Under my 3/36 Battery bad have a look. - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 14 (permalink) Old 07-20-2015, 05:19 PM Thread Starter
Mike Hickman's Avatar
Quoted: 108 Post(s)
Exclamation Under my 3/36 Battery bad have a look.
Called dealer to see if this was covered under my 3/36 they say no. Why would this not be covered I asked service guy said it's a wear item.
Ok but just today My wife's Tacoma got a new replacement battery put in because it was bad. So I made an appointment for Tuesday to talk to them in person ....
What do you guys / gals think? Picture of what it looks like, does that look normal to any of you?
2012 Tundra CM TRD SR5
6" Procomp on 35 12.5
ATX Ledge Toyo MT.
12x5 BaMuffler setup.
Mike Hickman is offline
post #2 of 14 (permalink) Old 07-20-2015, 05:23 PM Thread Starter
Quoted: 108 Post(s)
This is what they gave us for her Tacoma will it work in my 2012 5.7 SR5 TRD? They did not install because she could not wait so they just put in one back seat.
ATX Ledge Toyo MT.
post #3 of 14 (permalink) Old 07-21-2015, 10:36 AM
Beerguy's Avatar
Quoted: 26 Post(s)
Is there a problem with the battery other than the way it looks? You can clean that up with a can of Coke or some baking powder & water.
Beerguy is offline
post #4 of 14 (permalink) Old 07-21-2015, 10:49 AM
Moderator
Dragos28's Avatar
Quoted: 11668 Post(s)
that oxidization is common on the oem batterys on our tundras. I just went and bought a new battery and had them install new clamps.
Dragos28 is offline
post #5 of 14 (permalink) Old 07-21-2015, 11:12 AM
N2Deep's Avatar
Quoted: 748 Post(s)
Yupp Toyota should cover it - They replaced mine without even asking me and mine never looked that bad.
2010 4x4 Tundra
Front -Camburg Long Travel & King Coilovers and King Secondary triple bypass
Rear - ADS triple bypass spec'd to Deaver Springs
N2Deep is offline
The Following User Says Thank You to N2Deep For This Useful Post:
Mike Hickman (07-21-2015)
post #6 of 14 (permalink) Old 07-21-2015, 12:15 PM
wildbill23c's Avatar
Quoted: 677 Post(s)
That's about how mine has looked for 7 years. Its pretty normal no matter what the vehicle is. Its not just a Toyota thing. Batteries will corrode in any vehicle. A simple mix of baking soda and water and a brush and its all taken care of.
No, Toyota doesn't need to replace it.
wildbill23c is offline
post #7 of 14 (permalink) Old 07-21-2015, 12:20 PM
Jaj23's Avatar
Quoted: 1081 Post(s)
Mine looks like that. It's annoying because when I wash out my engine bay, the acid drips on the ground and stains my driveway. When it dies, I'll get a different kind of battery...optima or some other sealed battery.
Sent from my Atari 2600
Jaj23 is offline
post #8 of 14 (permalink) Old 07-21-2015, 12:39 PM
chphilo's Avatar
Quoted: 636 Post(s)
As others have asked, does it still function or is it completely dead?
2010 Tundra, CM, 4x4, 5.7, TRD Off Road, Silver Sky Tundra Club #7, TWACC #100, RYRWDBTTBYCDI #7, Tri-State Club #21, Chrome Club #23, LTC #10
Toyota/TRD (Stepboards, Cat-Back, Intake, Hood Protector, Tow Mirrors), Pioneer (AVIC Z140BH & ND-BC5), Clazzio, Tint, Wheelskin, Line X (Extra/Color Match), ValuGard (Undercoat & Rust Inhibitor), Husky WeatherBeater, Westin Ult BB & Lights, Moto Metal 961, BW fender flares, BAKFlip F1, OME 614, LR UCA, UC SwingCases, Nitto Trail Grappler (295/70/18)
chphilo is offline
post #9 of 14 (permalink) Old 07-21-2015, 12:47 PM
MetalMonkey's Avatar
Quoted: 360 Post(s)
Installed March, 2011
Still looks just like this today and I live three blocks from San Diego Bay
MetalMonkey is online now
post #10 of 14 (permalink) Old 07-21-2015, 06:08 PM Thread Starter
Quoted: 108 Post(s)
Toyota replaced it under my 3/36 warranty, it was leaking acid so they replaced no questions asked.
That might be normal on some batteries but this was not a normal corrosion.
When you pay what we do for or trucks and still have 3/36 use it because once it's over that's it. I paid for a warranty I used it for what was needed.
Thanks guys for all info....
ATX Ledge Toyo MT.
post #11 of 14 (permalink) Old 07-21-2015, 06:12 PM
Quoted: 677 Post(s)
I had the 7/100k warranty which has expired. Used it once for the rear wheel bearing issue.
I still have the original battery. I did get some dielectric grease and put on the battery terminals which has helped with the corrosion issue.
The Following 2 Users Say Thank You to wildbill23c For This Useful Post:
MetalMonkey (07-22-2015), Mike Hickman (07-21-2015)
post #12 of 14 (permalink) Old 07-21-2015, 06:12 PM Thread Starter
Quoted: 108 Post(s)
While there they also fixed my shaking azz running lights . Also my truck when pulling up to a stop
light cold or warm would idle down below 500 rpms. They cleaned the throttle bottle under warranty.
I say they took care of me damn good...
ATX Ledge Toyo MT.
post #13 of 14 (permalink) Old 07-21-2015, 06:41 PM Thread Starter
Quoted: 108 Post(s)
I still have the original battery. I did get some dielectric grease and put on the battery terminals which has helped wifth the corrosion issue.
Yep I have a 7/125 too, cost me but I'll be covered for a good while.
ATX Ledge Toyo MT.
The Following User Says Thank You to Mike Hickman For This Useful Post:
wildbill23c (07-21-2015)
post #14 of 14 (permalink) Old 07-21-2015, 06:50 PM
Quoted: 677 Post(s)
The cost of the warranty was well worth it just for that 1 case. Total bill would have been about $1100 if it wasn't for the warranty.
Sounds like there was a bad batch of batteries for a while as there have been a few other mentions of batteries leaking and causing some corrosion issues on the truck itself under the battery trays.
