Improving Fuel Efficiency (MPG) - Page 4 - TundraTalk.net - Toyota Tundra Discussion Forum
post #46 of 75 (permalink) Old 10-15-2017, 10:34 AM
Quoted: 57 Post(s)
Originally Posted by EngineeringNick View Post
And I believe the point of the electric fan is that it is battery driven opposed to directly adding to the engine load.
The point of an electric fan is to remove parasitic losses. The electric fan only turns when it is actually needed.
2012 Silver Sky Metallic Sequoia SR5 4WD 4.6L
TRD Pro eng skid, Or-Fab trans skid, custom transfer case skid, RCI gas tank skid, 1.75" lift with 6112 on lowest notch, Wheeler's Superbumps (front), Revtek 441R & 5100 (rear), Michelin Defender LT275/70R18 on MB Chaos +25, 3rd Row Removed
MtnClimber is offline
post #47 of 75 (permalink) Old 10-15-2017, 11:43 AM
rruff's Avatar
Quoted: 469 Post(s)
I was looking to see if anyone had tried to modify the fuel injection process to inject vapor from the get-go instead of trying to spray a mist to get to the same result.
So you vaporize the fuel (by heating it?) and then inject it? Wouldn't that require a completely different fuel and intake system and ECU, to supply a gaseous rather than liquid fuel? And this is one of those things I'm sure Toyota would have done if it provided a measurable improvement.
When it comes to power input to run the generator I was thinking of trying to harness the motion of the wheels to start the generator similar to how the starter helps start the engine.Once the generator is on it shouldn't require a constant power source - if you understand how permanent magnet generator work...
Harnessing the motion of the wheels? Where is the energy that is making the wheels turn coming from, and how would you harness it?
If power is coming out, then *more* power is going in from somewhere. That's basic physics. It's a question of efficiency, output/input, which is always < 1. No free lunch, again.
The battery *stores* energy. The energy it receives comes from the alternator, which is driven by the engine. And again, there is a loss due to inefficiency which is substantial. Probably over 50% in this case (alternator+battery+fan motor).
And @MtnClimber , isn't the fan on the Tundra already controlled with a clutch so it is only driven when needed? This has been common on vehicle fans for a long time.
rruff is offline
post #48 of 75 (permalink) Old 10-15-2017, 12:25 PM
Quoted: 370 Post(s)
...alternately, I was looking to see if anyone had tried to modify the fuel injection process to inject vapor from the get-go instead of trying to spray a mist to get to the same result...
No, not even the manufacturers with virtually unlimited resources and knowledge have successfully done it, and it probably has to do with Boyle's Law and the vapor pressures of hydrocarbon compounds.
Gasoline is a "middle of the barrel" product and contains a range of hydrocarbons, mostly C4-C12. In any event, they all remain liquid at typical ambient temperatures on earth, with some negligible loss at higher temps. Take the charge volume of a typical fuel injector, vaporize it (how to do this is "left to others"), and what do you have...probably a fraction of a cubic foot (I have no idea, and I'm not doing the calculation). Imagine trying to get that fuel vapor charge into a typical cylinder displacement once you've added enough air to get a stoichometric ratio for combustion.
Well, if you raise the pressure ENOUGH...No, wait a minute here, are we talking about injecting the fuel charge UPSTREAM of a supercharger!? Not exactly something which the NHTSB will endorse. But, theoretically, maybe it would then all squeeze into a volume expanding and contracting 5000 times a minute. No, wait, if you raise the charge pressure, then the gasoline will just go back toward a liquid state...and you're right back where you started.
No, Nickster, I think you need to apply some of that engineering training you received and do some thinking of your own instead of barnstorming and throwing out crap ideas for us to think about.
Then there's always liquid hydrogen and liquid oxygen...uh, no, that's already been done, but it was the Saturn V. The astronaut said he was literally sitting on the tip of a bomb, and he was right. Brave guys.
(Edit: Oops, should have fact-checked before I spoke...the first stage Saturn V fuel was actually a form of kerosene with liquid oxygen as the oxidizer, so liquid hydrogen IS still on the table. )
OldGuy43 is offline
post #49 of 75 (permalink) Old 10-15-2017, 01:56 PM
Quoted: 57 Post(s)
Yes, but the viscous clutch only partially disengages when not needed. There are still friction losses from the fluid coupling and fan constantly turning. Of course, the electric fan also has inefficiencies due to losses in the electrical conversion/storage/usage. According to the "ultimate authority," Wikipedia:
The conversion of mechanical energy to electricity and back to mechanical rotary power with a fan motor is less efficient than a direct mechanical connection, but this is more than compensated by greater control of an electric fan through electronic thermostatic controls which can turn the fan completely off when the engine temperature is below the setpoint.
Is the efficiency advantage of an electric fan over a clutch fan significant? Probably not.
The Following User Says Thank You to MtnClimber For This Useful Post:
rruff (10-15-2017)
post #50 of 75 (permalink) Old 10-15-2017, 10:01 PM
Quoted: 100 Post(s)
Am I the only one that wants to see this guy completely re-engineer the tundra, spending probably enough to buy a new prius; only to get 18 mpg in the end...
