Recommendations on Used Tundra (2014-2016) - TundraTalk.net - Toyota Tundra Discussion Forum
post #1 of 14 (permalink) Old 01-19-2017, 12:42 PM Thread Starter
Quoted: 31 Post(s)
Hi, I'm about to buy a slightly used (possibly Toyota certified) Tundra CrewMax 2WD with the 5.7 engine.
There are several for sale in my area ranging from 2014-2016 with low miles. Some seem to have the FFV engine, some don't.
I'm wondering if there is any reason to go with a specific year model in that range? Or a good reason to dodge the FFV?
Also, after buying a used or certified Tundra, can I get an extended warranty somewhere else at a good price? If so, where and what's a good price?
Anything else I need to consider? Thanks in advance.
Jarrett is offline
post #2 of 14 (permalink) Old 01-19-2017, 02:25 PM
Quoted: 238 Post(s)
JMHO...Toyota Certified is a BS scam that allows them to sell a used vehicle at a higher price. Yes you get a little warranty with it, but it certainly isn't a huge selling point for me.
If I had it to do over, I would buy a non-FFV (if it was offered in my area) just because I have never and will never use flex fuel. I think the non-FFV's get oil changes every 10K miles and I have to get it every 5K miles.
2014-16 is pretty much the same truck as far as I know.
As far as warranty, there is a thread about where to purchase a 100K/7-8yr warranty at a great price, just search for it.
The only other thing is that sometimes you can get a new truck for about the same price as a used one in that year range. Thats why I bought new.
MGMC #262
2014 Tundra CrewMax, 4X4, TSS in Mag Grey
TRD Swaybar*Bilstein 5100 -top setting, Bilstein 5160s*CB +2s*G-Tech Fab - SABM*Bakflip G2*BAM Budget System
Great Scott is offline
post #3 of 14 (permalink) Old 01-19-2017, 02:51 PM
rruff's Avatar
Quoted: 473 Post(s)
You don't need a shorter oil change interval if you never use E85.
rruff is offline
post #4 of 14 (permalink) Old 01-19-2017, 04:05 PM
Quoted: 238 Post(s)
@rruff , I asked the dealer and they said it doesn't matter. I have the extended warranty, so I'm going to continue that interval until my warranty is up.
MGMC #262
post #5 of 14 (permalink) Old 01-19-2017, 04:36 PM Thread Starter
Quoted: 31 Post(s)
Do you have to use the same 0-20w full synthetic oil on the shorter FFV oil change interval? I think it's $95 in my area.
It would make a difference if I had to do that every 5,000 miles instead of 10,000.
Jarrett is offline
post #6 of 14 (permalink) Old 01-19-2017, 05:08 PM
rruff's Avatar
Quoted: 473 Post(s)
Using AMSOIL Beyond 3000 mile oil changes and how it affects your vehicle warranty
Will extending oil change intervals void my warranty?
No. Extending oil change intervals will not void new vehicle warranties. To affect the vehicle warranty, it must be determined that the lubricant was directly responsible for the failure; if the oil didn’t cause the problem, the warranty cannot be voided, regardless of brand or length of time in use.
Since non-FFV Tundras have 10k intervals it would be impossible for Toyota to make a viable case against 10k intervals in a FFV that only used standard fuel. I'd guess the reason they are not able to make this distinction in the owners manual is some legal requirement regarding the EPA concession they get for selling FF engines.
rruff is offline
post #7 of 14 (permalink) Old 01-19-2017, 08:43 PM
tstieb's Avatar
Quoted: 93 Post(s)
I think the certified warranty was fairly substantial. Don't recall specifics but a plus for sure. Might want a 16 as they had the larger fuel tank.
tstieb is offline
post #8 of 14 (permalink) Old 01-19-2017, 08:56 PM
Schaffer05's Avatar
Quoted: 315 Post(s)
When I bought my 2014 certified it was a 12k warranty. My truck only had 20k miles so it was a moot point.
I did end up reporting the dealer to Toyota though. The cabin air filter and engine air filter were both filthy, both part of the certified check list. Then had another Toyota dealer do the certification for ease of mind. Figured if they were too lazy to check the easy stuff, you know they didn't check the other stuff.
Schaffer05 is offline
post #9 of 14 (permalink) Old 01-20-2017, 07:34 AM Thread Starter
Quoted: 31 Post(s)
Hmm, that is interesting. How much larger in the fuel tank in the 2016? That would be nice to have.
It sounds as if the FFV engine costs roughly $600 more a year to maintain as Toyota says the same oil is used in both FFV and non-FFV engines. I haul an RV a couple of times a month and the non-FFV is a proven workhorse for me, I'm just worried that the FFV might not be as reliable or fuel efficient, especially since it seems to need its oil changed more frequently than the non-FFV for some reason.
Are there any stories of the FFV not being as reliable as the non-FFV engine?
Jarrett is offline
post #10 of 14 (permalink) Old 01-20-2017, 11:05 AM
TheLast13's Avatar
Quoted: 16 Post(s)
Here in Ohio I wanted a crewmax 4x4 2014 and I could only find FFV, so I didn't have a choice. It would be nice to have gotten the larger fuel tank, but Ill take what I can get and afford.
Id say just get the newest and lowest mileage truck you can afford.
TheLast13 is offline
post #11 of 14 (permalink) Old 01-20-2017, 01:01 PM
rruff's Avatar
Quoted: 473 Post(s)
Bigger tank is an option. It won't necessarily be on the truck you want.
$600/yr? What are you smokin? That's at least 6 more oil changes per year. You drive 60k miles per year?
I know for me, the FFV will cost $0 more to maintain. There is no reason to change the oil more often unless you use E85.
The difference between the FFV and the non, is fuel lines, pump, and seals made to handle E85, and a computer that is able to sense the ethanol content. It *might* be less reliable if you burn E85, but on regular gas it should be the same.
rruff is offline
The Following User Says Thank You to rruff For This Useful Post:
Schaffer05 (01-20-2017)
post #12 of 14 (permalink) Old 01-20-2017, 01:06 PM Thread Starter
Quoted: 31 Post(s)
My bad, only $300 more a year for my driving habits.
That was my next question. What models have the bigger tank?
Jarrett is offline
post #13 of 14 (permalink) Old 01-20-2017, 01:07 PM
Schaffer05's Avatar
Quoted: 315 Post(s)
2016+ with the SR5 upgrade package and higher.
post #14 of 14 (permalink) Old 01-20-2017, 01:18 PM
I went from a 2006 Tundra DC SR5 to a 2008 Tundra DC SR5 TRD and love the extra room and towing power!
JCRiggs is offline
