Just Got Back From Dealer For Steering Wheel Not being Centered - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 23 (permalink) Old 09-24-2016, 10:41 AM Thread Starter
Quoted: 16 Post(s)
Unhappy Just Got Back From Dealer For Steering Wheel Not being Centered
Brought my 2 month old SR5 back to the dealer due to the steering wheel being turned left when driving straight. All they did was correct a slightly out of spec right tie rod toe. Service guy said the test ride indicated the wheel was now straight as it will get and we can't get it perfect, also mumbled something about road crown. My guess is the tech didn't center the wheel prior to doing the alignment. I'm not an alignment guy but I would think all he had to do was adjust each tie rod end equally so the wheels are pointing straight while the steering wheel was centered. What a waste of time. I certainly will not be going back to that dealership.
swimbait_charlie is offline
post #2 of 23 (permalink) Old 09-24-2016, 11:34 AM
Quoted: 18 Post(s)
I'm a mechanic and I've done my fair share of alignments. All he did was center your steering wheel and correct the toe adjustment on both wheels. He's right about road crown effecting steering but only on some roads.
Sent from my Nexus 6P using Tapatalk
ledzeppelinriff is offline
post #3 of 23 (permalink) Old 09-24-2016, 11:56 AM Thread Starter
Quoted: 16 Post(s)
The wheel isn't centered. It's at 11:00 when going straight. My FJ steering wheel was dead straight across as is my co workers Tundra and my wifes buick when driving straight. I'm going to bring it to an alignment shop and see what they have to say.
post #4 of 23 (permalink) Old 09-24-2016, 12:14 PM
Quoted: 31 Post(s)
This is strange and timely for me, I just had my Tundra in last week for 5,000 mi service. They rotated the tires and now the wheel is at 12:30 or so when going straight. I've driven it for a week this way on various roads, it isn't road crown. My problem is making time to get back to the dealer...
CoffeeAddict is offline
post #5 of 23 (permalink) Old 09-24-2016, 01:34 PM
StormTrooperRW's Avatar
Quoted: 679 Post(s)
They compensated for road crown in your alignment. So the steering wheel will be straight on roads that are sloped for water runoff. I had them take it out of my alignment so it was dead center on flat ground.
2017 Ram 2500 Cummins Crew Cab
-2016 Toyota Tundra Platinum - SOLD
-Icon Stage 5/6 MT Suspension - For Sale
-18" Method Standards W/ 285/75R18 (35x11.5) Toyo AT2 Extremes For Sale
-2012 Toyota Tundra Rock Warrior D/C w/
a whole buncha crap.... SOLD!
StormTrooperRW is offline
post #6 of 23 (permalink) Old 09-24-2016, 01:43 PM Thread Starter
Quoted: 16 Post(s)
It's tilted to the left on any road if I hold it centered the truck will drive off the road to the right. It's annoying to look down and see the tilt which was my complaint, apparently they disregarded my complaint.
post #7 of 23 (permalink) Old 09-24-2016, 02:45 PM
Quoted: 679 Post(s)
Right. So most of the roads you travel are flat then. Tell you specifically you want the compensation for the crown in the road removed.
post #8 of 23 (permalink) Old 09-24-2016, 04:54 PM
XHILR8N!'s Avatar
Quoted: 316 Post(s)
Ours is off like that too, but not as bad as yours. Sure glad that the makers of our other cars and earlier Tundras did not know about "road crown"
2003 Tacoma 4WD. 2005 Tundra, Carolina Dirt Road Metallic (traded)
2007 Tundra XS-P, dark green. Perhaps the very best overall vehicle I've ever owned, traded for:
2015 Tundra TRD pro, Inferno dual cab.
Lotus cars: 1974 Europa, 2005 Elise (track prep), 2011 Evora S
2015 Honda Civic Si It's orange too. Great little daily
2013 Bentley Continental GT Speed. Best car on the road.
2019 Lexus LC500. The V8 barks!
XHILR8N! is offline
post #9 of 23 (permalink) Old 09-24-2016, 09:49 PM
socal57chevy's Avatar
Quoted: 412 Post(s)
Did they offer you a printout with before and after measurements?
Your steering wheel should not be off center after an alignment. I'll bet the tech who did the alignment didn't drive your truck before & after he did the alignment.
I don't trust shops that don't offer a printout unless they have a really good reason for it. They can look you up in the alignment machine computer and print one for you if you go back and ask for it. Post it up and we'll take a look at it.
Centering the steering wheel and adding cross caster to keep the truck from pulling right are two different issues. If your truck drives straight, but the steering wheel is not centered, road crown and cross caster are not your issue. A lazy alignment guy is your issue.
ASE Master Technician
socal57chevy is offline
The Following User Says Thank You to socal57chevy For This Useful Post:
jbroas (09-24-2016)
post #10 of 23 (permalink) Old 09-26-2016, 05:55 AM Thread Starter
Quoted: 16 Post(s)
The print out will be mailed, something about need to do paper work for the warranty claim. He showed it to me and like I said earlier he adjusted the passenger side tie rod as it was slightly out of spec. I don't think he test drove it because my bluetooth on my phone stayed linked to the truck while I was waiting. The truck drives perfectly straight with no pulling it's just the annoying tilted steering wheel.
post #11 of 23 (permalink) Old 09-26-2016, 07:43 AM
Quoted: 412 Post(s)
Definitely a lazy tech. Road crown and cross caster have nothing to do with it. He simply didn't center your steering wheel and then he didn't drive the truck to ensure that his adjustment took care of your concern. He never even drove your truck to verify your concern in the first place. Every alignment needs a before and after road test. Without both, there's no way of knowing if the adjustments had any affect on the way the vehicle drove. After they fix this for you, I'd ask for a different tech on any future visits you make to this dealer for service.
post #12 of 23 (permalink) Old 09-26-2016, 05:35 PM Thread Starter
Quoted: 16 Post(s)
Took this pic of the wheel while driving straight, might not bother some but it bothers me.
post #13 of 23 (permalink) Old 09-26-2016, 08:58 PM
Ghost96R's Avatar
Quoted: 145 Post(s)
Attachment 698746
Dude, your toe is off. Thats all.
2016 Tundra CrewMax 4x4, TSS black edition, Bilstien 6112/5160s with Toytec Shackles and poly bushings, TRD Rear Sway Bar, Morimoto XB LED Foglights, Morimoto D2S 4.0 Retrofit headlights with Osram CBI 6000k bulbs, Fender Flares, Undercover Flex bed cover, Viofo A119S Dash Cam and Escort radar detector hardwired, Husky X-Act Contour Front/Rear mats, Line-X bedliner, Debadged, Anytime Fog light Mod, Leather steering wheel swap
MGMC#400
Ghost96R is offline
post #14 of 23 (permalink) Old 09-26-2016, 09:02 PM
Ghost96R's Avatar
Quoted: 145 Post(s)
Mine looked the same after a steering wheel swap. It's a easy fix on your tie rod ends...
MGMC#400
Ghost96R is offline
post #15 of 23 (permalink) Old 09-26-2016, 09:07 PM
XHILR8N!'s Avatar
Quoted: 316 Post(s)
Exactly.
(1) loosen tie rod ends
(2) center steering wheel
(3) reset toe (without pulling the steering rack as to turn the wheel)
(4) drive like 100 feet or more to determine if wheel is centered
(5) Enjoy!
XHILR8N! is offline
