TRD Rear Sway Bar? - Page 3 - TundraTalk.net - Toyota Tundra Discussion Forum
post #31 of 51 (permalink) Old 05-27-2018, 09:43 AM
Quoted: 6 Post(s)
Best upgrade ever.
Sent from my XT1585 using Tapatalk
Yota3242 is offline
The Following User Says Thank You to Yota3242 For This Useful Post:
Mr. Creosote (05-27-2018)
post #32 of 51 (permalink) Old 05-27-2018, 12:15 PM
I have a 2017 TRD Pro. I read an earlier post (from 2015) that the Sequoia front sway bar greatly improves the handling of a Tundra. Is that still true for the 2017 models? Is that a worthwhile swap? Will dealers install them or do they consider that a warranty issue?
Counselor is offline
The Following User Says Thank You to Counselor For This Useful Post:
post #33 of 51 (permalink) Old 05-27-2018, 04:03 PM
SP
SP's Avatar
Quoted: 412 Post(s)
just get it. Unless your a hardcore off roader you will love the stability the TRD sway bar gives.
2014 CM 5.7L 1794 edition
Front tint(removed its illegal now in NYS)*OEM look alike Brushed steps*GENSSI® ELITE G7 H4 Led's*morimoto LED fogs(excellent)*interior canbus LED's*Husky Floor Liners*Trd Pro grill and color matched front end*TRD sway bar*Extang 2.0 solid fold Tonneau cover*20 inch Black Rhino black wheels*Sotck nit size terra graplers*Bully Dog tuner AWESOME*
SP is offline
The Following User Says Thank You to SP For This Useful Post:
post #34 of 51 (permalink) Old 05-28-2018, 07:39 AM
2underpar's Avatar
Quoted: 34 Post(s)
I also saw all the recommendations and decided to buy and install it, wasn't disappointed in the least and actually thought it was better than advertised.
2underpar is online now
The Following User Says Thank You to 2underpar For This Useful Post:
Mr. Creosote (06-23-2018)
post #35 of 51 (permalink) Old 06-23-2018, 05:33 PM
Just installed my TRD RSB after 5yrs of owning my used 2007 CM 4x4....Wow!! so stupid not to have bought this sooner...$200 well worth it. Yes, it's easy to install. If you need an extra hand, I just used bungee cords to hold up the bar when installing the U brackets...made it super easy.
Enjoy your Tundra...dudes.
2007 Magnetic Gray Crew Cab 4x4 | DigiFit WeatherTech Mats | Sylvania UltraStars | White LED interior lights | Cargo Net for Bed
TundraTumbler is offline
The Following User Says Thank You to TundraTumbler For This Useful Post:
post #36 of 51 (permalink) Old 06-23-2018, 06:49 PM
McGovTundra's Avatar
Quoted: 281 Post(s)
Yup. Like putting 350cc's of silicone in your gals boobs. "Why in the phvck didn't I........."
McGovTundra is offline
The Following 3 Users Say Thank You to McGovTundra For This Useful Post:
restosud (06-23-2018), Sav16CM (06-24-2018), TundraTumbler (06-28-2018)
post #37 of 51 (permalink) Old 06-28-2018, 05:23 PM
Also, did new front Struts/springs and rear shocks (140,000mi on originals)....thought it was time!!! Rides like a truck just off the showroom floor...very nice!!!
post #38 of 51 (permalink) Old 07-06-2018, 08:59 AM
Tundra234's Avatar
Quoted: 272 Post(s)
Just installed mine. Did you guys find it weird that it does not call for a washer on the nut side where it attached to the end links? Haven't looked into swapping out the front yet.
2013 DC 4.6, Flowmaster exhaust, Undercover, V-leds exterior, LED interior, LED strips in door pockets/footwells, Pioneer AVH-P5100 head unit, Alpine Typr R 8" subs, Oracle halos/power indicator, BHLM, Fuel maverick 18x9 +1 offset w/ Nitto Ridge Grappler 285/70/18, Aries bull bar/N-Fab Podium step bars, V-Leds Micro headlights, Rigid fog lights, GrillCraft grill with Rigid LEDs, ReadyLift 3/2 SST, ScanGuage II, Switched backup cam, Vleds 6K LED strips in bed, G-Tek SABM, Clazzio seat covers, G-Tek Fab sill protectors, Line-X bumpers, TRD front/rear sway bars, Pedal Commander, Hornblasters
Tundra234 is offline
post #39 of 51 (permalink) Old 07-06-2018, 09:19 AM
Quoted: 281 Post(s)
No. I didn't find it weird.
I've done the front sway bar with the TRD. Be very aware on my word here: it really tightens and stiffens up the front. If you're currently uber happy with the fronts compliance over small bumps then the TRD front swayer may not be for you.
post #40 of 51 (permalink) Old 07-09-2018, 03:32 PM
Tundra234's Avatar
Quoted: 272 Post(s)
I saw that it is listed on one of the Toyota sites. Does it make the ride rougher and tighten the steering a lot?
post #41 of 51 (permalink) Old 07-09-2018, 08:31 PM
Quoted: 281 Post(s)
In one word? Yes.
post #42 of 51 (permalink) Old 11-16-2018, 03:18 PM
Tundra234's Avatar
Quoted: 272 Post(s)
I see that some members rotated the brackets 90 degrees to raise the bar up so that it doesn't sit so low. Is there any after effects or differences after doing it?
post #43 of 51 (permalink) Old 11-17-2018, 02:40 AM
mudcruiserman's Avatar
Quoted: 10 Post(s)
brackets
The rotated brackets are actually a kit sold by tundra performance/SOS for lowered trucks. If you look closely at pictures you will see the leaf springs flipped/under axle and the links are shorter.
2008 regular cab short bed sport package 53K, 5.7, with console/bucket seats.
SOS lowered, Caltracs, Firestone airbags, Spintech 2 into 1 muffler, X pipe, Rear sway bar, Leer 700 tonneau
mudcruiserman is offline
post #44 of 51 (permalink) Old 12-05-2018, 11:23 AM
Tundra Rod's Avatar
Quoted: 40 Post(s)
Did this on the weekend and I am impressed. The truck actually goes around corners flat!
Only downside is I'm going to go through more tires and fuel because I'm having so much fun!
Tundra Rod is offline
post #45 of 51 (permalink) Old 12-05-2018, 12:42 PM
krienhart's Avatar
Installed rear sway bar and didnt notice anything glaringly different but the tried hitting freeway ramps a little harder and realized it hugs much better.
krienhart is offline
