I just purchased a 2008 Tundra CrewMax, at first the truck would chirp when I locked and unlocked the doors but after the first wash I gave it is sounds like the chirp is underwater. Can someone tell me where the "beeping" unit is located as so I can try to dry it out.
The chirp box is under the LH "driver" headlight. If you remove the filler panel under the light its right there. I pumped a little clear silicone into mine it was a bit too loud.
Thanks for your quick reply and help! Found it and just as expected it had a fair amount of water/corrosion but I'm back in business now!
