Transmission pan bolt stripped **help** - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 10 (permalink) Old 06-12-2019, 06:24 PM Thread Starter
Quoted: 5 Post(s)
Fellas! Looking for some input, a quick fix or if leaving it be will be fine. Iím going on a year long deployment and of course Iím having this issue right right before Iím about to leave my wide with the truck!
Dropped the trans pan because Iím swapping a valve body. Of course as Iíve ready everywhere some of the 10mm bolts snapped. No big deal, I pulled them out no problem except this one. It is sooo beyond rusted and seized In there. I soaked in PB blaster for 3 days spraying it about 4 times a day, it still wonít move.
Can I just throw the pan back up and it wonít be a big deal? Maybe around that area on the gasket use some actual blue or black gasket maker and let it ride? I donít have the time to take this into a shop for them to charge me an arm and leg.
Any advice would be amazing guys!
THANK YOU SO MUCH!
jetblack14316 is offline
post #2 of 10 (permalink) Old 06-12-2019, 10:16 PM
Quoted: 557 Post(s)
try putting some heat on it a few times.or find a buddy who can weld a nut on it.
restosud is offline
The Following User Says Thank You to restosud For This Useful Post:
Powertechn2 (06-13-2019)
post #3 of 10 (permalink) Old 06-13-2019, 05:16 AM Thread Starter
Quoted: 5 Post(s)
I was thinking of both options. I was worried with the pan up that welding a nut might cause damage to the cheap metal trans pan that is in this truck in the first place.
Thank you for the advice!
post #4 of 10 (permalink) Old 06-13-2019, 08:53 AM
Skip C's Avatar
ive had luck with drilling out the center. But when making the initial hole dont let it slip. I buy a piece of thin metal or a big washer will work to protect around the hole while drilling. Once its started its easy.
Skip C is offline
post #5 of 10 (permalink) Old 06-14-2019, 07:49 AM Thread Starter
Quoted: 5 Post(s)
Well the heat gun method worked. Thanks
The Following 3 Users Say Thank You to jetblack14316 For This Useful Post:
Johnjpa808 (06-15-2019), Powertechn2 (06-14-2019), riccnick (06-17-2019)
post #6 of 10 (permalink) Old 06-15-2019, 09:47 PM
Quoted: 10 Post(s)
Glad you got it out. My neighbor was going through the same problem just a few days ago
Johnjpa808 is offline
post #7 of 10 (permalink) Old 06-16-2019, 04:46 PM
Quoted: 3 Post(s)
Transmission pan bolt screw substitute
Those screws (in other places on other Toyotas)- I've removed by drilling the center and teasing out the threads. And cleaning up to the point that another identical screw will thread in. But it is a stunt. Shortcut is to drill out and use strong twist on a big screwdriver to install a short pan head screw w/ deep sharp threads and a big head w/ a wide slot.
dogsridewith is offline
post #8 of 10 (permalink) Old 06-17-2019, 11:07 AM
Quoted: 36 Post(s)
Best is weld a nut on it. Canít go wrong with that.
ďDonít overthink something simple people... ..:sigh:..Ē
tacopower is offline
post #9 of 10 (permalink) Old 06-17-2019, 01:34 PM
Quoted: 3 Post(s)
Isn't this a now a headless screw shaft stuck very tight in a casting? (Photo shows a sort of ghost image.)
Isn't the pan off? ("pan up?")
Weld a nut to what?
Those screws centers are soft enough to center drill by eye and hand drill w/ a sharp small drill. (Don't want to break off the drill in the screw.)
Edit: oops...didn't read thread back far enough to see you got it. Good job!
post #10 of 10 (permalink) Old 06-17-2019, 09:08 PM
Powertechn2's Avatar
Quoted: 1642 Post(s)
Yep, best way to repair is to drill/easy-out it. Or drill, then chip off the threads left and clean up.
It really sucks when an easy out breaks off in a broken bolt, that really really makes the day go to hell.
and you can call me Power.
Powertechn2 is offline
