Possible broken valve spring - Page 2 - TundraTalk.net - Toyota Tundra Discussion Forum
post #16 of 24 (permalink) Old 03-12-2019, 07:34 PM Thread Starter
maybe's Avatar
Quoted: 33 Post(s)
Originally Posted by michaelsflowersjr View Post
Sometimes electrical components act up at the weirdest times. But mostly under load where they heat up and then they start failing quickly. If you had a way to watch the fuel pressure in the cab and when it cut out, and it didnít drop, that would
Be a good way to know itís not the fuel pump. Not sure how to do that without costing some money. It does seem like you would get a low fuel pressure code though surely
2019 Tundra TRD Pro
Thatís what I was thinking. I may know someone who could help me out with that.
2014 1794 CM, Bilstein 6112's top setting, 1 CB shim per side, 5160's rear with +3 CB shackles, Zone upper control arms, 1.25 Bora wheel spacers, Stock wheels, Nitto Ridge Grapplers 295/60/20, AMP Research steps.
maybe is offline
post #17 of 24 (permalink) Old 03-12-2019, 07:46 PM
Powertechn2's Avatar
Quoted: 1642 Post(s)
I forget what adapter you have to use to check fuel pressure on a Tundra, but if you are able to T off, there is a long hose fuel pressure gauge that you can run up to the windshield and watch it under a load while the issue is happening.
Have found a few hard to trace issues that way in the past.
and you can call me Power.
Powertechn2 is offline
riccnick (03-13-2019)
post #18 of 24 (permalink) Old 03-12-2019, 07:57 PM Thread Starter
maybe's Avatar
Quoted: 33 Post(s)
I have someone that has a fuel pressure gauge. I just need to know what adapter we need and where do you hook it up at.
maybe is offline
The Following User Says Thank You to maybe For This Useful Post:
Powertechn2 (03-12-2019)
post #19 of 24 (permalink) Old 03-12-2019, 08:30 PM
Geezer's Avatar
Quoted: 10 Post(s)
In the mean time, dump some good injector cleaner in the tank and see if it helps.
Life is not measured by the number of breaths we take, but by the moments that take our breath away.
Geezer is offline
post #20 of 24 (permalink) Old 03-12-2019, 08:51 PM Thread Starter
maybe's Avatar
Quoted: 33 Post(s)
Will do. Never hurts to try the inexpensive things.
maybe is offline
post #21 of 24 (permalink) Old 03-12-2019, 09:16 PM
This might help, seems to list part numbers for adapters.
https://workshop-manuals.com/toyota/...ons/page_4550/
post #22 of 24 (permalink) Old 03-12-2019, 09:20 PM Thread Starter
maybe's Avatar
Quoted: 33 Post(s)
Thanks, I will check that out.
maybe is offline
post #23 of 24 (permalink) Old 03-13-2019, 10:24 AM
BTinAZ's Avatar
Quoted: 105 Post(s)
Truck has a really strange intermitting problem. Sometimes when I give it gas to pass someone the RPM's hang between 3000 and 4000 rpm's and there is no increase in speed. So I let off, then I hear a thud. If I try to just hold it the check engine light starts flashing and the truck starts shuddering. I have also had it happen a few times with a head wind or going up hill on the freeway. I have had the codes pulled it always shows random misfires and bank 1 and 2 lean. I took it to the dealer and they have no clue. They are guessing that it's a broken valve spring but are not sure. What would the symptoms of a broken valve spring be? The reason I ask is because the dealer could not explain to me why they think it is a broken valve spring. The tech took a snap shot with tech stream and sent it to Toyota engineer's.
I had a valve spring go late last year - it completely disabled me right then & there (https://www.tundratalk.net/forums/tu...ml#post9395284).
2014 Tundra 5.7 CrewMax 4x4 SR5 TRD Off-Road in bitchin' Red.
Nothing is as it seems. Nor is it otherwise.
BTinAZ is offline
The Following 2 Users Say Thank You to BTinAZ For This Useful Post:
OldGuy43 (03-13-2019), Powertechn2 (03-13-2019)
post #24 of 24 (permalink) Old 03-13-2019, 11:14 AM Thread Starter
maybe's Avatar
Quoted: 33 Post(s)
Thanks for that info. I remember reading that discussion when I was searching for info on broken valve springs. That's what made me think I don't have a broken valve spring.
maybe is offline
