Super chargers and traction control - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 16 (permalink) Old 05-03-2015, 10:47 AM Thread Starter
T-Ville Tundra's Avatar
Quoted: 3 Post(s)
I just had my super charger installed and am living on traction control. Now I know the obvious, that it can be turned off. And yes I had the center point calibration done. As well as I KNOW it's not REALLY comparable but I did have a FJC and had the TRD SC on it so I know some of the characteristics. But is there anything else I can do to stop the TC from engaging every time I accelerate? I'm talking like at 40-50 MPH merging onto the interstate if I accelerate hard it kicks in. And I have a 3/1 lift with 295/70/18's so I know I'm NOT SPINNING TIRES. Any input would greatly be appreciated.
T-Ville Tundra is offline
The Following User Says Thank You to T-Ville Tundra For This Useful Post:
Mr. Creosote (05-03-2015)
post #2 of 16 (permalink) Old 05-03-2015, 12:07 PM
SC Tuna's Avatar
Quoted: 232 Post(s)
You just gotta learn how to drive again. I can kick the rear out anytime I want with everything on.
SC Tuna is offline
The Following User Says Thank You to SC Tuna For This Useful Post:
post #3 of 16 (permalink) Old 05-03-2015, 01:18 PM
TRDPRO1's Avatar
Quoted: 36 Post(s)
Turn off the traction control, I have a 2015 and I press and hold the traction button for about 3 seconds until the TC and LSD light comes on for a second or two. After the lights goes out, press and hold the TC button again for about 3 second until it reads
"traction control off" and go have some fun!
The traction control will reset itself everytime you turn off the truck and you'll have to do it again. BTW the truck needs to be running and foot on the brake in gear or not.
TRDPRO1 is offline
The Following User Says Thank You to TRDPRO1 For This Useful Post:
post #4 of 16 (permalink) Old 05-03-2015, 01:35 PM
2012CMINCO's Avatar
Quoted: 917 Post(s)
Sounds like OP issue is ZPC related. OP, I know you said you had that done but I would do it again. If you are confident you're not breaking traction yet are seeing traction control issues I would do it again just to be sure.
2012CMINCO is offline
The Following 2 Users Say Thank You to 2012CMINCO For This Useful Post:
Mr. Creosote (05-03-2015), riccnick (05-03-2015)
post #5 of 16 (permalink) Old 05-03-2015, 01:40 PM
mdl
Premium MemberPremium Member
mdl's Avatar
Quoted: 398 Post(s)
@T-Ville Tundra , As stated you have to re-learn some driving habits. You could also drive with alsd on to have traction and not have the engine cutout on you.
Supercharged 2007 DC 4X4, ASP SC pulley, JBA LT's, 3 inch dual race exhaust by Dirtydeeds, Shift Kit, Auburn LSD, AEM 325 FP, SABM, Icon, Camburg UCA, Coahbuilder1
mdl is offline
The Following User Says Thank You to mdl For This Useful Post:
post #6 of 16 (permalink) Old 05-03-2015, 01:59 PM
planomateo's Avatar
Quoted: 161 Post(s)
You need to disable the traction control (aka nannies) every time you start the truck.
What @TRDPRO1 said above.
(SOLD) 2010 CrewMax SR5
planomateo is offline
The Following User Says Thank You to planomateo For This Useful Post:
post #7 of 16 (permalink) Old 05-03-2015, 03:52 PM Thread Starter
Quoted: 3 Post(s)
I will go have the ZPC done again just to be sure that's not the issue. Just wondering when saying "learn to drive the truck again" that doesn't mean NO FULL THROTTLE with the LSD, TC etc. on does it? That no matter the circumstance you cannot run full throttle without them kicking in and killing power? Example: driving 60 mph on interstate and flooring it to pass in a hurry? Not trying to be hard headed, just hard to believe that it's NORMAL to kick in under conditions like that.
OH YEH, AND THANKS FOR THE 411 EVERYBODY!!!
The Following 2 Users Say Thank You to T-Ville Tundra For This Useful Post:
post #8 of 16 (permalink) Old 05-03-2015, 05:18 PM
mdl
mdl's Avatar
Quoted: 398 Post(s)
It's more of easing into the throttle than punching it. Definitely try the ZPC again as it shouldn't be engaging under your circumstances.
mdl is offline
The Following 3 Users Say Thank You to mdl For This Useful Post:
Mr. Creosote (05-03-2015), riccnick (05-03-2015), SC Tuna (05-04-2015)
post #9 of 16 (permalink) Old 05-03-2015, 08:02 PM
Quoted: 208 Post(s)
Second the ZPC re-do... My TC rarely comes on, usually only on a turn when road it bumpy or I am hard on throttle, and definitely doesn't come on when merging on to the highway. What you're experiencing is not normal.
2015 Tundra Crewmax, Limited, 4x4, TRD
TRD Supercharger, ASP 2.35", TRD Exhaust & Rear Sway
JL Audio 10TW3 (x2)
LS1Steve is offline
The Following 2 Users Say Thank You to LS1Steve For This Useful Post:
post #10 of 16 (permalink) Old 05-31-2015, 12:07 AM
Quoted: 22 Post(s)
Hey T-Ville, did the second ZPC solve your problem??? I am on a stock height/tire TRD Pro but experiencing the same issue with the TC interference. I haven't tried disabling through the button...I am hoping I don't have to hold down a button for 6 seconds every time I start the truck, I could be doing 80mph by then
AKMuskeg is offline
The Following User Says Thank You to AKMuskeg For This Useful Post:
Mr. Creosote (05-31-2015)
post #11 of 16 (permalink) Old 05-31-2015, 06:48 AM
kxed's Avatar
Quoted: 35 Post(s)
may have to shim the yaw rate sensor
OME 612, LR UCA, +3 CB Shackles and Bushings, 18X9 +30mm Ultra Drifter Wheels, 295/70R18 Nitto Terra Grappler G2, BAmuffler Dual Exhaust, BullyDog Platinum, Morimoto Mini D2S Apollo 3.0 shield, LED Concepts Halo's
kxed is offline
The Following User Says Thank You to kxed For This Useful Post:
post #12 of 16 (permalink) Old 06-01-2015, 06:47 AM Thread Starter
Quoted: 3 Post(s)
I'm taking it today to have it done. As well as I bought the Hypertech speedometer calibrator and having it installed. I'll keep you posted.
post #13 of 16 (permalink) Old 06-06-2015, 05:31 PM Thread Starter
Quoted: 3 Post(s)
UPDATE: Picked truck up with Hypertech done and speedometer is better, (only 1-2 mph off) but the Distance to empty and the avg MPG is still OFF as it was from the time I lifted the truck. If ANYONE knows a fix for this problem I'd greatly appreciate the info????
Mr. Creosote (06-08-2015)
post #14 of 16 (permalink) Old 06-08-2015, 12:55 PM
Quoted: 208 Post(s)
Once they load the SC tune (Toyota tune, when install is done) say goodbye to accurate mpg gauge. Mine was +/- 0.1 when NA, but after the tune, it is off by a lot. Not consistently either. I've been off by as little as 4.8mpg and as much as 6mpg, but seems to be most frequently off by +5.3mpg.
JL Audio 10TW3 (x2)
LS1Steve is offline
The Following User Says Thank You to LS1Steve For This Useful Post:
post #15 of 16 (permalink) Old 06-08-2015, 06:40 PM
Quoted: 22 Post(s)
Did that second ZPC solve your traction control issue?
Thx.
AKMuskeg is offline
