The Coachbuilder Shackles on Pro - Page 2 - TundraTalk.net - Toyota Tundra Discussion Forum
post #16 of 36 (permalink) Old 01-29-2017, 01:17 PM
Newm's Avatar
Quoted: 92 Post(s)
Center of the fender would be great.... thank you sir.
Knowing the exact difference between the front and rear on your truck can give me a better visual for what I need to do.
Thanks again.
Newm is offline
post #17 of 36 (permalink) Old 01-29-2017, 10:24 PM
Cyoda44's Avatar
Quoted: 14 Post(s)
Subscribed.. I really need to do this!
2017 Tundra Pro
2015 Platinum Crew Max (traded)
Cyoda44 is offline
post #18 of 36 (permalink) Old 01-30-2017, 12:40 AM
crzy2bealive's Avatar
Quoted: 19 Post(s)
Originally Posted by zm1283 View Post
Is there a good ball joint press you can rent at one of the auto parts stores that will do what this one does? I don't really want to have to buy one unless I have to.
Or buy from harbor freight and return it lol
Sent from my SM-G920V using Tapatalk
crzy2bealive is offline
post #19 of 36 (permalink) Old 01-30-2017, 10:10 AM
ktharbour6's Avatar
Quoted: 249 Post(s)
Thanks again.
Ok, so I parked the truck in the same spot to measure before and after shackles install. I can't guarantee that the ground is completely level but it's pretty darn close. Keep in mind this is on a 2016 Pro CM and the 1st measurements were done after installation of 275/70/18 Nitto Ridge Grapplers.
After CB +2 shackles only my measurements are as follows: Front Left 39.25"... Front Right 39.5"... Rear Left 40 5/8"... Rear Right 40 5/8".
I hope this helps. If you need anything else feel free to ask.
2016 Toyota Tundra TRD Pro CM MGM.
IG: @kt_harb.protundra
ktharbour6 is offline
The Following User Says Thank You to ktharbour6 For This Useful Post:
Newm (01-30-2017)
post #20 of 36 (permalink) Old 02-02-2017, 05:44 PM
ktharbour6's Avatar
Quoted: 249 Post(s)
Here is a good view to see the take created by CB +2 shackles.
SeanScott (09-20-2017)
post #21 of 36 (permalink) Old 03-03-2017, 05:23 PM
Quoted: 40 Post(s)
Is anyone with +3s having issues at the dealership whenever getting the oil changed? The leafs hit the exhaust at full drop... I just put them on, wondering how it is going when it's at the dealer and placed on a lift.
Sent from my SM-G935P using Tapatalk
xxxshiftxxx is offline
post #22 of 36 (permalink) Old 03-03-2017, 05:29 PM
Banned
Lee's rig's Avatar
Quoted: 353 Post(s)
I'm sure they have something.
You just need a socket type of piece on the one end that will allow the bushing to pop out into.
Like in my video.
Saw on another thread some one made one out of p.v.c parts from home shitpo
Lee's rig is offline
The Following User Says Thank You to Lee's rig For This Useful Post:
blue87fj60 (03-15-2017)
post #23 of 36 (permalink) Old 03-03-2017, 08:06 PM
Quoted: 22 Post(s)
Here is mine setup with the +3 shackles and 4 shims up front (2each side)
About an inch of rake
holsterpro is offline
post #24 of 36 (permalink) Old 03-13-2017, 12:12 PM
Quoted: 9 Post(s)
[QUOTE=holsterpro;8359298]Here is mine setup with the +3 shackles and 4 shims up front (2each side)
This looks so good!!!!
What size tires are those? 295/70-18?
I wound up going with 295/65-18 and I'm worried that they will look tiny after the +3 and shims up front...
2017 TRD PRO CM Cement
Rigid 30" SR-Midnight edition bumper light bar
Duratrac 295/65-18
PP Engineering Rock Sliders
D2S Retrofitted Headlights
Baja Designs Squadron Pro Fogs
CEMENT is offline
post #25 of 36 (permalink) Old 03-13-2017, 09:44 PM
derp's Avatar
Quoted: 173 Post(s)
Spare tire clearance?
I read somewhere that the Coachbuilder shackles cut into spare tire space. Is there anyone with +2 shackles and 295/70-18 that can comment on if the spare fits without rub by the shackles?
derp
2014 Tundra CrewMax SR5 4x4
SR5 Upgrade and TRD Offroad
Silver Sky over Graphite
DeMello Offroad Rock Crushers
derp is offline
post #26 of 36 (permalink) Old 03-15-2017, 08:28 AM
ktharbour6's Avatar
Quoted: 249 Post(s)
derp
Not sure about 295... but here is how it looks with stock spare tire.
derp (03-15-2017)
post #27 of 36 (permalink) Old 03-15-2017, 08:21 PM
derp's Avatar
Quoted: 173 Post(s)
Thanks for the pic. Hard to tell from that angle, but doesn't look like there's much room to spare? About how much gap between tire and shackle? Any sign of the shackle hitting/rubbing on the tire?
derp
derp is offline
post #28 of 36 (permalink) Old 03-15-2017, 08:27 PM
ktharbour6's Avatar
Quoted: 249 Post(s)
derp
I'll try and remember to climb under the truck tomorrow and check. And try to get a better photo. That one was taken during install.
derp (03-15-2017)
post #29 of 36 (permalink) Old 03-18-2017, 04:34 PM
ktharbour6's Avatar
Quoted: 249 Post(s)
@derp . Here are photos with +2 and the stock spare tire. 1st photo is drivers side which has hardly any room and 2nd photo is passenger side. Hope this helps some.
derp (03-18-2017)
post #30 of 36 (permalink) Old 03-18-2017, 08:05 PM
derp's Avatar
Quoted: 173 Post(s)
Thanks for the pics - easily worth a 1000 words.
[EDIT]
You have 275/70-18s per an above post?
[/EDIT]
derp
derp is offline
