N-Fab Light Bar with 30-inch LED Bar Installed on TRD Pro - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 24 (permalink) Old 02-03-2016, 01:37 PM Thread Starter
Quoted: 20 Post(s)
Talking N-Fab Light Bar with 30-inch LED Bar Installed on TRD Pro
After some trial and error with mounting the light bar and clearance issues, its all on!
^Just the LED Bar on.
^Just the LED Bar on again.
I will try to get some better pics tonight.
RJ
-16 Tundra TRD Pro CrewMax -Magnetic Grey
rjs1022 is offline
post #2 of 24 (permalink) Old 02-03-2016, 02:02 PM
Senorx's Avatar
Quoted: 332 Post(s)
Nice!
2015 Tundra CM TRD Off Road 4x4 / Super White / Bilstein 6112 (top) / 5160 / Camburg UCAs / Coachbuilder +1 / BFG AT KO2 275 70 R18 / TRD Pro Wheels / N-Fab Steps / LineX / VLED Interior / 42 in LED Bar / TRD Pro Grill / TRD Pro Skid Plate / WeatherTech Rear Floor Liner
Senorx is offline
The Following User Says Thank You to Senorx For This Useful Post:
rjs1022 (02-03-2016)
post #3 of 24 (permalink) Old 02-03-2016, 02:17 PM
Quoted: 15 Post(s)
Looks good!
vr0ck is offline
The Following User Says Thank You to vr0ck For This Useful Post:
post #4 of 24 (permalink) Old 02-04-2016, 08:08 PM
what light bar did you use and what kind of issues did you encounter
2016 Trd pro
quicksand
295/70/18 cooper maxx
spray in liner
Tpehl66 is offline
post #5 of 24 (permalink) Old 02-05-2016, 04:48 AM
Supporting Vendor
CARiD's Avatar
Quoted: 23 Post(s)
Looks great! How was the installation, any difficulties?
Toyota Tundra
Call Toll Free: 800.505.3274 |
CARiD is offline
The Following User Says Thank You to CARiD For This Useful Post:
rjs1022 (02-05-2016)
post #6 of 24 (permalink) Old 02-05-2016, 04:07 PM Thread Starter
Quoted: 20 Post(s)
Thank you! I used the MIC Tuning 31.5in LED Light Bar. I got it on Amazon and then resealed it before installing it:
MICTUNING.com 31.5 inch LED Light Bar Flood/Spot Combo
During the install the only real issues i had were initially installing the N-Fab brackets due to the limited amount of room you are working with in the bumper and the directions that they give you are not clear at all. And the other issue was that the brackets that i received were about 1.5in too tall so i just went to Home Depot and got some 3 inch L brackets and it is on there solid for now. I will make some nicer ones but i just wanted to get it on there for now.
RJ
rjs1022 is offline
post #7 of 24 (permalink) Old 02-25-2016, 11:01 PM
rpeker's Avatar
Quoted: 8 Post(s)
I have nearly the exact same setup and I couldnt be happier for the price I paid!
Fast - Cheap - Reliable... Pick two
rpeker is offline
post #8 of 24 (permalink) Old 03-01-2016, 11:07 PM
Only downside I've had is persist rattles and noise from the mounts, several attempts to re torque hardware to keep quiet.
FLUFFY PANDA is offline
post #9 of 24 (permalink) Old 05-06-2016, 09:36 PM
Quoted: 58 Post(s)
What was the mount part number, I am looking at the nfab N-FAB T1430LD-TX LIGHT BAR FOR LED, wondering if that one u installed is better?
2014 Crew Max TRD Magnetic Grey
MGMC# 326
TRD Rear Sway Bar
U Guard 4 Inch Oval stainless side bars
Lund Bug Deflector 2
AMP Bed Step
Back Rack
Canadian Tundra Club
Nebah is offline
post #10 of 24 (permalink) Old 05-06-2016, 10:36 PM
I used the T1430 gloss black
post #11 of 24 (permalink) Old 05-09-2016, 10:24 AM Thread Starter
Quoted: 20 Post(s)
I used the T14300R
Manufacturers of high quality Nerf Steps, Prerunners, Harley Bars, Light Bars, Replacement Front Bumpers, Rock Rails, Rear Runners, Tire Carriers & Truck Accessories
RJ
rjs1022 is offline
post #12 of 24 (permalink) Old 05-16-2016, 10:27 PM
BorderCop's Avatar
Quoted: 41 Post(s)
I got mine installed today after a four day delay. The original brackets that came in the box had the captive nut welded off-center and crooked. Of course I found this out after I had started the install and could not thread in the bolts. Anyways, a quick email to Nfab after hours was promptly answered by "Scooter" the next morning at 7am. By 2pm I had a Fedex tracking number for 2 new brackets headed my way. Kudos to Scooter but I have to ask myself, good customer service or are they well versed in dealing with bad quality control?
The brackets came in today and first thing I noticed was that Scooter made sure the bolts threaded in properly because the bolts were taken out of the hardware bag and threaded in the brackets. The new ones also had much better welds overall (weird) as if they made me a new set or they stock different ones (?).
Easy install although it's a tight space.
BorderCop is offline
post #13 of 24 (permalink) Old 05-17-2016, 05:44 PM
Quoted: 7 Post(s)
Installed the same on mine, not much space to move brackets around!
svichera is offline
post #14 of 24 (permalink) Old 05-17-2016, 10:31 PM
Quoted: 58 Post(s)
I have read that the brackets require the grill to be removed as well as some cutting of plastic mini grill in bumper, did u have to do this?
thx
MGMC# 326
TRD Rear Sway Bar
AMP Bed Step
Back Rack
Nebah is offline
post #15 of 24 (permalink) Old 05-17-2016, 10:33 PM
Quoted: 7 Post(s)
Yes. It was a nightmare. And the brackets are angled so it is extremely hard to tighten the three nuts on each side. The grill is easy to remove, the rest is tough and the instructions are pretty worthless.
svichera is offline
