Driveline grease points - Page 2 - TundraTalk.net - Toyota Tundra Discussion Forum
post #16 of 29 (permalink) Old 02-24-2017, 04:58 PM
Mickleford's Avatar
Quoted: 63 Post(s)
Originally Posted by GreatAvalon View Post
Is there a spec of grease that should be used?
Straight from the manual:
Lithium base chassis grease, NLGI No.2
2016 CM SR5 | Silver Sky Tundra Club Member #248
Mickleford is offline
The Following 4 Users Say Thank You to Mickleford For This Useful Post:
Dixon Cider (03-04-2017), GreatAvalon (02-24-2017), Mr. Creosote (02-25-2017), msoto_3 (02-26-2017)
post #17 of 29 (permalink) Old 02-24-2017, 06:26 PM
GreatAvalon's Avatar
Quoted: 759 Post(s)
You the man. I guess I should RTFM!
2016 Tundra - DC | Limited | TRD | 5.7 | 4x4 | Lux Pack | Ceramic Tint | Husky X-Act Contour | AMP PowerSteps | TRD Sway Bar | TRD Exhaust | Full VLEDS | 2018 OEM LED Headlights & Fog Lights
GreatAvalon is offline
The Following User Says Thank You to GreatAvalon For This Useful Post:
post #18 of 29 (permalink) Old 02-24-2017, 07:56 PM
rolly's Avatar
Quoted: 37 Post(s)
Great post ! Should be a sticky!
rolly is offline
The Following User Says Thank You to rolly For This Useful Post:
post #19 of 29 (permalink) Old 02-24-2017, 08:09 PM
Quoted: 759 Post(s)
post #20 of 29 (permalink) Old 03-04-2017, 11:19 PM
Blindman75's Avatar
Quoted: 35 Post(s)
Sub
Sent from my SM-G925V using Tapatalk
Blindman75 is offline
The Following User Says Thank You to Blindman75 For This Useful Post:
Mr. Creosote (03-05-2017)
post #21 of 29 (permalink) Old 03-05-2017, 01:23 AM
Cereal Killer
Mr. Creosote's Avatar
Quoted: 1612 Post(s)
Originally Posted by Blindman75 View Post
Sub
Mr. Creosote is offline
The Following User Says Thank You to Mr. Creosote For This Useful Post:
JT74 (03-12-2017)
post #22 of 29 (permalink) Old 03-05-2017, 02:43 AM
Big Shasta's Avatar
Quoted: 1887 Post(s)
If you get one of these (a needle adapter) you can do all your ball joints and tie rod ends. Just don't pump them too full or the pressure will come back out the hole.
Also, one of these makes getting grease in a zerk much easier. Especially if you can't get straight enough to snap onto it without it leaking out the sides.
Called a Lincoln nozzle, you just push it up to the ball in the fitting. Also cuts out the aggravation of the gun getting stuck on the fitting.
2012 Pearl White 4x4 Sequoia Platinum.
I drink a whiskey drink
I drink a vodka drink
and when I have to pee
I use the kitchen sink
Big Shasta is offline
The Following 5 Users Say Thank You to Big Shasta For This Useful Post:
Dixon Cider (03-05-2017), Dragos28 (03-10-2017), JT74 (03-12-2017), Mr. Creosote (03-05-2017), Redwoods Jay (03-06-2017)
post #23 of 29 (permalink) Old 03-10-2017, 02:30 PM
Jaj23's Avatar
Quoted: 1081 Post(s)
Updated post no. 10 to show grease type I use.
Sent from my Atari 2600
Jaj23 is offline
The Following User Says Thank You to Jaj23 For This Useful Post:
Mr. Creosote (03-10-2017)
post #24 of 29 (permalink) Old 03-10-2017, 06:52 PM
Quoted: 33 Post(s)
thanks.
aspec is offline
The Following User Says Thank You to aspec For This Useful Post:
post #25 of 29 (permalink) Old 03-11-2017, 11:22 AM
Mickleford's Avatar
Quoted: 63 Post(s)
http://m.advanceautoparts.com/p/gree...1&prefZC=41143
This is also NLGI #2
The Following User Says Thank You to Mickleford For This Useful Post:
Mr. Creosote (03-11-2017)
post #26 of 29 (permalink) Old 10-22-2018, 08:38 PM
walter93's Avatar
Quoted: 10 Post(s)
The three obvious zerks
The very front of the main drive shaft:
About the middle of the drive shaft:
Right in front of the rear differential.
To "retorque propeller shaft" (per manual)
Manual states torque is 59 for front shaft and 52 for rear shaft.
The two less obvious zerks
Here are photos of the two zerks for the front shaft...both are in the center of the spider joints. I was able to find an easy way to reach the rear zerk of the front shaft by coming in from the front passenger side.
Photo taken towards driver rear wheel from front passenger side:
Same photo, but with grease gun in place:
Photo of the front zerk of the front shaft:
Use NLGI No. 2 Lithium Grease
This is the kind of grease you need.
$3.99 at Harbor Freight
Thank you so much for posting these pics. Did my first oil change last weekend and forgot about lube!!
walter93 is offline
post #27 of 29 (permalink) Old 10-22-2018, 08:48 PM
RingSteel's Avatar
Quoted: 149 Post(s)
Nice pics.
Now has anyone ever use these?
https://www.amazon.com/d/Grease-Guns...k+n+lube&psc=1
I bought the short and long one for my tractor.
Love these units.
No more busting knuckle pulling them off and and trying to pop them in.
2003 F-250 7.3 XLT-traded for 2014 4Runner TE Prem.
2010 F-150 gone for a 14' CM, 4x4, 5.7L, Barcelona Red, Tan interior TSS Pkg.>2018 F-250 XLT FX4 6.2L
Going down in a pile of brass, Jack!
RingSteel is offline
post #28 of 29 (permalink) Old 10-22-2018, 10:25 PM
thearborbarber's Avatar
Quoted: 35 Post(s)
I've had one for a couple of years now and it works great, esp on my tractor.
2018 Tunda SR5 w/TRD Package
thearborbarber is offline
post #29 of 29 (permalink) Old 10-27-2018, 06:56 PM
Quoted: 65 Post(s)
How much grease should be pumped? I've heard anywhere between 1 to 2 pumps or until you flush out old grease. Not sure how much I should be pumping. Thanks!
Sent from my SM-N950U using Tapatalk
MGMC#365
tijkim is offline
