Can anyone tell me what is the correct name for the smaller radiator/cooler on the passenger side of this picture? Also...is it possible to relocate it to the drivers side? Thanks, in advance
That's a transmission cooler. You have the tow pkg which the cooler comes with. You probably can relocate it but more than likely all new tubing to the new location.
Well, I was just thinking of relocating it to the drivers side and possibly using the existing spot for a ram air intake... Just thinking. I'll have to look t it up close to see if it would be a a big problem. Thanks!
Moving it is fine. Just be sure you still have sufficient airflow. Moving it to the other side of the radiator will be ok as long as it doesnt interfere with the A/C plumbing over there. You could also add a small electric fan. Then you could mount it wherever you wanted. Check out Summit or Jegs for pics of trans coolers with fan modules attached.
Like this one... http://www.jegs.com/i/Be+Cool+Radiators/134/96300/10002/-1
...or this one for a lot less $$... http://www.jegs.com/i/JEGS+Performance+Products/555/60346/10002/-1
That's when I would definitely replace it with the $100 Jegs unit that comes with a cooling fan.
