Shake in steering wheel - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 11 (permalink) Old 12-03-2017, 08:51 AM Thread Starter
Quoted: 49 Post(s)
I THINK I may have a bad tire, but wanted to get opinions.
I did the following upgrades all at once and the shake began. The ride itself is smooth. Bilstein 5100s highest setting w/CB shim. Toytec 1.5" shackles. Fuel beast 18x9 +1 offset. Falken wildpeak at3w 305/65/r18.
I assumed this was a balancing issue from the start. I used a very reputable off-road shop to install everything. They road force balanced the tires. I took it back to have them checked because of the steering wheel shake. They checked all, rebalanced one, and rotated the tires. That fixed the issue. Last oil change I rotated the tires and now it's back.
Is this most likely a bad tire ? I'm taking it back, but can't get in until January. Thought about trying another shop just to rule out poor work being the issue. But like I said this place is THE place to go where I live.
MattFL850 is offline
post #2 of 11 (permalink) Old 12-03-2017, 11:26 AM
Quoted: 328 Post(s)
Is notorious for Toyotas in general.
The one thing you mentioned as they didn't do a balance at the last tire rotation which is huge. Tires wear and you're changing the position of which there further wearing by doing a tire rotation. You need to have the wheels tires balanced during rotations as well because what worked 6 months ago is not going to work today.
Just make sure they do a dynamic Road force balance and you'll be good to go.
AZTC #70, 14TC #42
14burrito is offline
post #3 of 11 (permalink) Old 12-03-2017, 01:21 PM
mendonsy's Avatar
Another possibility is that the wheels were not mounted properly by the shop that did the rotation. If they just threw them on and tightened them with an impact that can cause problems because the Tundra wheels are hub centric.
The lug nuts need to be tightened to snug then torqued to 90 ft/lb with a torque wrench in a star pattern. Try loosening all five lug nut the re-tighten them properly.
'19 SR5 DC, 5.7, TRD
Toyota SS steps, ARE MX cap
Toyota bed step, Weathertech Vent Visors
Techstream
TWACC #7
mendonsy is online now
post #4 of 11 (permalink) Old 12-03-2017, 02:23 PM Thread Starter
Quoted: 49 Post(s)
On the balance. It was only a few thousand miles. It was pretty early for a rotation. I just did it because I had the oil changed to get on track.
post #5 of 11 (permalink) Old 12-03-2017, 02:25 PM Thread Starter
Quoted: 49 Post(s)
I'll try that on my next day off. I've only had this tundra since January. But I've been in one since 2009 and have never had this issue. I know for a fact the they hand tightened this rotation, but I'm not for sure if they torqued it. Thanks
post #6 of 11 (permalink) Old 12-03-2017, 06:42 PM
Quoted: 328 Post(s)
I rotate and rebalance every 2500 or so. Rebalancing is key, regardless of miles.
AZTC #70, 14TC #42
post #7 of 11 (permalink) Old 12-30-2017, 07:35 PM Thread Starter
Quoted: 49 Post(s)
Finally got around to discount tire. They were way out of balance
post #8 of 11 (permalink) Old 01-02-2018, 07:17 PM
Quoted: 19 Post(s)
I quit putting the stick-on weights that came when I ordered them. Put the old school hammer on weights, no more problems.
JDIZZ is offline
post #9 of 11 (permalink) Old 01-11-2018, 06:46 PM
Quoted: 328 Post(s)
Unfortunately an old school hammer on weights don't work for all Wheels
AZTC #70, 14TC #42
post #10 of 11 (permalink) Old 01-12-2018, 08:45 PM
GR8White's Avatar
Quoted: 343 Post(s)
@MattFL850 , any pics of the truck? Trying to get a buddy to do same 5100’s and same tires but on stock wheels
2012 RW DC. ADS Coilovers and Piggybacks, MCM Fab UCA's, CB +3ís, 305/70/17 Nitto Terra Grappler G2's, full audio system
GR8White is offline
post #11 of 11 (permalink) Old 01-14-2018, 02:53 AM Thread Starter
Quoted: 49 Post(s)
Originally Posted by GR8White View Post
@MattFL850 , any pics of the truck? Trying to get a buddy to do same 5100ís and same tires but on stock wheels
Here ya go
