OBD2 Scanner issue - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 8 (permalink) Old 11-05-2018, 08:59 PM Thread Starter
Quoted: 5 Post(s)
OBD2 Scanner issue
So I have a 2012 Toyota Tundra 5.7L double cab. I assume I have what is an OBD2 port in my truck. When I look at it, itís white, looks like 16 ports, but not all of them look like they are actually pinned with actual metal pins in them if that makes sense.
Anyways. I am just trying to find a simple basic one that will clear codes, nothing extra really. I have tried FIVE OBD2 readers, and none of them will connect or communicate with my truck.
Does anyone know for sure which reader will actually work with my truck and actually clear codes!? I greatly appreciate any help!
-zach
jetblack14316 is offline
The Following User Says Thank You to jetblack14316 For This Useful Post:
shamrock246 (11-06-2018)
post #2 of 8 (permalink) Old 11-06-2018, 07:01 AM
Buckaroo's Avatar
Quoted: 17 Post(s)
Originally Posted by jetblack14316 View Post
So I have a 2012 Toyota Tundra 5.7L double cab. I assume I have what is an OBD2 port in my truck. When I look at it, it’s white, looks like 16 ports, but not all of them look like they are actually pinned with actual metal pins in them if that makes sense.
-zach
Zach -
Unless you have an issue with your OBDII port, any OBDII code reader should be able to communicate with your Tundra. Some basics....
1. The ignition key needs to be in the on position and your truck battery needs to be functioning to communicate via the OBDII port. Truck doesn't have to be running.
2. OBDII port located under the steering wheel
3. With basic code reader, you can only read and clear engine related codes, not ABS, SRS, Transmission codes, etc.
Helpful video....
https://www.carcarekiosk.com/video/2...light/diagnose
If you are doing all the basics right, then it's time to dig deeper into the OBDII port itself. If you have questions, you could always take it to Autozone, etc and have them try to read your codes to verify the port is functioning....they typically do that for free.
Buckaroo
Buckaroo
- 2017 Limited Tundra DC 5.7L 4WD
- 2020 Grand Design Imagine 2670MK
- 2017 XLE Camry 2.5L
- 2010 Mazda Mx-5 Touring
- 2004 EX Accord 2.4L
- 2002 XLE Camry 2.4L
- 2000 4Runner 3.4L 4WD
Buckaroo is offline
post #3 of 8 (permalink) Old 11-08-2018, 08:33 PM Thread Starter
Quoted: 5 Post(s)
Iím going to bump this again and see if anyone has any other info.
I have tried two different scanners from friends that are between 30 - 50 bucks and they donít work.
The ones at the auto store do but they are like 300+ dollars?
Any insight?
post #4 of 8 (permalink) Old 11-08-2018, 08:39 PM Thread Starter
Quoted: 5 Post(s)
Any insight?
post #5 of 8 (permalink) Old 11-12-2018, 07:54 AM Thread Starter
Quoted: 5 Post(s)
Going to try and bump again. This is insane, none of these OBDís are compatible for whatever reason.
post #6 of 8 (permalink) Old 11-12-2018, 10:10 AM
Brian20's Avatar
Quoted: 156 Post(s)
Going to try and bump again. This is insane, none of these OBD’s are compatible for whatever reason.
I use this one on my 2016, works fine.
[Upgraded Chip] WiFi OBD2 Scanner Car Diagnostic Tool - Vehicle Code Reader Wireless OBD II Check Engine for iOS Android & Windows Device, More Than 3000 Code Database https://www.amazon.com/dp/B075B3CG7S..._EEz6BbWNJ102M
Brian20 is offline
The Following User Says Thank You to Brian20 For This Useful Post:
Powertechn2 (11-12-2018)
post #7 of 8 (permalink) Old 11-12-2018, 10:47 PM
Powertechn2's Avatar
Quoted: 1658 Post(s)
I use the same one he said^^^, no issues connecting.
and you can call me Power.
Powertechn2 is offline
post #8 of 8 (permalink) Old 11-16-2018, 08:30 AM Thread Starter
Quoted: 5 Post(s)
Thanks Brian and Powertech! Got that one and it works! Itís because my OBD is CAN complaint and I guess the ones I was trying to use were not.
Thanks!
