Blistein 6112 w/no Coils - Page 3 - TundraTalk.net - Toyota Tundra Discussion Forum
post #31 of 47 (permalink) Old 12-01-2016, 12:09 PM
Quoted: 1213 Post(s)
Nah. We probably could figure out some kind of springs to use. But 6112 valving and spring rate is pretty dialed in. I would run what you brung.
dirtydeeds is offline
The Following User Says Thank You to dirtydeeds For This Useful Post:
rruff (12-04-2016)
post #32 of 47 (permalink) Old 12-04-2016, 11:25 PM
rruff's Avatar
Quoted: 469 Post(s)
My truck is going to be loaded though, with I'm guessing ~500 lb over stock weight on the front. I'd like 2" of lift. I figured a heavier spring would make sense. What do you think? With the stock spring I'd need a coil spacer for extra preload, and I suspect the coils would bottom out before I hit the bumpers.
rruff is offline
post #33 of 47 (permalink) Old 12-07-2016, 01:46 AM
Maybe consider a set of kings? 700lb springs. Or OME 613?
Or, we could try a set of one springs on 6112's. but then we would have a bastard set of 6112 springs laying around.
rruff (12-07-2016)
post #34 of 47 (permalink) Old 12-07-2016, 07:39 PM
rruff's Avatar
Quoted: 469 Post(s)
That makes sense, thanks for your reply.
rruff is offline
post #35 of 47 (permalink) Old 12-26-2016, 11:15 AM
Quoted: 3 Post(s)
Originally Posted by kstateskier View Post
600lbs. OEM is 700lbs
Would you happen to know if oem coils are different lengths (driver vs passenger)? I read that somewhere but can't confirm. Looking to either reuse oem coils or buy complete 6112's. Depending on either oem or 6112 coils being different lengths might change whether or not different clip settings having to be used to correct driver side lean
Tundraltdblck is offline
post #36 of 47 (permalink) Old 12-26-2016, 12:23 PM
kstateskier's Avatar
Quoted: 296 Post(s)
The OEM coils I pulled off my truck had the same exact part #s which would lend me to believe they were identical lengths. The new 6112 coils are identical so you can install either on drivers or passenger side. However there is a small small difference in height as it sits on a level surface.
2017 Tundra Crewmax Limited Weatherby Lake, MO
TRDPro Reservoir shocks Rear
TRD Stainless Dual Exhaust
kstateskier is offline
post #37 of 47 (permalink) Old 12-26-2016, 12:56 PM
Quoted: 3 Post(s)
I'm debating whether to shim, or just use different clip settings? Came across a 4Runner forum stating using one notch higher would correct driver side lean. Probably need to just wait to have a whole day of free time to experiment
post #38 of 47 (permalink) Old 12-26-2016, 01:04 PM
Making driver have one more notch than passenger or vice Versa will correct lean.
post #39 of 47 (permalink) Old 12-26-2016, 01:40 PM
Quoted: 3 Post(s)
What's the pros/cons of shimming besides lift height and springs having same compression? Does the shim allow easier alignment?
post #40 of 47 (permalink) Old 01-05-2018, 11:53 PM
Quoted: 17 Post(s)
Originally Posted by rruff View Post
I did some looking at it doesn't appear to be a standard spring. Standard Eibach go up to 3" ID, but the 6112 is ~3.3". Eibach has a 14" and 16" spring, but 6112 is ~15.25".
If you got a 700 lb 16" spring you'd get a lot of lift even in the lowest perch on the 6112. The 1" of lift that a 600 lb 15.25" spring gives you, plus an extra .75" of length, on top of a 100 lb higher rate. I wouldn't go that route unless you have a *lot* of extra weight in the front. There is no 650 lb spring or 15" spring unfortunately. 700 lb 14" (with a coil spacer?) or 600 lb 16" look like the best options, though with the later a coil spacer on the regular 6112 spring might work just as well.
Going to dig up this thread. I called wheelers yesterday, they recommended a 3" ID x 14" length 700lb rate spring for my 6112's, I'm not digging the idea of using shims on the top setting of the shock to preload the spring and maintain the lift. I'm wondering if I went with a 16" 700lb spring on the lowest shock setting will it work? If I have to toss a Deaver spring pack in the rear to bring it up I'm not adverse to that either, the bumper I put in the rear doesn't;t leave much room for gear in the bed without it sagging. I'm putting on a exp one front bumper that weighs in at ~150 and have plans for a winch.
