P0430 bank 2 - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 5 (permalink) Old 09-11-2019, 12:03 PM Thread Starter
RIjon's Avatar
Quoted: 539 Post(s)
P0430 bank 2
I have had this pop up twice now when under heavy acceleration. I clear the code and it stays away for a while.
I have a full custom SS Bam exhaust with cats (4) from the stock manifolds back.
The O2 sensors are stock and original with 100,000 miles on them.
I don’t know if it’s the sensors or a bad cat, but I guess it could be either. Maybe both?
I have techstream software and can run tests, but I don’t know what I’m looking for. I do know that if I run the PID app on my phone, both banks do not match. At all.
Any help would be appreciated. The cats are aftermarket per Keith. I believe they are magnaflow.
I also believe I have some pinhole leaks, but they are after the cats.
@dirtydeeds .
Thanks,
Jon
08 RCSB B00STED
10 T4R
RIjon is offline
post #2 of 5 (permalink) Old 09-11-2019, 12:24 PM
Quoted: 1216 Post(s)
That’s your passenger cat being ‘less efficient’ than the ecu is expecting.
Grab and 18mm anti fouler from Autozone. Drill it out. Install on sensor. And screw back into truck.
Give a call with any questions. 760-877-4234
dirtydeeds is offline
The Following User Says Thank You to dirtydeeds For This Useful Post:
RIjon (09-11-2019)
post #3 of 5 (permalink) Old 09-11-2019, 07:49 PM Thread Starter
RIjon's Avatar
Quoted: 539 Post(s)
Thanks Keith
I want that on the front or the rear sensor?
08 RCSB B00STED
10 T4R
RIjon is offline
post #4 of 5 (permalink) Old 09-12-2019, 12:08 AM
ViktorG's Avatar
Quoted: 331 Post(s)
Rear sensors monitor the cat.
Front ones control the air fuel ratio.
So you need to put the cheater on the rear sensor on the affected bank.
2010 RCSB ([email protected] on NOS) - AWD conversion, Pauter rods, JE 8.5:1 pistons, Ti int & SS exh valves, Ti retainers, 5 angle valve job, P&P heads, TRD SC w/ 50mm pulley, ASP crank pulley, 84mm TB, SABM, IPT VB, JBA LTs, Killer Chiller, 1.25 Gal IC tank, Frozenboost 101 HE, IKH-24 plugs, A1000 FP, 2"/4" Belltech drop, weight reduction, NOS
ViktorG is offline
RIjon (09-12-2019)
post #5 of 5 (permalink) Old 09-12-2019, 10:12 AM
Exactly. Rear sensor.
RIjon (09-12-2019)
