A Vibration Thread of My Own 07 Crew Max - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 16 (permalink) Old 03-06-2017, 11:23 AM Thread Starter
TacomaCowboy's Avatar
Quoted: 5 Post(s)
So the main problem i am having is a constant full truck vibration. From 50-75mph it smoothes out real nice going 80, but the State Trooper last week told me that was not acceptable... i have had this problem for the last 40,000 miles or so. the truck currently has 240,000 on the ticker. The truck vibrates enough that my passenger seat looks like it is at a Pantera concert doing its best at head banging. Though the steering wheel doesnt really vibrate unless i apply the brakes. Which stops once under 50mph
Steps i have taken so far...
Replaced lower control arms
Replace steering tie rods
Replaced CV axles
Replaced bilstein 5100 struts 2.5" lift
extensive trips to the alignment shop
have my tires filled with 8oz of ceramic balancing beads (295/75-18 nitto terra grappler g2 on moto metal 951s)
and replaced the needle bearing driver side axle with the bushing kit from east coast gear supply (i did have a loose cv axle. this kit fixed that extra movement)
I have new pads front and rear, and new rear rotors.
checked my emergency brakes for binding (all good)
I do have about a 1/4" of give on the 2 piece drive shaft carrier bearing. Normal?
what else am i missing that could possible help me locate and snuff this problem out?
It is bad enough that my girlfriend claims her 4 door jeep on 35's has a better ride. Not Acceptable!
i have read over 40 different threads with solutions that i have tried and none have quite seemed to do the trick.
Good day to Y'all from Texas.
There was a time that I was awesome, then the cops showed.
00 tacoma xtrcab 3.4 lifted, locked, armored... dead
06 tacoma 4door 4.0 lifted, armored, headers... dead
07 tundra crewmax 5.7 lifted, armored, and alive
TacomaCowboy is offline
post #2 of 16 (permalink) Old 03-06-2017, 08:53 PM
Quoted: 533 Post(s)
Sounds like you need cab mounts
l1tech is offline
post #3 of 16 (permalink) Old 03-06-2017, 09:27 PM
Dixon Cider's Avatar
Quoted: 60 Post(s)
I am sure that you have done this with as many miles as you have, but what about swapping the wheels from front to back and see if the vibration changes. Also, you might want to look and see if your rims are hub centric. From MotoMetal website "A: Most aftermarket wheels are manufactured with a center hole that will fit a wide range of vehicles. The hub-centric ring is an installation tool used to help hold the wheel perfectly centered during installation. Use of a hub centric ring can help in reducing minor vibrations. Proper installation and torque sequence is required to correctly center a wheel with or without a hub centric ring."
Also, I checked my center carrier bearing and it had about 1/4 inch play in it.
Sent from my Commodore 64 with cassette tape backup.
Dixon Cider is offline
post #4 of 16 (permalink) Old 03-06-2017, 09:47 PM
wyo700's Avatar
Quoted: 49 Post(s)
From my experience I'm saying it's you're carrier bearing on the drive shaft. And for your steering wheel vibration when stepping on the breaks that is warped rotors.
wyo700 is offline
The Following User Says Thank You to wyo700 For This Useful Post:
Dixon Cider (03-06-2017)
post #5 of 16 (permalink) Old 03-06-2017, 09:49 PM
Quoted: 24 Post(s)
U joints?
2007 Tundra CrewMax 5.7L "Max"- Black with tan/chocolate leather - 20" factory wheels and Powerstop drilled and slotted brake rotors - Fender flares - Bilstein 5100's front and rear - TRD rear sway bar - K&N drop in/carbon filter delete/throttle body screen delete - TRD airbox Flow Accelerator - Dirty Deeds Stainless TRD Rep exhaust with TRD stainless tail pipes
PonyMan is offline
The Following User Says Thank You to PonyMan For This Useful Post:
post #6 of 16 (permalink) Old 03-06-2017, 09:52 PM
Quoted: 60 Post(s)
I saw rotors on the original post, but re-read and it was only the rears. You are correct the warped front rotors would definitely cause the shaking during braking.
post #7 of 16 (permalink) Old 03-07-2017, 11:03 AM Thread Starter
Quoted: 5 Post(s)
Thanks for checking that.