2011 4.6L Double Cab 4x4
Nitro 4:88 gears, Auburn rear LSD, ARB Front Air Locker, Volant CAI, Borla Exhaust, Body Armor rear bumper, Expedition One front bumper, Method Standard 18" wheels, 35x12 Mickey Thompson Baja AT tires. Bilstein 5160 rear shocks, Bilstein 6112 front shocks.
VanDominator13 is online now
post #41 of 47 (permalink) Old 01-06-2018, 12:25 AM
rruff's Avatar
Quoted: 469 Post(s)
I don't think I'd take Wheeler's advice, unless they've actually done. Seems like a smaller diameter spring wouldn't fit right. Besides the length mismatch.
Do us all a favor and try something totally different!
AFAIK nobody is running the Ironman stuff on a Tundra. Lots of FJ guys use them though. The Pro front struts are fully rebuildable and have threaded collar adjustments. $590 for the struts and $160 for springs. https://ironman4x4america.com/truck/toyota/tundra/
https://www.tundratalk.net/forums/tun...hings-etc.html
rruff is offline
post #42 of 47 (permalink) Old 01-06-2018, 12:47 AM
Quoted: 17 Post(s)
As much as I'd love to swap out my entire suspension, it's just not in the economical future for me. But the Iron Man stuff looks like a great option, being rebuildable at that price point is awesome, but the leafs are too pricey, especially when I can just drive to Deaver and have them make me a new pack for a little less and avoid shipping costs.
Although I'm pretty sure Coachbuilder has done it or something similar. Wheelers is the only place I've talked to that has actually put those springs on a 6112. The 6112 is the same diameter (2.5) for the Tundra as it is for the Taco, thats why they recommended the 14" spring, because they know it works on the Taco shock. Basically just because the Bilstein spring is 3.3 it'll still work with a 3" ID spring, like all other 2.5' coilovers, I know there are guys who have swapped the springs in their 2.5 Icons with heavier Eibachs and had great results. I'm just debating on the choice of length.
post #43 of 47 (permalink) Old 01-06-2018, 01:29 AM
rruff's Avatar
Quoted: 469 Post(s)
You don't have to buy the Ironman leafs, BTW.... and shipping is free.
Seems like the smaller diameter spring wouldn't fit the perches correctly.
Also, if I understand correctly it's important to have valving that is designed for the spring rate. If the 6112s are still 600 lb (somebody said 650, maybe need to call Bilstein), then 700 lb is going to be a big difference. That's why OME and Ironman springs come in different lengths to get more height rather than spring rate. Maybe it isn't a big deal though...
Just for fun, lets say the Tundra with stock 6112s has ~4.5" of spring compression (4.5x600lb= 2700 lb) on the bottom clip. Spring goes from 15.25" long to 10.75". You are at .75" lift vs stock. A 700 lb spring will have the same load, so will compress 2700/700= 3.9". But it starts at 16" so 3.9" of compression leaves you at 12.1" compared to 10.75" with the stock 600 lb spring. So there is an added 1.35" at the strut, which translates to ~2.3" at the wheel. I used a 1.7 ratio there, is that about right Keith @dirtydeeds ? Combined with the .75" lift on the bottom clip compared to stock, you are at ~3" of lift at stock weight.
So I think the long spring will do what you want if my numbers are in the ballpark.
rruff is offline
post #44 of 47 (permalink) Old 01-06-2018, 01:06 PM
phm14's Avatar
Quoted: 11 Post(s)
For those that may not know, the "lean" is engineered into the suspension to compensate for road crown. The intent is to help the vehoicle track straight down the road, with less effort needed to keep the vehicle from wandering toward the edge of the road, and to provide a more level feel to occupants. I don't know of a practical reason to "correct" it. Seems most do it due to an obsession with vehicle stance. I did it myself until I learned the reason it is engineered into the suspension.
Toyota 4x4 owner (x4), since 1993, continuously
2018 Tundra SR5 4x4 5.7 DC, Blazing Blue Pearl, Bilstein 6112 coilovers, TRD exhaust, Method Roost with Nitto Ridge Grapplers
'16 Lexus RCF
'15 4Runner Trail
First Toyota: 1974 Celica, bought 1980.
[SIGPIC]
phm14 is offline
The Following User Says Thank You to phm14 For This Useful Post:
rruff (01-06-2018)
post #45 of 47 (permalink) Old 01-06-2018, 04:56 PM
Quoted: 17 Post(s)
That what I was thinking, I have the 6112's set on the top setting right now with a .25 shim to bring the lift up to 3". I think your math is correct, I just need to call Bilstein and find out about the valving, maybe they even have a 700lb spring that matches the dimensions of the 600 and I won't have to use a bastardized Eibach. We'll see.