2014 SR Work Truck Package Double Cab 4x4 4.6L Magnetic Grey Tundra.
Official tri-state club member #48
dforlenza is offline
The Following User Says Thank You to dforlenza For This Useful Post:
Wacked (10-15-2017)
post #51 of 75 (permalink) Old 10-15-2017, 10:40 PM
Quoted: 185 Post(s)
I'm scavenging here, but I see lower the truck, lower rolling resistance tires, and no fat chicks... Understand this isn't about saving money...
I agree. Lowering and low rolling resistance tires...preferably more narrow. (You'll never find wide tires on any economy car, so dont push the physics of a wider tire having less psi on the road because it doesn't equate to less rolling resistance!)
Money is where reality sets in. So you lowered the truck and added some more narrow eco tires. You might gain 1-2mpg long term average, tops. And how much did you spend to get it?
Do the math. Will you ever see a return on your investment within your or the trucks lifetime? Nope.
You bought a truck. If you want max MPG, drive it slow on the highway, coast to a stop for as long as possible, and get up to speed quickly but not aggressively.
RinconVTR is offline
post #52 of 75 (permalink) Old 10-15-2017, 11:01 PM
Quoted: 57 Post(s)
Space shuttle main engines burned liquid hydrogen and liquid oxygen from that lil' external tank.
post #53 of 75 (permalink) Old 10-15-2017, 11:07 PM
Quoted: 370 Post(s)
Ha! White Sands guy, am I right?
OldGuy43 is offline
post #54 of 75 (permalink) Old 10-15-2017, 11:44 PM
Quoted: 57 Post(s)
Nah, Idaho guy, never been south of Los Alamos.
post #55 of 75 (permalink) Old 10-15-2017, 11:47 PM
rruff's Avatar
Quoted: 469 Post(s)
Originally Posted by RinconVTR View Post
I agree. Lowering and low rolling resistance tires...preferably more narrow. (You'll never find wide tires on any economy car, so dont push the physics of a wider tire having less psi on the road because it doesn't equate to less rolling resistance!).
Wider tires actually do have slightly lower resistance though, all else being equal.
It isn't going to make a lot of difference, but skinny tires on a Tundra look like shit. Might as well make it look and handle decent on the road while you are at it, eh?
That would easily pay for itself if you kept the truck 10 years (~$2500 in gas savings). Street tires would even be cheaper and last longer than the ones most of us "upgrade" to.
rruff is offline
post #56 of 75 (permalink) Old 10-16-2017, 01:25 AM
gcomptech's Avatar
I have a 2012 DC 4.6L. I have had it since new. I installed a K&N CAI and MagnaFlow cat-back duals. I went from 14-16 mpg to 16.5-18 mpg. Plus, it screams. Many people on this forum, and others, have said that those mods don't make a difference. They did for me. Next up will be BAMs.
Sent from my SM-N950U using Tapatalk
2012 Tundra Double-Cab base work truck. K&N CAI, MagnaFlow cat-back duals, Linex bed liner, Black powder-coated steps, U.S. Rack Weekender. It's a work truck and it does that better than any truck I've ever owned.
gcomptech is offline
post #57 of 75 (permalink) Old 10-16-2017, 01:51 AM
rruff's Avatar
Quoted: 469 Post(s)
Modding the intake and exhaust at least has the potential for reducing pumping losses. Problem is, when you are in "high mpg" mode it will be at low power levels, where these losses are minimal.
rruff is offline
post #58 of 75 (permalink) Old 10-16-2017, 05:58 AM
RIjon's Avatar
Quoted: 532 Post(s)
This thread has gone full retard
08 RCSB B00STED
10 T4R
RIjon is offline
The Following 3 Users Say Thank You to RIjon For This Useful Post:
Azblue (10-16-2017), Big Shasta (10-29-2017), RingSteel (10-17-2017)
post #59 of 75 (permalink) Old 10-16-2017, 09:04 AM
Quoted: 185 Post(s)
A new set of wheels and tires and complete cost to lower the truck you see being only $2500 and realistically getting a full 2mpg better than stock?
I see $2500 being low, a full 2mpg being high, the better low rolling resistance tire compounds wear faster than anything else I know, wider tires get you into performance compounds that rarely come molded in LRR compounds for good reason.
I cannot believe I got sucked into this thread.
The Following User Says Thank You to RinconVTR For This Useful Post:
Wacked (10-16-2017)
post #60 of 75 (permalink) Old 10-16-2017, 12:21 PM
rruff's Avatar
Quoted: 469 Post(s)
You don't need new wheels, and tires are something you need to buy anyway. And it was a 10% improvement to get $2500 savings in 10 years, not 2mpg.
Just as an example for a tire, the Michelin Premier LTX 275 /60 R20 (33") was tested to have the lowest rolling resistance at Consumer Reports, and has a 60k mile warranty. https://www.discounttire.com/buy-tir...er-ltx/p/31566
If you have 18" wheels and want to go full eco, these are probably your best bet: Michelin Energy Saver A/S - Size: P265/65R18 (31.5"). Only $124 here: https://www.tirerack.com/tires/tires...ESAS&tab=Sizes
rruff is offline
