Headlight Bulbs - Page 5 - TundraTalk.net - Toyota Tundra Discussion Forum
post #61 of 74 (permalink) Old 01-31-2017, 03:17 PM
epak007's Avatar
Quoted: 34 Post(s)
don't have any i'll try to get some for you
Originally Posted by TundraDude85 View Post
Do you have any night pics available? I'd love to compare them to my fog setup. It's good, but I'd like to see others.
2017 Platinum crewmax, Toytec Boss coil overs w/ Total Chaos UCA's,Toytec Boss dual reservoir shocks w/ Toytec shackles 1.50" on the rears, 20" Method NV wheels w/ 295/60/20 Toyo AT's, TRD rear sway bar, color matched door and mirrors, Nfab, Corsa sport exhaust, Line-x spray liner, dash cam, Pace Edwards jack rabbit cover, Xenon LED headlights & fogs, Bedslide, Yakima aero blades, LED interior, rear & puddle lights, TRD skid plate, D.A.P. tune, Rigid fog lights
epak007 is offline
post #62 of 74 (permalink) Old 02-01-2017, 12:37 PM
muddybumper's Avatar
Quoted: 21 Post(s)
Originally Posted by muddybumper View Post
Here are the PIAA Night Techs installed. Pretty much only took one after shot and a side by side with both the old bulbs and new installed. Hope it helps anyone. The only bulbs were some variety of Sylvanias, the Night Techs look almost as white as LEDs.
I was able to pull a before shot with the old headlights off my dashcam for a side by side.
muddybumper is offline
The Following User Says Thank You to muddybumper For This Useful Post:
Powertechn2 (02-01-2017)
post #63 of 74 (permalink) Old 02-01-2017, 12:51 PM
RitcheyRch's Avatar
Quoted: 168 Post(s)
That's a huge difference
"I didn't pay them for sex, I paid them to leave"
Charlie Sheen
Life is all about ass, you're either covering it, hauling it, laughing it off, kicking it, kissing it, busting it, trying to get a piece of it, or behaving like one.
Silver Sky Tundra Club Member #182
RitcheyRch is offline
The Following User Says Thank You to RitcheyRch For This Useful Post:
post #64 of 74 (permalink) Old 02-01-2017, 01:16 PM
TundraDude85's Avatar
Quoted: 34 Post(s)
Amazing! They look great
2014 1794 Tundra Super white purchased Jan 19th
Need advice on issue with dealer, link below. Any help/advice is appreciated. Ill remove once issue is resolved. 2/2-??
TundraDude85 is offline
post #65 of 74 (permalink) Old 02-01-2017, 02:19 PM
I bought Silverstars a while back but can't figure out how to install the damn things and I haven't had any time to research.
Verne
iverne is offline
post #66 of 74 (permalink) Old 02-01-2017, 03:51 PM
RitcheyRch's Avatar
Quoted: 168 Post(s)
I wonder if anything has changed since this report
Sylvania Silvestar Halogen Headlight Bulbs - Consumer Reports
Charlie Sheen
post #67 of 74 (permalink) Old 02-01-2017, 07:28 PM
scotch's Avatar
Quoted: 19 Post(s)
Anyone try vleds.com headlight bulbs?
2010 5.7L DC TRD 4x4
2005 4.7L 4Runner
Method 20x9 Fat Fives, 305/55/20 Duratracs, Bilstein 6112/5160, SPC Upper Control Arms, TRD Rear Swaybar, OME/Dakar leafs with CB +1 Shackles, Husky Weatherbeaters, Du-Ha, Extang Solid Fold, Line-X, Toyota Bed Mat, Stoptech Cryo Rotors and pads, Goodridge brake lines, Stoptech STR-660, Rigid Fog Lights, Odyssey Battery, Firestone Airbags with CB spacer, etc, etc...
Previous Toyota's: 97 4runner, 02 tacoma, 09 tacoma
scotch is offline
The Following User Says Thank You to scotch For This Useful Post:
TundraDude85 (02-01-2017)
post #68 of 74 (permalink) Old 02-01-2017, 10:25 PM
qqqqqqqman's Avatar
Quoted: 114 Post(s)
Not really a ''lights guy'', lol......almost never replace stock unless they burn out. But those pics look great for just bulb replacement!
Are these the correct ones for a '15 Tundra?
https://www.amazon.com/PIAA-10704-Ni...00544ZD86?th=1
OR these?
https://www.amazon.com/PIAA-70485-Ni.../dp/B005SG25AE
2015 Tundra CrewMax, Magnetic Gray Metallic....SR5 Upgraded bucket seats, Pro Comp Pro-Runner 2.5" front strut leveling lift, Bilstein 5100 rear shocks, XD Monster II 20x9 wheels (+18 offset), Nitto Terra Grappler G2 275/60-20 tires, N-Fab Nerf Bars......debadged
Magnetic Gray Metallic Club member #319
qqqqqqqman is offline
post #69 of 74 (permalink) Old 02-02-2017, 05:53 AM
Quoted: 16 Post(s)
Dis mantling the front end to change the bulbs stopped me from upgrading but was all set to install some silverstars. Mind boggling why toyota made it such a chore to change a headlight bulb.
swimbait_charlie is offline
post #70 of 74 (permalink) Old 02-02-2017, 07:59 AM
Quoted: 34 Post(s)
Headlight Bulbs
It is insane the fact that u can't reach behind and swap it. But I rather do the work and swap the bulbs than leave the stock bulbs.
post #71 of 74 (permalink) Old 02-02-2017, 12:19 PM
partyguy816's Avatar
Quoted: 44 Post(s)
The first time might take you about 25 to 30 minutes to change them out. Once you've opened it up once, the next time is only about 15 minutes or so. It's very easy.
partyguy816 is offline
post #72 of 74 (permalink) Old 02-02-2017, 01:34 PM
Powertechn2's Avatar
Quoted: 1642 Post(s)
Ford and GM require you to take a bunch of stuff apart also. Kinda just seems the norm anymore.
and you can call me Power.
Powertechn2 is offline
post #73 of 74 (permalink) Old 02-02-2017, 03:23 PM
qqqqqqqman's Avatar
Quoted: 114 Post(s)
As Ive noted, I never change my bulbs. Didn't know you can't just remove/replace bulbs....aarrgghh.
I have taken the front grille off.....I have to do that again?
post #74 of 74 (permalink) Old 02-02-2017, 03:41 PM
Quoted: 21 Post(s)
OR these?
Not really sure about the 2015 bulb sizes but I think the first one you linked will fit.
