2018 conversion harness PNP??? Anyone Use it? - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 13 (permalink) Old 06-07-2018, 09:25 PM Thread Starter
Quoted: 5 Post(s)
Hey guys! So im tired of my retrofit as its giving me problems. Ufff HID. I want to get the new 2018 LED headlights. I heard about several kits including kits that use the Morimoto Control Harness. I was going to go with TRS harness but see you still need to repin a harness. I came across Retrofit Wholesale pnp harness and says its 100% pnp (this one 18 TUNDRA LED HEADLIGHT PNP CONVERSION HARNESS ? Retrofit Wholesale). Has anyone used this harness. It doesnt say I need the Morimoto control and it says it has Turn signal adpaters so I dont have to repin. Anyone use this kit? I think I also seen a listning on ebay and it looks like the same kit. Theres reviews on ebay thats positive so im asumming the kit is good. Any input would be great thanks!
2014 Tundra Limited DoubleCab
BFG KO2
Bilstein 6112
Morimoto LED Fogs
RX350 Retrofit w/Panamera DRL shrouds/Custom LED & Diffuser
.........eat my dust pony cars
KENG is offline
post #2 of 13 (permalink) Old 06-07-2018, 09:59 PM
dandailey's Avatar
Quoted: 281 Post(s)
dandailey is offline
post #3 of 13 (permalink) Old 06-07-2018, 11:57 PM
Quoted: 8 Post(s)
I have used the set made by ihacker on the tundras.com forums. They are top notch quality and work extremely well.
SikYota is offline
The Following User Says Thank You to SikYota For This Useful Post:
Lilly (06-09-2018)
post #4 of 13 (permalink) Old 06-09-2018, 09:26 PM
Skiddy's Avatar
Quoted: 143 Post(s)
Are you getting the full function of the lights? How about dimming the DRLs?
Overheating?
Thanks
2016' CM Limited 295/60/20 TOYO Open Country AT, Moto Metal 940 Bilstien 5100 mid setting w/two CB shims each side
Skiddy is offline
post #5 of 13 (permalink) Old 06-10-2018, 12:14 AM
Quoted: 8 Post(s)
Yes I have full function but I also have a Platinum tundra so I already had that function. No overheating at all. Love this harness, looks so much cleaner than the previous version.
SikYota is offline
post #6 of 13 (permalink) Old 06-12-2018, 04:59 PM
Quoted: 47 Post(s)
The PNP version won't dim like the iHacker ones. iHacker has a new harness available that does not require the Morimoto relay. Check out his thread on tundras.com.
I currently have the PNP version and will be removing it for the iHacker version. I'll sell you my PNP version (minus the Morimoto relay) for $50 if ya want.
cooper4x4 is offline
post #7 of 13 (permalink) Old 06-12-2018, 07:14 PM
Quoted: 8 Post(s)
PNP means plug n play. ihackers adapters are PNP.
SikYota is offline
post #8 of 13 (permalink) Old 06-12-2018, 07:18 PM
Quoted: 47 Post(s)
I know what it means. My ihacker harness is not PNP as you have to tap into the harness under the dash. Maybe his newer ones are PNP?
post #9 of 13 (permalink) Old 06-12-2018, 09:36 PM
Skiddy's Avatar
Quoted: 143 Post(s)
I have yet to see a true"PNP" even though they all say it is. For the DRL adapter you either have to switch the pins and use a fuse tap to get it to work.
One of the vendors told me he wouldnt sell the harness that that allows DRL dimming due to the overheating issues.
Skiddy is offline
post #10 of 13 (permalink) Old 06-12-2018, 10:02 PM
Azblue's Avatar
Quoted: 8863 Post(s)
I've had mine hooked up for about 7 months now using ihackers older version with the Motocontrol and the extra relay for the dimming function. I have had 0 problems and everything works like it came stock from Toyota. The install was less work than doing a standard HID system, and now with his new harness, probably even less. It's a top notch harness and the lights themselves are awesome.
Save The Chrome Club #1
SAVE THE CHROME!!!
Azblue is offline
post #11 of 13 (permalink) Old 06-13-2018, 11:32 PM
DSTundra's Avatar
Quoted: 35 Post(s)
Whether or not iHacker's harness is PNP depends on the Tundra you have. With my Platinum, there are two short harnesses on each side between factory wiring and the light, so there's nothing running across the middle and nothing needs to be tapped or repinned...
Dave
2017 Tundra Platinum 4x4 | 2018 OEM LED Headlights w/ iHacker Harness | 2018 OEM LED Fog Lights | TRD Front Anti-sway Bar | TRD Rear Anti-sway Bar | Color Matched Door Handles and Mirror Caps | BAKFlip MX4 | BAKBox 2 | Line-X Premium Bedliner | TRD Shift Knob | Husky X-Act Contour Floor Mats | Drive Bright LED Puddle Lights | LED Interior, Cargo, Third Brake, and License Plate Lights | 5 Window Tint
DSTundra is offline
The Following User Says Thank You to DSTundra For This Useful Post:
SikYota (06-14-2018)
post #12 of 13 (permalink) Old 06-14-2018, 09:32 AM
Skiddy's Avatar
Quoted: 143 Post(s)
I just picked up a harness from another vendor I found on a Tundra Club on Facebook, Randy from Xkstensive Off-Road. Great service and he responds to messenger on the fly.
And yes I get it now, because I have a Limited I had to run a second adapter across to both sides and re pin the turn signals. Very straight forward though.
Skiddy is offline
post #13 of 13 (permalink) Old 06-14-2018, 08:26 PM
Quoted: 8 Post(s)
Only the platinum/1794 harness is completely PNP.
SikYota is offline
