Brake dilemma - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 10 (permalink) Old 07-14-2015, 06:53 PM Thread Starter
2012CMINCO's Avatar
Quoted: 917 Post(s)
Brake dilemma
Having brake judder on my 2012. Have about 48k miles.
My dealer got approval from Toyota to replace my backing plates to the new design using my 7yr / 125k platinum warranty.
Here's the dilemma:
The rotors will be turned.
The pads are at 6/32 so good.
The dealer is willing to replace rotors and pads at no cost for me if I want to supply new ones to them, since they will be tearing things apart anyway. I was thinking Cryo treated BrakeTech slotted and Hawk LTS.
So, do I let them turn and keep decent life left pads, or do I spend the bucks and go with the combo I mentioned above?
2012CMINCO is offline
post #2 of 10 (permalink) Old 07-14-2015, 08:53 PM
Quoted: 533 Post(s)
I tow a 7000 lb toyhauler on a regular basis and the stock pads and rotors are more than up to the task. The front and rear brakes on my truck were replaced with Toyota pads and the rotors were resurfaced when I bought the truck with 54,000 miles. I now have 86,000 miles on the truck and the pads have approx 50% remaining and I have no vibrations or noises while braking...IMO the stock setup really can't be beat. What do you think you are going to gain by going with slotted rotors and hawk pads?
l1tech is offline
post #3 of 10 (permalink) Old 07-14-2015, 09:24 PM
Quoted: 58 Post(s)
I just had the backing plate replaced on my 11' Crew Max as well. Took away a lot of vibes that showed up seemingly overnight. Another exceptional brake pad to consider is the "adaptive one" pads from NAPA. They are designed with towing in mind, but are fantastic outside of towing as well. Otherwise, I have had great success with Hawk pads in the past on another vehicle & as mentioned above, the stock pads obviously get the job done quite well.
Linky to NAPA adaptive one pad info.
Adaptive One - NAPA Brakes
Rotor info.
http://www.napabrakes.com/magnoliaPu...nce-rotor.html
michaelw8107 is offline
post #4 of 10 (permalink) Old 07-14-2015, 11:34 PM Thread Starter
2012CMINCO's Avatar
Quoted: 917 Post(s)
Thanks for the replies.
post #5 of 10 (permalink) Old 07-14-2015, 11:55 PM
Quoted: 26 Post(s)
I did a complete brake job last year, went with cryo treated rotors, replaced all the brake lines with steel braided lines, and went with Hawk LTS pads originally. The LTS pads ended up causing some binding and overheating the rotors. Went to a brake shop and they suggested using posi-quiet pads. Swapped to the posi-quiet pads and have had no issues ever since.
TundraLA is offline
The Following User Says Thank You to TundraLA For This Useful Post:
2012CMINCO (07-15-2015)
post #6 of 10 (permalink) Old 07-15-2015, 02:37 AM
Mike Hickman's Avatar
Quoted: 108 Post(s)
@2012CMINCO
Is there a TSB on this ?
2012 Tundra CM TRD SR5
6" Procomp on 35 12.5
ATX Ledge Toyo MT.
12x5 BaMuffler setup.
Mike Hickman is offline
post #7 of 10 (permalink) Old 07-15-2015, 08:58 AM Thread Starter
2012CMINCO's Avatar
Quoted: 917 Post(s)
Originally Posted by Mike Hickman View Post
@2012CMINCO
Yes, don't know the number. They changed them in October of 2011.
post #8 of 10 (permalink) Old 07-15-2015, 12:20 PM
Quoted: 67 Post(s)
@2012CMINCO
Google is your friend.. Plus, I keep tundraheadquarters on my favorites..
2007-12 Toyota Tundra Rear Rubbing or Grinding Turning Noise - TSB | Tundra Headquarters Blog
n2ceptor is offline
The Following User Says Thank You to n2ceptor For This Useful Post:
Mike Hickman (07-17-2015)
post #9 of 10 (permalink) Old 07-15-2015, 02:03 PM
Quoted: 599 Post(s)
akebono and centric rotors
sundance is offline
post #10 of 10 (permalink) Old 06-04-2019, 09:22 AM
John-BuyBrakes.com's Avatar
Quoted: 3 Post(s)
Depending on your driving style and conditions there are a lot of different ways you can go. The Posi-Quiet pads are a great pad for many vehicles and applications. It is a slight upgrade from stock from a performance standpoint and (as its name implies) is quiet.
For those looking for a more aggressive pad for heavy braking or towing, the Hawk LTS pads are a great options. If you are one to ride the brakes, just keep in mind that with a more aggressive brake pad compound, the rotors can take a beating if they get too hot for too long.
As always, you can find any of these brake upgrades and others at BuyBrakes.com who enjoys a bit of price smashing. After all, we're Veteran owned. Use coupon code Tundratalk10 at checkout!
John-BuyBrakes.com is offline
