Any tips?? Deaver install planned for tomorrow... - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 3 (permalink) Old 12-09-2015, 07:02 PM Thread Starter
pc1p's Avatar
Quoted: 129 Post(s)
Anyone have any Tundra specific tips for installing leaf springs on Gen 2's??
New springs (K37's), u-bolts, shackles (Total Chaos), shackle hardware and brake-line relocation brackets.
I was told that it is a good idea to disconnect the ABS sensor and unbolt the brake line bracket before starting.
Anything else??? Thanks in advance...
| 5.7L | Gibson | K&N | Fox | Total Chaos UCA | Deaver K37 | TC Shackles | Power Stop | AO Armor 18x9 +10mm | BFG 305/65 KO2 |
pc1p is offline
post #2 of 3 (permalink) Old 12-19-2015, 10:44 AM
dissipator16's Avatar
Quoted: 183 Post(s)
i am sure you installed already but yeah do your brake line stuff first.... I never disconnected ABS but not a bad idea. I did it myself but a buddy would make moving those springs easier. lube up those bushing well and go to town!
Keep your lettuce crisp, and your hair low and loose.
dissipator16 is offline
post #3 of 3 (permalink) Old 12-19-2015, 11:45 AM Thread Starter
pc1p's Avatar
Quoted: 129 Post(s)
Got them already, but thanks for thinking of me
I just unscrewed the brake line bracket and ABS bracket to give some flex as a "Just in Case".
I did the driver's side myself - which was actually the more difficult side as it was the one with the frozen shackle pin. I had to unbolt the u-bolts, then front perch, then the rear shackle. Since the entire pack could move, BUT the ABS stuff was in the way, I had to carefully slide it over then twisted it to get it clear and out. Not bad, and I'm a bulky guy, but certainly two hands would have helped.
On the passenger side, my buddy wasn't called into work (a pilot's life!) and came over to help with the other side and rear brakes.
I wire-wheeled every bolt going back in, used new u-bolts torqued to factory spec (~77 ft lbs I think) and used synthetic bushing grease on all the pins and bushing ends. After driving about 300 miles, I retorqued all fasteners, and then used some white paint to mark them as torqued and to allow quick visual if they should move.
pc1p is offline
The Following User Says Thank You to pc1p For This Useful Post:
Über Drunk (12-28-2015)