I have swapped Tire positions many a time. They seem to be smooth for about 500 miles/ 3 days and start to shake again. Brand new they run about a week before the problem shows its face again . Also the moto website claims to have the same bore as the Tundra hub at least on that specific wheel.
post #8 of 16 (permalink) Old 03-07-2017, 11:05 AM Thread Starter
Quoted: 5 Post(s)
Originally Posted by PonyMan View Post
U joints?
Checked. They seem to be pretty tight with no clicking. Brake check confirmed this, but they are the originals.
post #9 of 16 (permalink) Old 03-07-2017, 11:19 AM
RIjon's Avatar
Quoted: 534 Post(s)
Welcome to my world. I've been dealing with this for years. The worst part is it comes and goes for me.
Several wheels and tires. Several road force balances. Checked everything I could except axle and spindle runout. I did have it on a frame rack at one point and digitally measured. All fine.
Next is driveshaft rebalanced (this was replaced by dealer once long ago).
Then check axle and spindle.
Then mysteriously, the truck might burst into flames.
08 RCSB B00STED
10 T4R
RIjon is offline
post #10 of 16 (permalink) Old 03-07-2017, 11:35 AM Thread Starter
Quoted: 5 Post(s)
I've kinda be waiting on a Mercedes or BMW to hit me from the side. Running a red light or something. Just saying I wouldn't mind having a 2015 in desert sand Mica rock warrior edition. Come on car gods...
post #11 of 16 (permalink) Old 04-26-2017, 07:58 PM Thread Starter
Quoted: 5 Post(s)
So I may be on to something. I replaced the front Rotors last week. No changes in vibration, but... I noticed that my right cv axle has a bit of an oscillation 2mm at max while the driver's side has no deviation to its rotation. Would this be enough to shake my whole truck?
post #12 of 16 (permalink) Old 04-26-2017, 09:35 PM
RIjon's Avatar
Quoted: 534 Post(s)
2mm, not likely
I'm still slacking on getting my driveshaft balanced. I am thinking the 5100s are compromised as at least one rear is leaking. Bad suspension was causing a vibration on my 4runner. It felt just like a wheel out of balance. Had the wheels balanced and the problem didn't get much better. Put a 2" suspension lift on and it was completely gone. (springs, shocks, hats + Alignment)
The took it out for a ride last week. Vibes weren't there most of the day, even after sitting all winter. Then when I hopped in it to go home, the vibes were back at 62-72 mph like it always is. Completely random
08 RCSB B00STED
10 T4R
RIjon is offline
post #13 of 16 (permalink) Old 04-26-2017, 11:32 PM Thread Starter
Quoted: 5 Post(s)
That could be a possibility. I blew my driver side 5100 strut on a low water crossing (snapped it at the base) , and the new redesigned model is 1/2 inch shorter. So my truck leans towards the driver's side with the newer strut. I wonder if my passenger side is ruined.
post #14 of 16 (permalink) Old 05-24-2017, 12:31 PM Thread Starter
Quoted: 5 Post(s)
Ok so this weekend I made slight strides towards my end goal of getting a smooth ride. I jacked my rear end up and had my dad drive the truck up to 45mph. The driver's side had a slight vibration, but the passenger side got the wobbling so bad. That if my tool box hadn't had been bolted down the entire thing would have been bucked off. End if the truck had about 3 inches travel at a very high rate.
So I'm guessing a bent wheel or out of round tire.
The Following User Says Thank You to TacomaCowboy For This Useful Post:
ACDan (05-25-2017)
post #15 of 16 (permalink) Old 07-26-2017, 06:08 PM Thread Starter
Quoted: 5 Post(s)
Problem found or at least one of the reasons for my vibration. Rack and pinion bushings. I picked my truck up with our forklift at work and found that the rack moves an inch back and forth. New parts ordered just in time for a 3000 mile trip this weekend. Hopefully it solves my my issues
Sent from my SM-G930V using Tapatalk
RIjon (07-26-2017)
