2 engines blown in 2 months... Forged 5.7 build thread - Page 6 - TundraTalk.net - Toyota Tundra Discussion Forum
post #76 of 140 (permalink) Old 05-07-2017, 11:40 PM
Quoted: 59 Post(s)
any updates?
motorhead_1 is offline
The Following 2 Users Say Thank You to motorhead_1 For This Useful Post:
Mr. Creosote (04-05-2018), Wacked (05-07-2017)
post #77 of 140 (permalink) Old 05-09-2017, 01:03 PM Thread Starter
ViktorG's Avatar
Quoted: 288 Post(s)
Originally Posted by motorhead_1 View Post
any updates?
I realized that after putting a 12 inch lift and 37's on the DCLB truck, there is no way to ever make it fast again, no matter how much power it puts out.
So I ended up buying a 2010 RCSB and picked it up on the weekend.
The new forged motor will go into that truck.
However, I have to put that project on hold for a while until I pay off the money that I spent on the new truck.
2010 RCSB ([email protected]) - AWD conversion, Pauter rods, JE 8.5:1 pistons, Ti int & SS exh valves, Ti retainers, 5 angle valve job, P&P heads, TRD SC w/ 50mm pulley, ASP crank pulley, 84mm TB, SABM, IPT VB, JBA LTs, Killer Chiller, 1.25 Gal IC tank, Frozenboost 101 HE, IKH-24 plugs, 325 LPH AM FP, 2"/4" Belltech drop, weight reduction
ViktorG is offline
The Following 3 Users Say Thank You to ViktorG For This Useful Post:
Mr. Creosote (04-05-2018), RIjon (05-09-2017), Wacked (05-09-2017)
post #78 of 140 (permalink) Old 05-09-2017, 01:06 PM
Chief of Grammar Police
Wacked's Avatar
Quoted: 3194 Post(s)
Born in TEXAS built by TEXANS
aFe Stage II Pro-S Dry Si
Wacked is online now
The Following User Says Thank You to Wacked For This Useful Post:
post #79 of 140 (permalink) Old 05-10-2017, 02:05 AM
Quoted: 59 Post(s)
well, there is that....
completely understandable. Time to go the an LSX platform for more power..... J/K
i'm starting to look into gathering bits for a forged build myself.
i got beat up the other day by a CTS-V. need to get more power/displacement.
of course, i had a good suspicion it was over when the electric cutouts opened up.....
Mr. Creosote (04-05-2018), Wacked (05-10-2017)
post #80 of 140 (permalink) Old 04-05-2018, 03:19 PM Thread Starter
ViktorG's Avatar
Quoted: 288 Post(s)
any updates?
Had to put the project on hold due to having another baby last year and buying the 2010 RCSB.
Finally got some money together.
The block, crank, rods and pistons are going to Muscle Motors in Strathmore, AB, Canada to have the machine work done and the rotating assembly balanced.
They should be finished in a month or two, hopefully this motor will be in the truck later this year.
ViktorG is offline
Mr. Creosote (04-05-2018), RIjon (04-06-2018), Wynnded (04-05-2018)
post #81 of 140 (permalink) Old 06-13-2018, 06:41 AM
Quoted: 52 Post(s)
Hi Vitor, Thanks for sharing your experience. Any update?
I myself got a 2012 supercharged RCSB. I am interested in adding more HP and not really sure where to start. Blowing engines are nightmares so I want to start with forged internals surely.
Flex Fuel 2016 | Edition 1794 CM | TRD CAI | Valve body Mod | LT ARH | | 20" Method Roost wheels
2012 rcsb | TRD SC | 18" 41 series Procomp wheels| Valve body Mod | JBA Long tube headers | Airaid CAI | 2/4" SOSperformance LK | Caltracs TB
riskydude is offline
The Following User Says Thank You to riskydude For This Useful Post:
Mr. Creosote (06-25-2018)
post #82 of 140 (permalink) Old 06-14-2018, 07:58 AM
Quoted: 160 Post(s)
need more fuel while spraying
2018 TRD OffRoad 5.7 gasser
24hrsparkey is offline
The Following 2 Users Say Thank You to 24hrsparkey For This Useful Post:
Mr. Creosote (06-25-2018), Wacked (06-14-2018)
post #83 of 140 (permalink) Old 06-14-2018, 08:44 AM
Big Shasta's Avatar
Quoted: 1887 Post(s)
Pretttyyyyy sure he knows about AFRs...But thanks.
2012 Pearl White 4x4 Sequoia Platinum.
I drink a whiskey drink
I drink a vodka drink
and when I have to pee
I use the kitchen sink
Big Shasta is offline
The Following 2 Users Say Thank You to Big Shasta For This Useful Post:
Mr. Creosote (06-25-2018), ViktorG (06-25-2018)
post #84 of 140 (permalink) Old 06-14-2018, 12:20 PM
Quoted: 160 Post(s)
No probl.
fact remains it went lean and or needs to retard the timing at the top end . IE: melted piston.
Under boost and spray ,, the timing and fuel curve is very complex . Its hard enough getting it close normally aspirated .
Good day , Gents.
The Following User Says Thank You to 24hrsparkey For This Useful Post:
post #85 of 140 (permalink) Old 06-25-2018, 05:58 PM Thread Starter
ViktorG's Avatar
Quoted: 288 Post(s)
The block is still in the machine shop.
Forged rods and pistons will run you around 3 grand for the parts.
If you want serious power, start with that.
Or you can just slap a couple of blower pulleys onto the engine and enjoy it while it lasts.
ViktorG is offline
post #86 of 140 (permalink) Old 06-27-2018, 11:50 PM
Quoted: 52 Post(s)
Just ordered forged pistons and rods from Wiseco. Next in the wish list: springs, valves and retainers.I will start a new thread once I get all the parts and proceed with the engine build. Good luck, keep us posted.
Mr. Creosote (06-27-2018)
post #87 of 140 (permalink) Old 07-08-2018, 02:47 AM Thread Starter
ViktorG's Avatar
Quoted: 288 Post(s)
The block has been bored and decked.
Waiting on the main bore honing and rotating assembly balancing.
I have also decided to have the machine shop do the short block bearing clearancing and assembly.
Originally I was going to do it, but I think they will do a better job vs my "made in China" bore gauges and micrometers.
ViktorG is offline
Big Shasta (07-09-2018), Mr. Creosote (07-08-2018), sundance (07-09-2018)
post #88 of 140 (permalink) Old 07-10-2018, 03:16 PM
Quoted: 55 Post(s)
And you are going to be tuning this new engine how?
freudie1 is offline
The Following User Says Thank You to freudie1 For This Useful Post:
Mr. Creosote (07-10-2018)
post #89 of 140 (permalink) Old 07-10-2018, 03:54 PM Thread Starter
ViktorG's Avatar
Quoted: 288 Post(s)
For now, stock ECU.
Later, custom DAP tune on the dyno.
ViktorG is offline
The Following 2 Users Say Thank You to ViktorG For This Useful Post:
Mr. Creosote (07-10-2018), Wacked (07-10-2018)
post #90 of 140 (permalink) Old 07-24-2018, 05:30 AM
Quoted: 52 Post(s)
@ViktorG how is your project going?
I have noticed that there is an oil leak on my valves covers both sides so I went for a compression test.
No. 3 at 100 PSI so I guess it has to do with the oil ring.
I may not have a better chance to start building a forged engine. Almost got a set of pistons and rods from Wiseco. My questions is do I really need performance valves and springs?
Wacked (07-24-2018)
