2017 fog light housings loose, rubbing through paint? - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 6 (permalink) Old 10-09-2017, 07:58 PM Thread Starter
Powertechn2's Avatar
Quoted: 1663 Post(s)
Is anyone else having this issue?
Since it is getting dark sooner I noticed when I hit bumps my fogs really really move around.
I looked when I got home, the housings are so loose that they have rubbed through the paint on the bumper wings.
I can jiggle them around.
Just over 5k miles on the truck, I don't offroad, haven't hit anything, and don't even drive down dirt roads, and if I have to, I go slow, hate rock chips.
Tried to get pics/vid, but it's too dark, didn't turn out.
and you can call me Power.
Powertechn2 is offline
post #2 of 6 (permalink) Old 10-09-2017, 09:16 PM
Brian20's Avatar
Quoted: 157 Post(s)
Iíve got a 16 sr5, so the chrome bumper wings, and the fog lights are tight, no movement.
Brian20 is offline
The Following User Says Thank You to Brian20 For This Useful Post:
Powertechn2 (10-09-2017)
post #3 of 6 (permalink) Old 10-09-2017, 09:38 PM Thread Starter
I have the Plat, so plastic bumper wings.
At first they were tight.
Now they are loose as all get out.
post #4 of 6 (permalink) Old 10-13-2017, 11:38 AM
TacoBlack's Avatar
Quoted: 216 Post(s)
did you change any bulbs or have someone change your bulbs? the fog light shroud will become very loose fitting if someone tries to remove them from the front. to tighten them up remove the lower inner fender liner to get to the back of the fog light, just as if you were changing the bulbs. you will find a blue locking clip holding one of the tabs. simply remove the blue locker and flipit over and reinsert. it will still lockin place but put a lot more force on the tab thus holding it much tighter. hope this makessome sense. once you pull the inner fender you will see what needs to be done.
2014 Magnetic Grey Crewmax Platinum, Toytec coilovers up front, Coachbuilder 2+ shackles, Firestone air bags & bilstein 5100 in the rear. 20x9 Raceline Assault with 295/60/20 Toyo ATII, Debadged, Bak Flip VP, Line-x Liner, LED interior/exterior lights, Puddle lights LED mod, Clifford alarm/starter with windows and sunroof control, Grillcraft 3pc black MX grill, tinted windows, custom Magnaflow exhaust. Nfab wheel to wheel step bars. D2S 5000k Morimoto HID retrofit with BHLM, JL Audio clean sweep, Jl 500/1, Jl 300/4, 2-JL10tw3 subs, Jl ZR 650csi components front and rear.
TacoBlack is offline
The Following User Says Thank You to TacoBlack For This Useful Post:
Powertechn2 (10-13-2017)
post #5 of 6 (permalink) Old 10-13-2017, 06:46 PM Thread Starter
I swapped Morimoto's in, but I did it through the backside.
Thanks, I will look into swapping the clip around.
I remember that the housings seemed kind of shoddily held in place.
post #6 of 6 (permalink) Old 10-16-2017, 11:27 AM
TacoBlack's Avatar
Quoted: 216 Post(s)
i had the same issue after installing the morimoto fogs aswell, the clip flip fixed mine.
Powertechn2 (10-16-2017)
