Low idle after hot restart - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 13 (permalink) Old 06-03-2015, 10:03 PM Thread Starter
nitroscope8's Avatar
Quoted: 94 Post(s)
'15 5.7 non FF. Every time after starting the engine after a brief (several minutes) stand the idle will be about 400 rpm or so for several seconds then I can clearly hear the rpms jump to about 800 like the ecm realizes this is too low idle. Also, I'm noticing when starting the engine when cold or warm I notice a slight delay after it begins to start firing. To be more clear It feels like I need to keep the starter engaged before all cylinders fire otherwise it might not start.
This has happened on several tanks of fuel from different stations and has SLOWLY gotten worse since new, but it's not severe enough that a dealer tech would duplicate it every time. Anyone have any suggestions as to what this might be? Maybe it's just a normal characteristic of the engine?
3000 miles.
Protected by Glock.
A two wheel drive truck is like a really hot woman with no vagina. Looks amazing but you can't do anything.
nitroscope8 is offline
post #2 of 13 (permalink) Old 06-04-2015, 10:33 AM
Gort11's Avatar
Quoted: 5 Post(s)
Take it back to the dealer.
2014 Toyota Tundra Sr5 4x4 4.6L
Barcelona Red,Double Cab w Tow Hitch,
SABM w/K&N Filter, BAmuffler TRD Replacement
System w/TRD Tailpipes, Access Cover,
Husky Molded Floor Matts, Vent Visors, TRD Rear Sway Bar,
Hypertech Interceptor
Gort11 is offline
post #3 of 13 (permalink) Old 06-04-2015, 11:19 PM
Wynnded's Avatar
Quoted: 249 Post(s)
Because the dealer can't reproduce it "every" time doesn't seem like a valid "excuse". If they can reproduce it 2 of 10 starts, they should have it in their repair bay until they can describe to you what was wrong and how they resolved it.
Tesla > Edison
2011 RCSB 5.7L AWD (not a typo)
Wynnded is offline
post #4 of 13 (permalink) Old 06-05-2015, 09:17 AM
Quoted: 533 Post(s)
Sounds like the fuel pressure may not be holding when the engine is shut off.
l1tech is offline
The Following User Says Thank You to l1tech For This Useful Post:
2011TundraInMe (06-05-2015)
post #5 of 13 (permalink) Old 06-05-2015, 10:15 AM
Big Shasta's Avatar
Quoted: 1887 Post(s)
Sounds legit.
2012 Pearl White 4x4 Sequoia Platinum.
I drink a whiskey drink
I drink a vodka drink
and when I have to pee
I use the kitchen sink
Big Shasta is offline
post #6 of 13 (permalink) Old 06-12-2015, 02:33 PM Thread Starter
Quoted: 94 Post(s)
Update: So I think I have figured out the problem. I usually fill up with 87 octane, but last week I filled up with 93 octane and went on a 800 mile road trip. During the course of the trip i've used 93 as my first tank, 87 as my second, and 89 as my third. Now today I filled up again and i'm using 89. The problem has gone away completely EXCEPT the one time I filled up with 87, then went away when I used higher grade fuel. It seems my truck doesn't like 87 octane fuel. It runs just fine on 87 with the exception of hesitant start.
Protected by Glock.
post #7 of 13 (permalink) Old 07-09-2015, 02:55 PM
Mike Hickman's Avatar
Quoted: 108 Post(s)
My 2012 5.7 has done this rpms fall to about 400 then goes back to normal rpms Cold or hot. I see this when at a stop light also feel my brake pedal get soft as well. Hopefully This Friday I'll be able to drop it off and see what's up.
2012 Tundra CM TRD SR5
6" Procomp on 35 12.5
ATX Ledge Toyo MT.
12x5 BaMuffler setup.
Mike Hickman is offline
post #8 of 13 (permalink) Old 07-09-2015, 03:53 PM
Quoted: 155 Post(s)
If you have the a/c on the rpms will float a bit with the a/c compressor cycling on, As well it will idle slightly higher if the lights are on while in gear
07 Limited 5.7L 2WD DCRB - billet grille, folding rear seat backs, BAmuffler, Painted TRD rims, AMP research Bed step
2018 Grand Designs Imagine 2250RK
Tundra Campers Club #35
Ditchhooker is offline
The Following User Says Thank You to Ditchhooker For This Useful Post:
Mike Hickman (07-09-2015)
post #9 of 13 (permalink) Old 07-09-2015, 09:02 PM
Quoted: 108 Post(s)
I drove my wife's 13 v6 4x4 Tacoma today and it does the same thing. I guess It's more notice
now due to the BAmuffler because of the sound.
Thanks for the info @Ditchhooker
ATX Ledge Toyo MT.
The Following User Says Thank You to Mike Hickman For This Useful Post:
Ditchhooker (07-10-2015)
post #10 of 13 (permalink) Old 07-21-2015, 06:44 PM
Quoted: 108 Post(s)
Well I had my truck at the dealer for warranty stuff and mentioned the low idle to them. They cleaned the throttle bottle under warranty at no charge so I'll report back on how it goes.
ATX Ledge Toyo MT.
post #11 of 13 (permalink) Old 08-23-2015, 11:16 PM
Quoted: 36 Post(s)
Mine is doing the same thing(kind of), it only does on cold start and it gets worse the colder the outside temp gets. Mine is a 15 FFV with 8000 miles and I always fill up with 91 at shell(seams to be the best fuel in my area). I guess I'll take it to the dealer but my problem with that is if it only does it on a cold start, it well likely not do it once I get there.
RedRooster527 is offline
post #12 of 13 (permalink) Old 08-24-2015, 12:52 AM
Quoted: 108 Post(s)
After throttle body cleaning I hAve yet to have the low rpm problem anymore. I run only 89 octane or better so that did not help keep it from getting dirty.
Anyways clean that throttle body and see what you get .
ATX Ledge Toyo MT.
post #13 of 13 (permalink) Old 08-24-2015, 08:04 AM
Quoted: 599 Post(s)
I had a similar issue with my 07 and the 4.7. A little throttle cleaner in the throttle body fixed it.
A new vehicle shouldn't be doing this... but you might have gotten some rather dirty fuel. It happens sometimes.
sundance is offline
