Bilstein adjustable front OME rear? - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 7 (permalink) Old 12-16-2015, 10:57 AM Thread Starter
Quoted: 8 Post(s)
I currently have OME 612 setup on my truck with a one inch block in the rear. I need to be lower for a parking garage. Can I remove the blocks on the rear and keep the OME rear shocks and switch the front out to Bilstein adjustable set on middle setting? I figure if I do this and drop from 295/70s to 275/70s I should gain some clearance right? If so how much clearance gained? I need to fit in a garage marked 6'8" with minimal risk. Trying to keep price down on switch too.
cch2a is offline
post #2 of 7 (permalink) Old 12-16-2015, 12:56 PM
Joshhtn's Avatar
Quoted: 285 Post(s)
Yep. You can do it.
How much clearance will depend on a few things...
~2008 4x4 Limited Crewmax TRD~
OME 614 Complete Lift w/ 1.5" AAL
Coachbuilder +3 Shackles
SPC/LR UCAs
18x9 Black Rhino Glamis +12
295/70/18 Trail Grapplers
50 Series Flowmaster
Wet Okole Seat Covers
Demello Hidden Winch Mount
Smittybilt X2O 12K Winch
Baja Designs Squadron-R Sport Lights
TonnoPro Hardfold
Joshhtn is offline
post #3 of 7 (permalink) Old 12-16-2015, 02:16 PM Thread Starter
Quoted: 8 Post(s)
Measuring from peak of truck to ground is ~79" with my OME 612 and 1" block and 295/70r18s. Surely I could pick up 2" of top clearance with the switch in suspension and tires right?
cch2a is offline
post #4 of 7 (permalink) Old 12-16-2015, 03:59 PM
chphilo's Avatar
Quoted: 636 Post(s)
You are being overly optimistic.
Bilstein 5100 at the highest setting is lower than OME 612 roughly by 1/2 inches. There's about 1.5 inch difference in diameter between 295/70/18 and 275/70/18, only half of which will go into the height difference of the truck. So you are looking at about 1 & 1/4 inch height difference between the two set-ups. If you go with stock tires (32 inches in diameter), your truck will sit about 1.75 inch lower than the current set-up.
Exactly how much lower do you need to go?
2010 Tundra, CM, 4x4, 5.7, TRD Off Road, Silver Sky Tundra Club #7, TWACC #100, RYRWDBTTBYCDI #7, Tri-State Club #21, Chrome Club #23, LTC #10
Toyota/TRD (Stepboards, Cat-Back, Intake, Hood Protector, Tow Mirrors), Pioneer (AVIC Z140BH & ND-BC5), Clazzio, Tint, Wheelskin, Line X (Extra/Color Match), ValuGard (Undercoat & Rust Inhibitor), Husky WeatherBeater, Westin Ult BB & Lights, Moto Metal 961, BW fender flares, BAKFlip F1, OME 614, LR UCA, UC SwingCases, Nitto Trail Grappler (295/70/18)
chphilo is offline
The Following User Says Thank You to chphilo For This Useful Post:
Wacked (12-17-2015)
post #5 of 7 (permalink) Old 12-16-2015, 04:04 PM Thread Starter
Quoted: 8 Post(s)
Parking garage is marked at 6'8" so right now sitting at 79" I have 1" of clearance. Need to go low enough to be safe. No speed bumps are in the garage. Also planning on running the 5100s on middle setting not highest.
cch2a is offline
The Following User Says Thank You to cch2a For This Useful Post:
Wacked (12-17-2015)
post #6 of 7 (permalink) Old 12-17-2015, 11:26 AM
Quoted: 1215 Post(s)
Subscribed in case there is anything I can say to help
dirtydeeds is offline
The Following User Says Thank You to dirtydeeds For This Useful Post:
Wacked (12-17-2015)
post #7 of 7 (permalink) Old 12-19-2015, 10:15 PM
proLUKE's Avatar
Quoted: 5 Post(s)
I would think that if your truck is 6'-7" and the garage is labeled at 6'-8", then you should be ok... although I understand your desire for more of a safety factor. It is possible someone could have installed some plumbing or other utilities after the 6'-8" clearance was certified...
I live in Houston, and in the free garage at the Galleria mall my antenna didn't hit the warning bar entering the garage, but did hit a few things in there. The antenna is a few inches above the roof. I was definitely nervous!
All the best
proLUKE is offline
