14 Tundra 130k Blown head gasket - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 12 (permalink) Old 03-26-2019, 02:39 PM Thread Starter
Anyone experience a blown head gasket this early? Dealer maintained, towed 23' wake boat very occasionally.
Any quick fixes?
TIA
cbwtundra is offline
post #2 of 12 (permalink) Old 03-26-2019, 07:20 PM
ViktorG's Avatar
Quoted: 324 Post(s)
130K isn’t THAT early.
The only fix I know of is to remove the head and replace the gasket.
2010 RCSB ([email protected] on NOS) - AWD conversion, Pauter rods, JE 8.5:1 pistons, Ti int & SS exh valves, Ti retainers, 5 angle valve job, P&P heads, TRD SC w/ 50mm pulley, ASP crank pulley, 84mm TB, SABM, IPT VB, JBA LTs, Killer Chiller, 1.25 Gal IC tank, Frozenboost 101 HE, IKH-24 plugs, A1000 FP, 2"/4" Belltech drop, weight reduction, NOS
ViktorG is offline
RIjon (03-27-2019)
post #3 of 12 (permalink) Old 03-26-2019, 10:10 PM
Quoted: 599 Post(s)
Dealer diagnose?
What symptoms?
sundance is offline
post #4 of 12 (permalink) Old 03-26-2019, 10:26 PM Thread Starter
Originally Posted by sundance View Post
Dealer diagnose?
What symptoms?
Dealer diagnosed cyl # 8 misfire. Swapped some stuff around to isolate. Still throwing code.
post #5 of 12 (permalink) Old 03-27-2019, 01:06 AM
ViktorG's Avatar
Quoted: 324 Post(s)
How about a compression test and/or taking the valve cover off to look for a broken valve spring or rocker arm?
ViktorG is offline
The Following 3 Users Say Thank You to ViktorG For This Useful Post:
OldGuy43 (03-27-2019), Powertechn2 (03-27-2019), RIjon (03-27-2019)
post #6 of 12 (permalink) Old 03-27-2019, 10:38 AM
Quoted: 599 Post(s)
Exactly what I was thinking. Hard to believe someone would claim a head gasket without at least a compression test or pull the plug to check for cross-contamination.
sundance is offline
The Following 3 Users Say Thank You to sundance For This Useful Post:
Powertechn2 (03-27-2019), RIjon (03-27-2019), ViktorG (03-28-2019)
post #7 of 12 (permalink) Old 03-27-2019, 06:55 PM
Powertechn2's Avatar
Quoted: 1657 Post(s)
Leakdown test would be necessary otherwise they are just assuming. A compression test would dictate if a cylinder was losing pressure, but it could still be losing pressure due to a broken valve spring if the valve isn't holding closed. A leakdown would tell where the loss is, gasket, valve, etc...
and you can call me Power.
Powertechn2 is offline
The Following 2 Users Say Thank You to Powertechn2 For This Useful Post:
sundance (03-28-2019), ViktorG (03-28-2019)
post #8 of 12 (permalink) Old 03-27-2019, 11:01 PM
Quoted: 41 Post(s)
Head gasket failure is extremely difficult to diagnose until it gets so bad that the coolant level starts to quickly drop. I had a head gasket go at 67,000 miles and knew that there was a problem with the engine. I took it to 3 dealers and 2 independent garages and after spending $1400 no one could determine what was actually at fault. After another 15K miles the head gasket failed to the point where the engine was sucking up coolant and then it was easy to diagnose and fix the problem.
Calson is offline
post #9 of 12 (permalink) Old 03-28-2019, 08:03 AM
Quoted: 11 Post(s)
Originally Posted by Calson View Post
Head gasket failure is extremely difficult to diagnose until it gets so bad that the coolant level starts to quickly drop. ... After another 15K miles the head gasket failed to the point where the engine was sucking up coolant and then it was easy to diagnose and fix the problem.
Oof! Does a head gasket failure in 3EUR engines risk leaking coolant into engine oil? After coming from chevy small block world, I'm still familiarizing myself w/ Toyota engines. Coolant in oil can quickly trash the engine bearings, requiring a tear-down & rebuild.
Also, I'd think a failed pressure test on the cooling system would have indicated possibility of head gasket failure, no? Then a chemical test for presence of combustion gases in coolant would have (probably) confirmed it.
2018 Tundra Crewmax
post #10 of 12 (permalink) Old 03-28-2019, 08:28 PM
Head gaskets can typically fail in any/all engines in multiple ways. Between the water jacket, and cylinder, water jacket and oil galleys, cylinder and oil galleys, or in air cooled engines, cylinder and the outside of the block.
Coolant combustion gas tests only tell if it has failed between the water jacket and the cylinder. Coolant in oil or oil in coolant only happens if the gasket fails between those areas most often, but you can get coolant into the oil if enough coolant is being pushed into the cylinder. Different engines have different failures for head gaskets. Like diesels (6.0/6.4) you typically get coagulated coolant with oil and combustion gasses. Older gassers like my 3.8 Turbo in the GN most commonly failed and would push coolant into the cylinder and into the engine/oil pan. But the force of the coolant trying to hydrolock the engine under compression would take the bearings out and cause a knock before enough coolant was in the oil to totally ruin the bearings from contamination. Those were an odd bird though. Too much boost would lift the head, and literally flood the engine with coolant trying to lock it up.
I'm not sure how the Tundra's 5.7's fail most often.
post #11 of 12 (permalink) Old 04-03-2019, 06:40 PM
Quoted: 11 Post(s)
Originally Posted by Powertechn2 View Post
... Older gassers like my 3.8 Turbo in the GN ....
Off topic ... I have a garage queen '87 GN ... we're an "elite" group ;-)
At most, I might see 3-4 GNs per year in So Calif these days.
2018 Tundra Crewmax
The Following User Says Thank You to [email protected] For This Useful Post:
Powertechn2 (04-03-2019)
post #12 of 12 (permalink) Old 04-03-2019, 07:08 PM
There's quite a bit here, especially around Woodward Cruise time. Huge group.
I sold mine (87) last fall, but the guy who bought it has came in a few times this week because he replaced the floor, and fubar'd something, and they are odd birds till you learn what's what. I'll help him with it.
Mine needed body work, mechanically it was good. I have no garage, and finally figured he came in blind, saw it while putting in my new driveway, and said name your price so I did.
I need a garage before I get another one.
