2015 Sounds like a Diesel on start-up - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 26 (permalink) Old 02-07-2015, 11:05 AM Thread Starter
Quoted: 8 Post(s)
I have a 2015 Tundra with the 5.7 engine. When I start the truck in the morning in Winter temperatures, the engine sounds like a diesel for first 10 miles or so. Sounds like valve train clatter. Anyone else experience this?
Instructor is offline
The Following User Says Thank You to Instructor For This Useful Post:
Mr. Creosote (02-07-2015)
post #2 of 26 (permalink) Old 02-07-2015, 11:13 AM
Azblue's Avatar
Quoted: 8949 Post(s)
The 5.7 is a pretty noisy motor to begin with, I think the cold tends to intensify it.
Save The Chrome Club #1
SAVE THE CHROME!!!
Azblue is offline
The Following 2 Users Say Thank You to Azblue For This Useful Post:
Mr. Creosote (02-07-2015), theoat (02-07-2015)
post #3 of 26 (permalink) Old 02-07-2015, 11:22 AM
Dirte''s Avatar
Quoted: 128 Post(s)
How cold is cold? How loud is loud? My engine is quiet in the teens. Might compare it against another one at the dealer. It would be concerning to me. I would understand for a few minutes with a higher viscosity oils of the past. Normally lifters.... hydraulic or not will do it very shortly. Hydraulic should not do it very long with low viscosity synthetic.
That's right... It's an 14' with a foot print gas pedal and a Hurst speed shifter with a pool-ball grip.
Build Log Here:
14' Tundra 1794 Save The Chrome Club #46
02' Tundra Limited (Gone)
Dirte' is offline
The Following 2 Users Say Thank You to Dirte' For This Useful Post:
post #4 of 26 (permalink) Old 02-07-2015, 11:28 AM Thread Starter
Quoted: 8 Post(s)
This morning temp was 34 and the noise was louder than when truck is warm. Noise gets louder during acceleration until temp gage is in the middle of the range. Truck has 4500 miles on it.
The Following 2 Users Say Thank You to Instructor For This Useful Post:
post #5 of 26 (permalink) Old 02-07-2015, 11:31 AM
Azblue's Avatar
That's not all that cold, Might want to have them take a look. At least that way you have documentation if anything goes wrong down the line.
SAVE THE CHROME!!!
Azblue is offline
post #6 of 26 (permalink) Old 02-07-2015, 11:42 AM
Guest
Quoted: 1133 Post(s)
You lucky dog...got one of the test 5.7L diesel motors Toyota motor company put out.
-Ignition timing could cause this.
Are you running a good quality fuel?
ColoradoTJ is offline
The Following 3 Users Say Thank You to ColoradoTJ For This Useful Post:
Mr. Creosote (02-07-2015), SP (02-09-2015), theoat (02-07-2015)
post #7 of 26 (permalink) Old 02-07-2015, 12:16 PM Thread Starter
Quoted: 8 Post(s)
I always run BP fuel. I'm about due for oil change so I'll have them check it out.
post #8 of 26 (permalink) Old 02-07-2015, 12:17 PM
caponeusmc's Avatar
Quoted: 54 Post(s)
maybe the engine is cold?
2014 SR DC LB
Tri State Club Member #33
caponeusmc is offline
The Following User Says Thank You to caponeusmc For This Useful Post:
post #9 of 26 (permalink) Old 02-07-2015, 12:33 PM
wyo700's Avatar
Quoted: 49 Post(s)
My engine sounds exactly the same when it's cold. I have a 2013. Engine oil level is fine. My dad has a 2007 sounds the same. It's fine as long as you have good oil pressure and it's running like it should. But if your worried take and have it looked at. I think all is ok.
wyo700 is offline
The Following User Says Thank You to wyo700 For This Useful Post:
post #10 of 26 (permalink) Old 02-07-2015, 12:51 PM
Quoted: 294 Post(s)
Some diesels are very loud.
Some diesels are very quiet.
Some gas engines are very loud.
Some gas engines are very quiet.
Generally, the Tundra 5.7 with cold engine start up is just a bit louder than a Ram Hemi 5.7. Most Ford and GM half tons are quieter on startup, both cold and hot.
On Tundra 5.7 cold start up the AIP will be active, so you will hear that; usually that noise last about 1-3 minutes. The clutch fan will be active so you will hear that; that should last about 2-5 minutes. Over the next 5 miles of driving it should then be a tad quieter than the Ram 5.7, but sill louder than most Ford’s and GM’s. Generally after 10 miles of driving I do not hear it much except when accelerating.
Also there is some valve train clicking or tapping that is very light and on my truck goes away within the first 5 miles or sooner.
It all seems normal to me.
2014 CM Limited 4x4 FFV
Off Road Pkg
Spray In Liner - Gulf States
KG Steps
JBL Upgraded Entune
Lux Pkg
BigTexTundra is offline
The Following 2 Users Say Thank You to BigTexTundra For This Useful Post:
post #11 of 26 (permalink) Old 02-07-2015, 02:47 PM
morser77's Avatar
Quoted: 1862 Post(s)
This is what mine sounded like about a week ago. It was pretty cold, close to zero. http://youtu.be/vglr0MuhY0Q
PHP Code:
2008 Tundra DoubleCab 5.7 TRD 295/70/18 Cooper ST Maxx BORA 1" wheel spacers TRD Rear sway bar TRD front skid plate TRD CAI Carrier bearing drop Front diff spacer BA Muffler 6" system Firestick II antenna Debadged BHLM
morser77 is offline
The Following User Says Thank You to morser77 For This Useful Post:
post #12 of 26 (permalink) Old 02-07-2015, 03:55 PM
Dirte''s Avatar
Quoted: 128 Post(s)
Wow! Almost sounds like loud fuel injectors. Is that from under the hood?
Build Log Here:
Dirte' is offline
The Following User Says Thank You to Dirte' For This Useful Post:
post #13 of 26 (permalink) Old 02-07-2015, 06:29 PM
bptracker29's Avatar
Had a knocking in mine that was worse in cold weather. Had about 33k miles when the noise became way too noticeable. Hoy Fox Toyota in El Paso did a fantastic job of identifying the problem. They said the #5 cylinder wrist pin (?) had too much clearance. Don't quote me on that...Anyhow, they ended up replacing the short block.
2013 Tundra Crewmax TSS OffRoad 4X4
bptracker29 is offline
The Following 2 Users Say Thank You to bptracker29 For This Useful Post:
Landcruiser888 (02-20-2015), Mr. Creosote (02-07-2015)
post #14 of 26 (permalink) Old 02-07-2015, 06:57 PM
Quoted: 41 Post(s)
I have a question for you guys, besides freezing temps, do you warm up your tundras a few minutes before driving it ? as a youngster I was always told you should never just start up and take off, so out of habit i always warm up my vehicles about 5 minutes before i take off. now that i have a new truck, i wonder if that's still relevant ? forgive me if thats a noob question
2015 Tundra 5.7 - DC SR5
Toyo AT2 Tires 33" + Worx 803 Satin Black Wheels 18x9
Bushwacker Fender Flares
Front Tints + Plastidipped Badges and Rear Bumper caps
Fortin Ax/Evo-One Remote Start & Alarm
gzaonas is offline
The Following User Says Thank You to gzaonas For This Useful Post:
post #15 of 26 (permalink) Old 02-07-2015, 07:03 PM
Quoted: 27 Post(s)
BP....
I haven't bought anything from them in years.
Anyone remember the Gulf Oil spill?
Didn't think so
thooks is offline
The Following User Says Thank You to thooks For This Useful Post:
