 Barcelona Red Crew Max (Things and stuff installed) FOX
He who stands on toilet is high on pot.
Über Drunk is offline
The Following User Says Thank You to Über Drunk For This Useful Post:
post #13 of 30 (permalink) Old 05-14-2017, 11:11 PM
toymdt's Avatar
Quoted: 94 Post(s)
Originally Posted by Jarvis243 View Post
Yeah, story time.
Alright, basically in a moment of weakness I bought a set of very pretty looking arms from Ebay for $300 that were supposed to correct caster. These: 99-06 Tundra 2WD/4WD Silver Upper Control Arm For 2-4" Leveling Kit | eBay Well they are pretty but that's about it. They actually made the alignment worse and now I have to get a set of good ones like I should have done in the first place. Lesson learned.
toymdt is offline
Jarvis243 (05-15-2017), mckayam1 (06-12-2017)
post #14 of 30 (permalink) Old 05-14-2017, 11:29 PM
Quoted: 183 Post(s)
The lesson I learned is that everything you do on these trucks is an investment. The only thing that "saves money" is spending it up front on the good stuff to match your truck. You already spent thousands on a high quality machine, what difference does a few hundred make for something you use every day and should only ever buy once...
The Following 3 Users Say Thank You to dissipator16 For This Useful Post:
GR8White (05-15-2017), Jarvis243 (05-15-2017), mckayam1 (06-12-2017)
post #15 of 30 (permalink) Old 05-15-2017, 10:09 AM
Quoted: 19 Post(s)
this is what i did.
Andy9743 is offline
The Following User Says Thank You to Andy9743 For This Useful Post:
