EXCLUSIVE JBA long tube headers with true duals X pipe either 2.5" or 3" pipes - Page 12 - TundraTalk.net - Toyota Tundra Discussion Forum
post #166 of 193 (permalink) Old 10-07-2013, 02:39 PM
RichN's Avatar
Quoted: 3 Post(s)
Keith, I'm about ready to pull the trigger on a complete system. The one thing holding me back is a cel with no cats. Are the spacers good enough to fool the ecu or would I need simulators? I have a 13.
Thanks.
RichN is offline
The Following 2 Users Say Thank You to RichN For This Useful Post:
Mr. Creosote (10-07-2013), Wacked (10-07-2013)
post #167 of 193 (permalink) Old 10-07-2013, 03:01 PM Thread Starter
Quoted: 1213 Post(s)
I'm having great success with the spacers. Not quite 100% but will be soon.
dirtydeeds is offline
The Following 3 Users Say Thank You to dirtydeeds For This Useful Post:
Mr. Creosote (10-07-2013), RichN (10-07-2013), Wacked (10-07-2013)
post #168 of 193 (permalink) Old 10-09-2013, 03:28 PM
Keith,
Would this replace the o2 sim that I bought from URD that is not working? Let me know I keep getting that P0138 voltage code that I talked to you about a week or so ago.
Projectx24 is offline
The Following 2 Users Say Thank You to Projectx24 For This Useful Post:
Mr. Creosote (10-09-2013), Wacked (10-09-2013)
post #169 of 193 (permalink) Old 10-09-2013, 03:32 PM
Quoted: 45 Post(s)
Originally Posted by Projectx24 View Post
Keith,
I had voltage code on my o2 sensors..exhaust leak was my issue. .v clamp wasnt sealed. .took apart. Rtv around inside pipe and it was gone.. but I'm starting to hear exhaust leak again
that1seven is offline
The Following 2 Users Say Thank You to that1seven For This Useful Post:
post #170 of 193 (permalink) Old 10-09-2013, 03:37 PM
That could be the problem with mine to now that you bring that up. I had a leak on the drivers side header to mid pipe. I had a hard time getting them together properly. I will have to check if a leak has popped back up.
When I took them back apart the 1st time to try and fix the leak I sanded down the midpipe with a little sandpaper and got it to fit tighter but not all the way snug.
Did using the Rtv sealant help?
post #171 of 193 (permalink) Old 10-09-2013, 05:40 PM
Quoted: 45 Post(s)
Yeah rtv did.. Loosen up your exhaust. .vclamp off and loosen y pipe bolts.. tighten clamp first than the y part last.
post #172 of 193 (permalink) Old 10-09-2013, 06:24 PM Thread Starter
Exactly
V bands are proving to be finnicky. But by tightening the v band first you make that seal. The 2 hole flange seals no matter what.
The Following 2 Users Say Thank You to dirtydeeds For This Useful Post:
post #173 of 193 (permalink) Old 10-09-2013, 06:50 PM
Going to try that this Sunday and see if it fixes the p0138 I keep getting. I unplug the battery to clear it and it comes back on after roughly 200-300 miles.
I should just get them welded together and be done with the v-clamps.
Side note I got spoolins shift kit installed and it kicks ass with the combination of the jba's and 3" race exhaust. No more soft slow shifts. But it's going to take some time to get used to the 2-3 3-4 pushes you back for sure the 1-2 isn't to bad.
post #174 of 193 (permalink) Old 10-09-2013, 07:19 PM
Quoted: 45 Post(s)
I'm pissed I called spoolin and he's 2 months behind .. and everyone has the damn shift kit
u don't have the knock off techstream? I use that to check codes and clear codes
post #175 of 193 (permalink) Old 10-09-2013, 07:24 PM
Ya I was 4-5 on his list and a couple guys passed it up. I just put my valve body back in the mail to him this morning. Now I'm working on getting a supercharger next.
No I don't have that. But I have basically worthless bd tuner still in the box I believe I can use to check and clear codes with.
post #176 of 193 (permalink) Old 10-16-2013, 12:38 AM
LuisC's Avatar
Do you live in an area where they salt the roads in winter? Also, are we going to ballz out power or just sound? Reason I ask, you CAN have both
Corsa makes a sweet setup for tundras, but it's tuned for use after stock manifolds and stock cats. If you put one of those after Jba long tubes the sound won't be as desirable. Also, I've tested Jba long tubes using single exhaust versus dual exhaust. Dual exhaust is by far better. Not only that, but dual 3"!! That's right, dual 3" exhaust on a naturally aspirated daily driver (off road of course) works best on these trucks.
We make a dual 3" exhaust system with X pipe and any style of tailpipes you could want (Rcsb is somewhat limited due to space limitations) and it all bolts right on to the truck like factory parts would.
I can make your truck sound really good at full throttle, yet quieter than a catback at 70mph.
Keith,
I am confused are you talking about true 3" for a NA Tundra 5.7L here.
Mods:TRD Front Lowering Suspension(2"), TundraRacing Rear Flip Kit(4"), 20" on Nitto NT420S, Tint all around, DirectJG HID 8K Lows and Fogs, JL Audio 500/1 and 2x8W7 Stealthboxes(built by me), Backup Cam, Clear Bra, Viper 5901 with 2 DEI 530T's,506T,508D,520T, Tailgate lock and Tailgate Unlocker, BackFlip G2.
LuisC is offline
The Following 3 Users Say Thank You to LuisC For This Useful Post:
dirtydeeds (10-16-2013), Mr. Creosote (10-16-2013), Wacked (10-16-2013)
post #177 of 193 (permalink) Old 10-16-2013, 12:50 AM Thread Starter
Originally Posted by LuisC View Post
Keith,
yessir. Dual 3" with X pipe on a n/a Tundra. This makes 49hp 89tq to the wheels over stock. Zero loss of bottom end tq, there is actually a ton of gain!!
The Following 4 Users Say Thank You to dirtydeeds For This Useful Post:
H2O MAN (10-29-2018), mdl (10-16-2013), Mr. Creosote (10-16-2013), Wacked (10-16-2013)
post #178 of 193 (permalink) Old 10-16-2013, 02:16 AM
mdl
Premium MemberPremium Member
mdl's Avatar
Quoted: 398 Post(s)
Hey Keith, So how far out are we? I know your waiting to mock up the TRD exits. I'm clearing the garage out for the install...
Thanks,
Mike
mdl is offline
The Following 2 Users Say Thank You to mdl For This Useful Post:
post #179 of 193 (permalink) Old 10-16-2013, 02:26 AM Thread Starter
almost there. headers are in. mandrel bends are in. mufflers are made. just need to put it all together.
post #180 of 193 (permalink) Old 10-16-2013, 09:41 PM Thread Starter
Thanks,
Mike
mid pipes and catback are done just need to build tailpipes. Hope to get that done before end of week but it's slipping away quickly. early next week worse case scenario
Mr. Creosote (10-17-2013), Wacked (10-16-2013)
