Weird gas issue - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 16 (permalink) Old 03-25-2019, 10:52 PM Thread Starter
Quoted: 6 Post(s)
Weird gas issue
4 Month old Tundra. This morning I pulled in for gas like every Monday. I started pumping gas until it stopped. It stopped at 8 gallons from half a tank. I know I have the 38 gallon tank so this didn't make sense however the gauge said full. On the way to work the fuel gauge dropped fast and by the time I got to work it was already on 3/4 a tank. On the way home I stopped at the same station. I filled up again but this time I was able to get another 8 gallons of gas. The gauge again is at full but this time I feel it's right. What do you guys think happened?
JerrypWhite is offline
The Following User Says Thank You to JerrypWhite For This Useful Post:
ACDan (03-25-2019)
post #2 of 16 (permalink) Old 03-25-2019, 10:56 PM
ACDan's Avatar
Quoted: 5637 Post(s)
Quit eating eggs!
2016 SR5 DCLB 4X4
ACDan is offline
post #3 of 16 (permalink) Old 03-25-2019, 11:05 PM Thread Starter
Quoted: 6 Post(s)
Originally Posted by ACDan View Post
Quit eating eggs!
I get the joke but not really enjoying it right now. Any real help would be appeciated.
post #4 of 16 (permalink) Old 03-25-2019, 11:16 PM
ACDan's Avatar
How about set your odometer and get an accurate reading.
2016 SR5 DCLB 4X4
ACDan is offline
post #5 of 16 (permalink) Old 03-25-2019, 11:18 PM
ACDan's Avatar
2016 SR5 DCLB 4X4
ACDan is offline
post #6 of 16 (permalink) Old 03-25-2019, 11:27 PM Thread Starter
Quoted: 6 Post(s)
This will indeed give me an accurate reading but it doesn't fix the problem. The problem being the fuel gauge reporting wrong on a truck with two payments made. I thought maybe there is something I'm missing, doing wrong, or something I can reset. I've never had this happen on any vehicle and it concerns me for a vehicle this new.
post #7 of 16 (permalink) Old 03-25-2019, 11:33 PM
ACDan's Avatar
Did you use the same gas pump?
If it happens again I could see the problem but what if you just didn't fill it up all the way that morning.
My needle stays close to F for a long time before it starts dropping faster.
2016 SR5 DCLB 4X4
ACDan is offline
post #8 of 16 (permalink) Old 03-25-2019, 11:46 PM Thread Starter
Quoted: 6 Post(s)
Exactly, the gauge in previous fill-ups stayed on F quite a while. I drive approximately 12 miles one way to work and can make it almost a week and have 1/2 tank left. This morning when I ran the pump it clicked and stopped on around 8 gallons. I couldn't believe it because it's a 38 gallon tank. I turned on the truck and it reported full. I then still tried to pump more gas because it didn't make sense but it clicked immediately. Is it possible to have a substantial amount of foam in gas to do this?
post #9 of 16 (permalink) Old 03-25-2019, 11:52 PM
ACDan's Avatar
It's a mystery.
I wouldn't over think it yet. If there is indeed a problem it can be fixed.
Why don't you try running it down until the low fuel light comes before refilling. Then go back to your normal Monday method.
If you can't repeat the problem the dealership damn sure won't fix it.
2016 SR5 DCLB 4X4
ACDan is offline
post #10 of 16 (permalink) Old 03-26-2019, 12:00 AM Thread Starter
Quoted: 6 Post(s)
It's a mystery.
That's what I was thinking. Run it down to empty. I haven't gone past 1/2 since I got it. Thanks. Hopefully i can report back it never happened again.
ACDan (03-26-2019)
post #11 of 16 (permalink) Old 03-26-2019, 12:23 AM
ACDan's Avatar
I bet it will be fine.
I can't think of any reason your gauge would make the pump cut off.
Lay off the eggs for awhile!
2016 SR5 DCLB 4X4
ACDan is offline
post #12 of 16 (permalink) Old 03-26-2019, 05:27 AM
2underpar's Avatar
Quoted: 32 Post(s)
I agree, I’d see if it happens again before getting too crazy about it, hopefully it was an isolated anomaly.
2underpar is offline
post #13 of 16 (permalink) Old 03-26-2019, 08:50 AM
Quoted: 370 Post(s)
My theory: Your tank isn't venting properly through the charcoal cannister as it's being filled. It shutting off at exactly the same volume every time is coincidence. The pump nozzle senses the pressure in the tank, and shuts off when it reaches a certain pressure level...your tank is not venting so it's getting there prematurely.
Get it back to the dealer for warranty replacement of the charcoal cannister (expensive). You may not have done this, but in the future, never try to put additional gasoline once it clicks off. It's asking for trouble with these touchy "nanny" vehicles.
* Auto headlight conversion
* Power tail gate lock
* Toyota weather mats
OldGuy43 is offline
post #14 of 16 (permalink) Old 03-26-2019, 09:50 AM
Geezer's Avatar
Quoted: 10 Post(s)
The charcoal canister is likely.
Another possibility is the tip over valve. I may have the wrong name for it, but there is a mechanism in the tank that prevents fuel from leaking out if the truck tips over. There have been a few postings here and on another Tundra forum where that valve malfunctions and won't let the tank fill.
In any case, it is a warranty issue and should be taken care of by the dealer.
Life is not measured by the number of breaths we take, but by the moments that take our breath away.
Geezer is offline
post #15 of 16 (permalink) Old 03-27-2019, 11:19 AM
Aaron713's Avatar
Quoted: 20 Post(s)
You tell us how much you put in, and how often. Can you include how many miles you drove on those 8 gallons between Mondays? You're describing 2 payments worth of driving time (two months is 8 Mondays) and you've been to the gas station 8 times to fill up.
Aaron713 is offline
