Upgrading injecters for ~ 650hp? - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 11 (permalink) Old 02-21-2019, 07:02 AM Thread Starter
Quoted: 52 Post(s)
So I finally managed to conclude my project. Built a forged engine with trd SC, and ASP pulleys (modified 50mm SC pulley), and two DW400 fuel pumps. Got it tuned by HP tuners. Pretty happy with the performance, but I got lean spikes before shifting at WOT. Since the trd injectors duty cycle are maxed out, I am thinking about upgrading. Any advice which injectors to get. Thanks in advance.
Flex Fuel 2016 | Edition 1794 CM | TRD CAI | Valve body Mod | LT ARH | | 20" Method Roost wheels
2012 rcsb | TRD SC | 18" 41 series Procomp wheels| Valve body Mod | JBA Long tube headers | Airaid CAI | 2/4" SOSperformance LK | Caltracs TB
riskydude is offline
The Following User Says Thank You to riskydude For This Useful Post:
ViktorG (02-21-2019)
post #2 of 11 (permalink) Old 02-21-2019, 07:04 AM Thread Starter
Quoted: 52 Post(s)
Upgrading injectors for ~ 650hp?
Sorry for the typo in the title, "injecters"should read injectors
post #3 of 11 (permalink) Old 02-21-2019, 09:22 AM
ViktorG's Avatar
Quoted: 289 Post(s)
Awesome work man!
Is it a custom made blower pulley or the regular one ASP and URD sell?
Got any dyno numbers from it yet?
https://www.ebay.com/itm/8-550cc-Fue...-/271965920347
These are supposed to be a direct fit, but I have not used them personally.
Or, if you have the money, you can have a set of custom fuel rails made that can take any injector you want.
2010 RCSB ([email protected] on NOS) - AWD conversion, Pauter rods, JE 8.5:1 pistons, Ti int & SS exh valves, Ti retainers, 5 angle valve job, P&P heads, TRD SC w/ 50mm pulley, ASP crank pulley, 84mm TB, SABM, IPT VB, JBA LTs, Killer Chiller, 1.25 Gal IC tank, Frozenboost 101 HE, IKH-24 plugs, 325 LPH AM FP, 2"/4" Belltech drop, weight reduction, NOS
ViktorG is online now
post #4 of 11 (permalink) Old 02-21-2019, 01:11 PM Thread Starter
Quoted: 52 Post(s)
Originally Posted by ViktorG View Post
Awesome work man!
Thanks I will check the link.
It is just the TVS 1900 based blower with ported inlet and 84mm TB. I ordered a set of pulleys from ASP, managed to increase the boost to 9 from 6 psi. A friend of mine has gevin me even a smaller SC to try (50mm). Now I can see 12 psi occasionally. Forgot to mention that I am using snow performance stage 2 W/M kit.
597hp on dynojet using 95 octane pump fuel.
post #5 of 11 (permalink) Old 02-21-2019, 01:20 PM
ViktorG's Avatar
Quoted: 289 Post(s)
How did you manage to install those in the tank?
Any pictures?
post #6 of 11 (permalink) Old 02-21-2019, 01:49 PM Thread Starter
Quoted: 52 Post(s)
Any pictures?
A local shop installed it for me, it requires modifications to the stock housin/canister. Unfortunately no pics.
post #7 of 11 (permalink) Old 02-21-2019, 02:36 PM
ViktorG's Avatar
Quoted: 289 Post(s)
Wow, that's a LOT of fuel delivery capacity considering all 8 injectors together only flow 250 lph max.
I think 800 lph from your twin pumps is good for close to 2000 hp as long as the fuel lines are increased in size.
Where did your friend get the 50mm pulley?
I am actually having a 2" (51mm) one custom made by a machine shop this month.
Have you done any quarter mile runs?
post #8 of 11 (permalink) Old 02-21-2019, 06:15 PM
Quoted: 557 Post(s)
changing injectors unless your tuner can modify it,may not address the lean issue at shifting.the ecu pulls power right before shifts for transmission longevity,
it will give you more overhead room in all other cases however,always a good thing.
restosud is offline
post #9 of 11 (permalink) Old 02-21-2019, 07:46 PM Thread Starter
Quoted: 52 Post(s)
He got it customised by ASP if I remember correctly. You wouldn't want to try quarter miles specially with normal tires and Auburn lsd installed 🤣. Haven't tried it but would say mid/high 12s.
Yes luckily. The tuner recommended either Dynamics 725ID or DW 600c injectors. I would prefer direct fits. He also asked me to check the following link:
https://www.fiveo-racing.com/product...xtended-nozzle
post #10 of 11 (permalink) Old 02-23-2019, 10:25 PM
Quoted: 59 Post(s)
so forged rods/pistons? what rods and pistons? stock size or re-sleeved?
motorhead_1 is offline
post #11 of 11 (permalink) Old 02-25-2019, 04:48 AM Thread Starter
Quoted: 52 Post(s)
Wiseco rods and pistons, 9.8:1 compression ration if I remember correctly, Block bored 0.025".
